Germantas
A2 Modell
1.4 (BBY)
Baujahr
2003
Sweden
Leistung von Germantas
[1.2 TDI ANY] hydraulic oil pump constantly running
Germantas antwortete auf Germantas's Thema in English language forum
I found lot of information about pump unite O rings,but not gears selector. P.S. Finally found it in Wiki. Thanks -
I can't find gears selector O rings measurements or parts numbers. Can someone have this information or show where i can find it. Thank you -
I get offer for 115eur this one. Now question, repair old one or buy this one. I bought from him pump unite and it works well. https://ebay.us/m/iDL5Hl -
Good morning, friends! Yesterday I removed the gear actuator. From the outside it looks fine, just a bit dirty. One of the pipes (the upper one) is moving/loose in its place, while the other one sits more firmly. Is that normal, or is it a problem? Now that I have the actuator in my hands, I’m thinking about what to do. To start disassembling it, I’d need spare parts like O-rings, etc. Unfortunately, there are no complete kits available, so I’d have to search and buy everything one by one. I can buy another actuator in fully working condition for €120–150, but it was removed from a Lupo. I read somewhere that they are the same, only the high-pressure pipes are a different length. Is that true? -
Thank you Mankmil! Will start with gears actuator -
Ok, this it is gaskets. Gaskets in pump unite, gaskets in gear selector? There is no kits to care all all unites. My pump is from another car and it not runned with ATF oil. Left clutch actuator and gears selector. You mean i need those two parts? -
Today i opened drivers door and pump doesn't start. Looks like it still have a good pressure from yesterday. Ignition ON,pump starts for maybe 15 sek and then it stopt. I hear at same time gear changed from N( car was in N from yesterday) to 1 gear.Sounds promising. Then i pushed brakes and old history came back. Pump starts immediately and won't stop. Car engine started in S, don't know when, gut gear now is in N and i can't engage to D or R. I stoped engine,switchen off and on ignition and pump now running all the time without a Stop. VCDS screenshots: Nr.1 when ignition was on, Nr.2. when Ignition, Nr. 3 Engine running. -
I checked O rings in old pump unite, they looks OK. I'm just not undertand why system was filed with not correct oil. There is no visible lekage, and system was not only refiled with ATF but there was no evidens off egsisting Green oil in a system. Will chech gearboz bults, maybe gearbox was removed. Car i bought from ownes son, and he don't know what it was with it. -
Yes, previous owner instead of green filed system with ATF. I replaced with correct oil and replaced pump unite. There is no visible leakage of oil and just need to guess that there is no internal leakage. Mankmil wrote many interesting things what i need to check. I just confirm, when i open a driver doors pump working about 15 sek then stops. When Ignition ON it almost never stop. I newer checked what is pressure in a hydraulic system because didn't know that possibility to do in VCDS. Today first i will do this. I don't think a clutch have mechanical problem, there was no strange sound or something strange from the clutch. Just after last test drive next day car won't to drive. -
Lupo 3L maybe you missed my previous comments. I have 3 pcs. pressure accumulators. One is new Febi with Mankmill adaptor (currently it is installed on a car). Another one is original with confirmed 4 gears changing before pump starts. Last was with a car when i bought and i don't know his condition. Just one very important moment what I missed when I too much concentrated on a clutch system. Car is always in neutral! Gears are not changing when I move to D or R. On the video you can see VCDS showing "selected gear is LG 3-4” and doesn’t change. Maybe clutch is working, just problem in a hydraulic system because is not creating working pressure? If YES, what part I need to change, clutch valve? What tests I need to do to recognize a problem. -
No, previous owner had this car only one year, and drive 5000km. That way i need to investigate or guess what i need to do. Now ii looks like tomorrow after work i need to put a car on thet lift and dismount a gearbox. I already contacted Mankmil ,but looks and ask about how to exchange old valvo to new one. Waiting answer -
Little of history: A2 is 2005 with milage 240 000km. I bought it two weeks ago. Previous owner told that car drive good,but when engine is warn,it won't start. This is indication of worn injectors gaskets and i replaced it. Can drives well, gears is changing smoothly. I never had before this car and can't compare with another. It was two problem left. One is turbo vastgate accurator not working and gear box hidtaulic pump starting after first gear change. When i checked hydraulic system, recognize that instead of green oil it was filet with red ATF. Don't know why. There was visibal leakage. I bought new Febi accumulator and adapter for it. Replaced correct oil and installed Febi. Did all adaptations. Car car drive,but pump still working almost constantly. I bought nother pump with confirmed working ( 4 gears change) original accumutor,but results is the same. Now after last test drive i got this situation where i explained early and in video -
Now looked to clutch leaver. Clutch cylinder moving it just les ten 10mm. I tried to puch it with bid metal stick, but it can't move . If it stuck,it stuck in very strange position. Maybe pump is running almost without a stop to trying create a pressure to move a leaver. My question is: how hard is to move clutch leaver to open a clutch? I think,a problem is with mechanical clutch parts and to be shure i need remove gearbox.
