Was my German that bad?
I need to know where I can get the ABS signal for the rear wheels (left and right), so which cables to splice (at the driver's footwell) incl colours and connector colour. In other words, there is a connector in the driver's footwell, behind the plastic panel and directly besides the clutch pedal, which has two pins which carry the rear left and right ABS signal. I need to know which pins or cable colours I need to get the ABS signal.
Alternatively, the ABS computer should have signal-out connections. Only, I don't knwo where it is located, and don't know which cable to use.
I need it to get my Navi Plus the correct signals. I have an older version of Navi plus, non-DX, which will not accept speeed pulses lower than 12 impulses. GALA gives me 8 pulses, which is too low. This means my GPS signal is not interpreted correctly by my Navi system. The solution to all this is using the ABS signal, which gives out 45 pulses, and which can be programmed in the Navi plus using the correct wheel diameter.
I have tried using GALA at 8 pulses, setting the system to 12 and then multiplying the wheel circumference by 1.5. This does not seem to work.
I have also tried using the Hall-sensor signal (located at the speedo) but this does not work either.
Another solution is to use a GALA impulse doubler, which converts the 8 pulse signal into a 16 pulse one, but I would really like to avoid feeding the system false info.
Hence my question;
"Where can I get the ABS signal, so I can use the navi plus system correctly?"
