anyone AMF/ATL using GT1749 (eather v, va vb)
stylophonic
hi there not had much luck online finding many members running this turbo on their tdi,, are any of you guys using this turbo??.. if so whats your impressions of it? how much boost are you running?
how much power are you making>? which version of turbo are you using? would you recomend?
Variable turbos will only work on the ATL 90HP engine. The AMF and BHC work with a 'traditional' waste-gate turbocompressor and cannot (reasonably) be fitted with a VNG turbo.
Here's a conversion video on Kane's 6 speed gearbox.
Here (you already found this thread) you can read what happened. During an ordinary control non-standard items were discovered that were not approved. All upgrades were then retrofitted.
    2. 0
      Kälteleitungen erneuern
    3. 18
    4. 21
    5. 57
    6. 9
    7. 18
    8. 12
    9. 12
    10. 57
