ericosman
Alle erstellten Inhalte von ericosman
Expand retrofited central locking range
ericosman antwortete auf ericosman's Thema in English language forum
Today i found out whenn the door is open i have "normal" range Puting the cable just up wont help -
Hi all, Sorry had no time (yet) to check what happes whenn i just put the wire up.. But yesterday i had like 3 meter range from the passenger side range... And today u have to be almost in the car... -
Ok, but now i'm a little confused what to do:kratz: I have to cut the cable i guess? And where should i put the cable? And do i have to place it in some kind of shape? And do i need to have the end open so it can connect to metal? -
So i have to cut my cable to 34-35 cm? I see the lambda are antenna's? Is there a specific antenna you recommend? -
But if i cut my cable to 17.3 cm i will have better range? -
It's no big deal atm but it's just not verry handy I looked for some antenna's but could not fine them -
If you know where i can get a a2 antenna tell me But if i get it right now i have to only use a 17.3 cm cable ? So it will be only under the driver? -
Ok and i will have to place it here ? ( red line ) And what kind of wire do you recommend? -
:kratz: mmmm... so how long do's the cable need to be ? The Hz of the remote is 433,92 MHz ( remote 8Z0837231 ) -
Hi, The guy put a yellow wire there ( i hope in the right spot ) It looks like this : -
Hi, Someone placed a new CCU in my car so it would be possible to use remote keys. Now i have the right remote keys and it's all working But there is a downside to this... And the problem is i have a minimal range.... The range is only like 1 meter ( from the drivers door ) sometimes it's more or less... ( i guess it depends on the weather ? ) Stuff i tryed: Use a new battery Place the wire ( used as an antenna ) above the drivers door But still the range is crappy Do's anyone know how i can expand the range like "normal" ?
I got the right keys and someone put a wire ( as an antenna ) in the left cover. But i only have reception like 1 meter from the drivers door... Is there a good way to extend the range?
Hi, I recived a message from the seller i bought them from and he told me: "keys you have bought wont work with that module. the module needs 8Z0 837 231 (no letter at the end) if you get 8Z0 959 433 AF it should work ok." So... some one wants to buy my "old" remotes:bonk:
Maybe good to know i bougth these keys: http://pages.ebay.com/link/?nav=item.view&alt=web&id=181673873497
If i understand right he changed his CCU and tryed to get the key working ( start and open the car ) but only could start the car and open the car by key and not remote? If so yes thats also my problem.
Haha zou wel handig voor me zijn ) maar zover ik het begrijp is er een grote kans dat ik de juiste sleutels heb...
So maybe i have the right keys ? Because the ccu is 433.92MHZ and the keys also.
But i guess its dependents on the CCU model instead of the build year:confused:
Hi, my ccu is from build year 2007 So i guess i can sell my "old" keys and buy "8Z0 837 231"
Hi, A friend of mine got the blades working with the car but he cant get the remote working ( untill now ) he did it multiple times on other A2 cars. So i dont know what he did.
Hi Guys, I have an Audi A2 1.4 ( build in 2000 from germany) with a new Ccu 8z0 959 433 N and i bougth 2 keys: 8Z0 837 231 D But i cant get the remote working... What do i do wrong? The blade works but i cant use the remote. Do i need diffrent remotes? Like the 8Z0 837 231 ?
Hi, Sorry i have an audi chorus radio : http://i614.photobucket.com/albums/tt227/partsdepot_uk/CHORUSSTAEROA4A6TT.jpg?t=1289403502
Hi, On an other forum i'm reading you should use this one : Audi A2 A3 A4 TT Car Radio Wiring Loom Harness PC9-404 | eBay with this : PC5-90 AUDI A2 A3 A4 AMPLIFIED ISO - DIN AERIAL REPLACEMENT ADAPTOR MAST ANTENNA | eBay or is the kit from my first post also right? and what part go's in my new radio ?
Hello, First of all sorry for my English... but i cant speak German. first let me introduce myself my name is Eric Osman and i'm from the Netherlands. Sinds 2 days i'm a proud owner of an Audi A2 1.4 Diesel ( From 2000 ). Now comes my question : I would like to install an aftermarket radio in my car. My car has a Blaupunkt thing under the passenger chair ( i guess for the back speakers ? ) now i think i need : Radioeinbauset Radioblende+Aktivsystem- & Antennenadapter für AUDI A2 A3 A4 A6 | eBay But is this right ? and do i need something else ? Thank you very much!
