Hello everybody!
	I am new to this forum and what brought me here is, as it often happens, a big problem that I can't figure out myself...
	My lovely A2 1.6 FSI, which I own for less than a year started misfiring about 6 months ago. It started as barely noticeable and gradually it's getting worse and worse...
	The engine works perfectly for 3-5 minutes after cold start.
	Then after a little warming up (say, 3-5 km travelled):
	   Works ok at ide.
	   Works ok (ish) at revs >4000 RPM.
	   Noticeably misfires at RPMs around 2000-2500, especially around 50% throttle.
	Check engine blinks then light up. Here are the errors I am getting all the time:
	Control Module Part Number: 036 906 013 F
	Component and/or Version: MED7.5.11 4628
	Software Coding: 00051
	Work Shop Code: WSC 02138
	Additional Info: WAUZZZ8Z53N005638 AUZ7Z0B2098087
	VCID: 122DCA0A5E18EB8E3D9-5000
	6 Faults Found:
	17443 - Sensor for NOx (G295)
	P1035 - 35-10 - Signal Implausible - Intermittent
	16523 - Oxygen (Lambda) Sensor B1 S2
	P0139 - 35-00 - Response too Slow
	17584 - Bank1: O2 (Lambda) Correction Behind Catalyst
	P1176 - 35-00 - Control Limit Reached
	16684 - Random/Multiple Cylinder Misfire Detected
	P0300 - 35-10 - - Intermittent
	16685 - Cylinder 1
	P0301 - 35-10 - Misfire Detected - Intermittent
	16687 - Cylinder 3
	P0303 - 35-10 - Misfire Detected - Intermittent
	Misfiring cylinders are randomly different every time.
	What I did so far:
	Fuel system:
	-          Replaced fuel filler cap – no effect
	-          Replaced fuel filter – no effect
	-          Replaced fuel pressure regulator – no effect
	-          Replaced Activated charcoal canister – no effect
	-          Replaced N80 solenoid valve – no effect
	-          Used injector cleaning fuel additives several times – sometimes they seemed to have helped a little, maybe…
	Ignition:
	-          Replaced spark plugs – this probably helped a little
	-          Replaced ignition coils – this helped a lot but didn’t solve the problem
	Engine mechanics:
	-          Checked compression
	I did this in a garage – I don’t remember the numbers, but the guys said all cylinders are even and the values are good.
	-          Cleaned up the grounding point behind the left headlight – didn’t do much.
	Now I’m puzzled where to look next.
	I attach also here a few logs.
	Any advice will be highly appreciated!
LOG-01-007-140-142.csv
LOG-01-007-140-142 1.csv
LOG-01-007-140-142 2.csv
LOG-01-007-140-142 3.csv
