VW Lupo 3L manual ABS problem
iwcham1979
Hi guys. I appologize for the post in English, but my German is rather bad... I think this is better than having google translate it to German :( I have a Lupo 3L converted to manual, and my ABS is not working... I have heard it is almost impossible to make it work, but I know you guys have very strict Mot in Germany  so you must have found a way to make it work...My mot is nearing so if you have any tips or info I would very much appreciate it! Otherwise, my only solution is to remove the Abs module and install a non-abs master brake cyllinder... I would like to avoid that sollution if possible... Thanks in advance...
Moderator:
Moved thread to correct sub-forum.
    2. 45
    3. 45
    4. 3
    5. 1.373
      LED anstelle H7
    6. 10
    7. 1.373
      LED anstelle H7
