Jonham45
    1.4 (AUA)
    Hamburg
Leistung von Jonham45
  1. Jonham45
    A2 Mechaniker
    Thanks for the advice so far guys. DonRon is going to have a look for me at the weekend as he is only a few km away from me. Thanks for the advice also on the TuV penalty Manni. Think Im definately in the time perimeter of Geld plus points though ! Thanks for the great tip about the Bosch Dienst '3Ltdi' might be using that one. Yes I have some codes. The ABS /EPC warnings kick in shortly after I start driving or sometimes even if cars just started , idling and I press brake pedal. Jon Mileage: 174540km-108454miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 036-906-034-APE.lbl Part No: 036 906 034 Q Component: MARELLI 4LV 3720 Coding: 00051 Shop #: WSC 63533 VCID: 204F3FC4A024939663-4B32 WAUZZZ8ZZ1N019500 AUZ7Z0Y1588331 1 Fault Found: 17961 - Barometric / Manifold Pressure Signals P1553 - 35-10 - Implausible Correlation - Intermittent Readiness: 0010 0001 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8Z0-907-379-MK20.lbl Part No: 8Z0 907 379 B Component: ESP 20 CAN V015 Coding: 10758 Shop #: WSC 02154 VCID: 479D8458654A84AEC2-4B00 1 Fault Found: 01314 - Engine Control Module 79-10 - Please Check Fault Codes - Intermittent ------------------------------------------------------------------------------
  2. Jonham45
    A2 Mechaniker
    Hi Manni. Thanks for your offer. Not sure when I could get it over to Ratzeburg and as it has no TuV I’m a bit worried that if I drive it over and it breaks down I’m going to get some trouble so I will try for something more local first . Thanks. Jon.
  3. Hallo Leute Könnte jemand einen erfahrenen A2-Mechaniker im Raum Hamburg-Pinneberg empfehlen, der einige bezahlte Arbeiten übernimmt, um die Fehler an meinem A2 1.4 2001-Benziner zu beheben und ihn durch den TÜV zu bringen? Das Auto steht seit ein paar Jahren, aber ich würde es wirklich gerne wieder zum Leben erwecken und wieder benutzen. Der TÜV hat den Abgastest nicht bestanden und verfügt über eine EPC/ABS-Warnung, die nach einer Minute Fahrt aufleuchtet. Ich habe alle Brems- und Handbremsseile gewechselt. Ich habe das Drosselklappengehäuse gereinigt und angepasst und die AGR geändert, konnte es aber nicht anpassen und habe die Batterie ausgetauscht. Aus Ratschlägen im britischen Forum weiß ich, dass meine Probleme viele Ursachen haben können, aber mir läuft im Moment die Zeit und die Geduld davon, also würde ich gerne jemanden bezahlen, der mir hilft, solange es nicht teurer wird, als sie wert ist. Es ist frustrierend, dass das Auto im Allgemeinen gut fährt. Vielen Dank für Ihre Ratschläge/Kontakte und entschuldigen Sie die Probleme mit Google Translate, da ich Engländer bin und meine geschriebenen Deutschkenntnisse nicht besonders gut sind. Beste grüße Jon
  4. Hi Daniel. I can also come to you tomorrow (Monday) in the morning if your free. Tuesday I can normally only come after 6 as I'm working but if that's the only time your free I'll finish early. My numbers 015118240195 . Maybe you can just send me an SMS with your address. Cheers for this. Will bring you a 6 pack beer ! Jon
  5. Perfect. I live in Halstenbek. Any chance you free Monday afternoon or one evening next week. Thanks a lot!
  6. Hi Guys. Hoping maybe someone on the forum who has diagnostic software Vag com or similar might be able to help me obtain the codes from my wife's A2? I'm British but living in Hamburg and look for an alternative to taking it to Audi. My spoken German is ok but written would be a problem so appreciate the chance to send my plea for help in English. Thanks if anyone can help or point me to a reasonable independent garage with the knowledge to help. Thanks for any help. Jon. Oh , it's the EPC and motor warning lights that come on and off ( mostly on).
