Hello. My abs light is on. Error 00283 - front left ABS Wheel Speed Sensor (G47) appears in VCDS 35-00 - - I replaced the hub and the abs sensor twice. I connected a new brown wire to the abs module (there was a problem with signal transmission). I did the vcds test --> block 01 --> wheel speed check. I took out the sensor and waved the magnet. Unfortunately, no reaction. I checked the sensor with a meter and it is between 1200 and 800 ohms. Can the abs module be so damaged that it cannot see only one sensor ?
