GuruX
    1.4 Benz.
    Göteborg, Schweden
Leistung von GuruX
  1. I'm looking for the CAD file of the adapter, that bob26 made. I sent a message to him about it, but he doesn't have the file anymore. He did send it to someone here on the forum. Perhaps that someone still has the file and can send it to me?
  2. Yes, I used a relay. Took the controlling current from the left headlamp. As bret pointed out, the black and white cable on position 1 in the connector is the main beam. So I took the connector apart and soldered an extra wire to connector 1. The load current was taken from the generator. Here is a picture of the connector, I made for the english a2oc.net forum.
  3. Thank you for your advice guys. The lights are now fitted and working. I ended up stealing the 12V from the generator, by herr_tichys advice. Earth was connected to the earth point behind the left headlamp. Disabling them is a matter of disconnecting the fuse near the generator. The cables can be disconnected from the hood aswell, required for removing the bonnet. It's a bit of a hassle right now, I will be looking for a better plug. The LED bar is rated 120W and the small ones are rated 36W. I can say that the rating is probably wrong. I fitted a 10A fuse and it didn't blow. If the rating was correct, I would need a fuse with at least 13A. But hey, that's what you get for buying cheap stuff from China. Dipped beams: Main beams with spotlights: I'll take some pictures in daylight aswell to show what it really looks like.
  4. Hello Idler! Thank you! If the pictures are not available, try these links. imgur: the simple image sharer imgur: the simple image sharer imgur: the simple image sharer
  5. Hello German friends! I'm from Sweden and usually hang out at the English forum, a2oc.net Since I live in Sweden the winter is dark (and full of terrors) and extra high beam lights is useful. We also have less rules than Germany and I'm allowed legally to have them on my car as in the picture below. I have fitted my new led lights to my car, but haven't done the electrics yet. I will wire them up with a relay to have them switch on together with the high beam (fernschein). But I need somewhere to get power. Is there a good place to get a 12V feed in the engine compartment? I also need to hook the relay up to the original man beam, where is this done easiest? You can answer in German, but English is preferred. Reinforced fresh air box. The lights. The big one is a spotlight with narrow beam. The smaller ones are flood lights.
