Community durchsuchen
Zeige Ergebnisse für die Tags "'engine conversion'".
  • Suche nach Tags
    Trenne mehrere Tags mit Kommata voneinander ab.
  • Suche Inhalte eines Autors
  • Bugs der neuen Forensoftware
  • News - Regeln - Impressum
    • Clubinfos - Boardregeln - Impressum
  • Allgemein
    • Allgemein
    • Verbraucherberatung
    • English language forum
    • Treffen
  • Rund um den A2
    • Technik
    • Ausstattungen & Umbauten
    • Pflege
  • Rastplatz
Ergebnisse finden in...
Suchtreffer enthalten ...
Erstellungsdatum
  • Beginn
    Ende
Zuletzt aktualisiert
  • Beginn
    Ende
Suchtreffer filtern nach ...
  • Beginn
    Ende
Gruppe
About Me
A2 Modell
Baujahr
Farbe
Sommerfelgen
Winterfelgen
Zusätzliche Felgen
Ausstattungspakete
Soundausstattung
Panoramaglasdach
Klimaanlage
Anhängerkupplung
Sonderaustattung
Hobbies
Beruf
Website
ICQ
AIM
Yahoo
MSN
Skype
Threema ID
1 Ergebnis gefunden
  1. Thought I’d share my 1.4 90hp engine conversion I purchased a 1.9 ARL engine which had low mileage 78,000 which I tore down and had the crank and Conrods lightened and balanced and bores checked and lightly honed. Reassembled with Ned shell bearings and piston rings , cylinder heads been fully ported and polished with completion valve guides and multi angle seats , GTB 1756vk conversion on one off stainless manifold with EGT sensor , completion mild race camshaft , unrated black hydraulic lifters , smf conversion with uprated clutch wearing a 02m six speed gearbox Cupra R brembos brake set up with vented rear discs , rear anti roll bar , monroe reflex dampers all round with weitec -25mm sports springs , seat sport fmic cut down to fit available space , fabia vrs radiator , Audi TT Quattro front hubs which widens the wheel base with adjustable top mounts to make changes to castor and camber angle , one off custom length driveshafts , lower crossmember reinforcement bar. Webasto , Audi TT coolant pump for webasto telestart as you can imagine there’s not much room left in my A2 engine bay and although a very very tight fit everything’s in and has clearance and allowing for engine and gearbox movement. To do list & retrofits wiring sideguard , fis , rear pdc , tow bar , headlamp washers and winter pack heated mirrors and screen washer jets front crash bar and fmic mounts
