nitro68
Alle erstellten Inhalte von nitro68
  1. nitro68
    Gearbox noise
    Just came from the dealer. Next week they drain the gearbox oil and check it on metal particles. If so, we see what further steps to take, if not, we leave it as it is.
  2. nitro68
    Gearbox noise
    Thanks for the reply. What worries me is the explanation of the dealer that this noise is "normal working noise" With my technical background I can't imagene that this noise is "normal". I ask myself "what could make this noise?" The gears? Don't think so, not after 70000km. Damaged bearing? This would be the only source of grinding noise in my opinion........... I will pass the dealer this afternoon and propose to drain the gearbox oil to check for debris. However, a noisy bearing doesn't have to give debris.........
  3. nitro68
    Gearbox noise
    Hi, My A2 1.4 petrol gearbox makes a grinding noise when it is running idle with the clutch pedal up. Dealer replaced the whole clutch under warranty, noise is still there. You can hear the noise clearly, start the engine, switch of everything that makes noise like radio, airco, etc. When I engage the clutch it is quiet again, clutch pedal up noise is back. So it is clearly comming from the gearbox! According the Audi dealer it is "working noise", completely normal. For me this is not acceptabel, there should not comming these kind of grinding noises from the gearbox! Anyone has the same experience? Does your gearbox making these noises during idle running? Thank you in advance! (getting desperate..... )
  4. Hallo, I try to finalize the einbau of an GRA of kufatec in a A2 of end 2005. Motor code BBY, 1.4 bensin. Everything is build in, but now I need to plug in the 4 wires with pre-crimped connector pins in the connector of the motorsteuergerat. I couldn't get the connector (left one) of the motorsteuergerat, locking device was shifted to his max but the connector did not release. Fingers still hurt..... Other options? Is there a scheme/drawing of this connector how the pin numbers are located? Blau pin 75 Rot Pin 57 Gelb Pin 38 Weiss Pin 76 Can anyone help me out? Vielen dank!
