dismantle crankcase oil
djrer
You have to turn the flywheel maybe 30 degrees from the position you removed the screws.
Try it in 2 stages.
First you can pull out the oil block in front (or backside)of the car and then you turn the flywhell back to remove te oil block completely.
It works.
In the next stage be very carefull to remove the plastic protection. It breaks very easy.
Good luck.
    2. 22
      Dachzelt
    3. 0
      [V] Aufgearbeitete Klimabedienteile im Tausch oder Kauf
    4. 93
      [1.2 TDI ANY] Hydraulikeinheit: Adapter für alternativen Febi Druckspeicher
    5. 93
    6. 24
    7. 24
    8. 24
    9. 24
    10. 1.367
      LED anstelle H7
