linelis
    1.2 TDI
    Lt
Leistung von linelis
  1. Thanks! I will try. Let you know what happened.
  2. Thanks for prompt response. Odometer shows 140 000km, and seems that it is right mileage, because I have service book from earlier owner. Hm interesting. It will be not verry nice if it is true... As I understand there is a lot of work to change that part. But if that part would be failed wouldn't there be any problems during clutch ajustment? Or would't I feel when driving?
  3. Hallo, Ich spreche deutche nicht gut, bitte helfen sie in englisch. Danke! I tried to search forum for similar problem, but as my german is not good, I haven't found the answer. As the title of this thread states, I have Audi A2 1,2TDI, 2002 year. The problem is that engine doesn't start when gear selector is in STOP position. I push selector to the N position and engine starts with no problems. Hydraulic fluid level is ok.I made clutch adjustment, basic settings and creep point settings with no problems. Car drives normaly. Brake lamps and indicator near gear slector works when pushing the brakes (indicator turns off when brake is pushed), so I think brake pedal sensor is good. Also I tried change gears when not driving and engine is off, I can make only 2-3 gear changes and then pump begins pumping again. So I order pressure acumulator. Could the reason be pressure acumulator? What other reason could be that I can't start engine in STOP position? P.S. I have this car only for a week, so I am new to that interesting model Vielen Dank für Ihre zeit!
