hifi system
gianni21
Look at your battery in the back, if there is a Speaker right beside the battery (black plastik Subwoofer from Bose) than you should have a bose system. (Then you have it).
You also then must have an amplifier in the box under the passegers feet (and your repairing-tools must be in this box too.) and under those tools is the amp.
Open the trunk.
Our battery is in the trunk (behind the rear passengers. open the box at the bottom of the trunk. There is the battery:
all the other space except the battery is for the bose Sub.(in this pic there is no Bose! there is an amp or a second battery and a condensator) .attachment.php?attachmentid=9627
Original von erstens
BTW, there's also an amp if you have regular rear speakers installed (but no tool tray).
Don't BOSE speakers also wear a small BOSE label on it? At least the ones installed in the front doors?
___edit: A label similar to this one from an Audi TT's Bose system.
Right, that means: If your tools (compressor tyrerepairing kitt and Lifter) are beside the battery, You don´t have Bose (or the Sub is missing/stolen or sold allready, so look in the box under the right front seat. YOu can lift up the carpet to get there.
If there is a 20cm large black box with a broun plug with 25 Pins then it is the Bose Amp.Otherwise you have a 10cm small Aluminium box wich is the Blaupunkt Amp for the rear speakers.
    2. 0
      Biete: 3L A2 1.2 (ANY)
    3. 1
    4. 12
    5. 12
    6. 12
    7. 12
    8. 1
    9. 12
    10. 22
