Creep point adaption - Value flickering
luzt
Hi!
At the creep point adapation the fourth value (the box to the far right) jumps between 0/16/255 totally random.
Because of this I'm stuck at the first step of the adaption with a 5 in the third box and it does not at ALL respond to the break pedal. No problems with the brake light switch (works perfect). No fault codes what so ever.
The car is usable and the general basic settings works perfect and the clutch cylinder value is at a solid 1,85V.
What does the fourth (4) value display? Some sensor is broken, it's just a matter of knowing which one!
Big thanks in advance! :)
      Online Kredit
    2. 107
    3. 107
    4. 107
    5. 107
    6. 12
    7. 12
    8. 56
    9. 20
    10. 12
