mrbizzy
Alle erstellten Inhalte von mrbizzy
A2 1.2tdi gear selector not pushing down to 3rd, 4th and 5th gears.
mrbizzy antwortete auf mrbizzy's Thema in English language forum
Oh yes, i have 2 spare gangstellers. it was cheaper to buy those complete (used) than to buy the potentiometers on them separately, when i needed them. Solenoid looked normal. i did not bother to test it when it was replaced already. had to move on. While my A2 was waiting for me to start fixing it again, mouse had gotten in and chewed on the micro switch cables that are in the gear selector, so that for sure was giving errors, now soldered those and seems ok. BUT the gear selector potentiometer might be causing problems. as it does show T-MI when it should T-0. so it is out of range. now i did not compare the voltage to the wiki but looked at the textual value in diagnostic. I do not know (yet) if those values are depending on basic setting score or not. Will compare voltage with tables tomorrow. REAR lights in step 5 - working fine! I do follow the adjustment steps, yes. Have done basic setting many MANY times and only few of them were success in the past so i am familiar with the procedure. Whole front of the car is off the ground as i was replacing the gearbox. so no need to lift one wheel. Now got to check this, but i was "adjusting" the lower potentiometers angle of arm to sensor tooth on gangsteller. because the measured reading was out of range and i thought that was causing RTFM. maybe i messed up something there. Should the gear reading in speedo correspond to the real shifted gears during basic setting? sometimes it does not look correct in the dashboard. -
Update2: So i figured out which solenoid is responsible for pushing down and decided to replace it. It took much less time than i anticipated and it was worth it as now it is working correctly and during the basic setting all the gears are shifted in correct order. But still getting RTFM 12. i suspect it is because of fail reading from gear select lever potentiometer so will take a look at that one now. -
Update: So i measured the resistance of all 4 solenoids and they are in check by the WIKI. Also i did switch places both upper solenoid plugs and test the basic setting and even then gangsteller was only pulling up never pushing down. So that would lead me to think that all is working except the gangsteller and that should be removed and replaced or repaired. BUT there is one small thing that could be worth noting - the gear selector lever potentiometer when in E or Tiptronic position is reporting that it is actually in T-Mi position, so not a correct reading. i tried to attempt the basic setting while supporting the selector a bit upwards in a steady position, but the gangsteller still was not pushing downwards. It is cold outside, where i work on the car, and if needed will have to remove that gangsteller but before i do that i will wait a bit as maybe there is another thing to check or test before blaming the gangsteller. So if you have ny suggestion please share it with me. -
thank you for responding. i am certain that the hoses are connected fine because the gear lever is being pulled upwards and pushed in and out so pressure is ok. Rear light gets activated just fine, but because it is not pushing downwards even 2 times slides into R. And i already used those WIKI pages before looking for help here. So will have to pay closer attention to N286 and N287. i hope it is one of them gone and not the ECU as i have a few spare solenoids laying around. I saw that i can test them with resistance, so that will be my tomorrows job then. -
I hope you will not disqualify my post because of language, but yes, as you can see it is English. Where else to look for help with Audi if not with Germans... So i am on it again - to get my A2 3L on the road, the last try. Had to repair gearbox and ended up replacing with a good one. now all put together and i am stuck at basic settings. ECU does not throw any errors, measurements from pots are +/- in range, fluid in system is ok level and the accumulator holds pressure, also the battery has a charger connected and is a fresh one. The problem is that during basic setting the gear selector (gangsteller) does not push downwards and as i understand that is where the gears nr 3,4 and 5 are. so RTFM 12 is a normal outcome. I can switch all gears by hand , no extra resistance or anything on the gearbox side that would prevent that. I tried to switch places the upper solenoid plugs N286 and N287 still not pushing downwards. Then unplugging one of the lower ones N285 then no gear selection happens at all. The diagnostic reports equal Ampers for both N284 and N285 solenoids. So i suspect that either could be a cable to solenoid or solenoid itself that is the issue. Next i would suspect the gangsteller itself, but i had refurbished it the previous time i tried to get that car on road and had not a chance to drive more than 100km before the fork inside the gearbox snapped and left me with a useless audi. i would think the gangsteller is ok, but who knows. And then if those two are not the reasons i would suspect the ECU itself. now, can you knowledgeable and kind people PLEASE help me to get on track and find the issue while i have the inspiration for it. And if you know, is one of those 4 solenoids responsible for down-push movement? if you know, please share. Peace and strength to you all. MrBizzy Moderator: Moved to english sub-forum.
hei c_a. great to hear from you. The sleeve is intact, just as is the clutch disk and bearing. Actuator was ok when i did adaptation just before that short ride of ca 45km. Also now i can not test it as the gearbox is off the engine already. hei c_a. great to hear from you. The sleeve is intact, just as is the clutch disk and bearing. Actuator was ok when i did adaptation just before that short ride of ca 45km. Also now i can not test it as the gearbox is off the engine already.
Dear audi fellows in Germany, i understand this is German site, and do not mean to come rude but i simply can not write German so i will post in English. i hope it will not upset too many of you and maybe i will get some answer in the end. so, to the point. Since i bought my A2 1.2TDi many years ago already and it was my dream car back then. I still like the car as a model and am fascinated by the engine but my exact car has been still for most of the time i owned it. So last summer i did overhaul the gear actuator and adjusted all fine. in test drives was working fine. so i took it with the smile on my face to the yearly control station so i can put it back on road and what do you know, 5 km before the control station i am on the side of the road again with blinkers. Damn! Symptom - could not take off. as soon the 1st gear "was engaged" car stalled. it was not smooth, it was like switching into gear without clutch at all, i guess that was exactly what was going on. And besides that i heard a rumbling sound while the engine was running in neutral, so i made a conclusion that the clutch bearing has had it and towed it home. Now, i did not touch it through the winter as i do not have a warm garage, but this week have managed to remove the gear for inspection, and the clutch bearing and clutch itself looks very good. At this point i need a suggestion about what next step to consider. I am in Latvia, and that is one reason why i have to do it myself as few times with audi dealer was very disappointing and independent garages can only brake it instead of fixinig it (proven!) and most of them don't even touch it. I have tools, patience and have repaired my cars enough to try and get it back on road again for summer, but i am clueless what to do next with this situation. please, wise and experienced people, pour some of your knowledge on me. Moderator: Moved to english language forum.
G240 potentiometer on my A2 3L is faulty and needs to be replaced it seems like a simple task - 2 bolts and basic setting BUT i have spent hours searching for the part numbers for this little poti with no luck. Please share a part number or knowledge where to buy one if you know.
Hello. I have this A2 wih 1.2tdi engine for few weeks now. very satisfied with the car except one problem that should be sorted. While the car is relatively cold all goes well but on a highway it reaches only 100-105km/h in the 5th gear and no further acceleration. so the rpm sits little above 2000 and the consumption is displayed as 4l/100km. Even when it shifts down to 4th gear it does not ad much and speed rises to 110km/h not more. That is annoying, especially because here are no recognized A2 (especially 1.2tdi) specialists who could i trust to fix it. But that is not all, unfortunately. When it gets warmer, about 30min driving, the 5th gear starts to "pop-out" and sometimes releasing acceleration pedal and pressing again helps to activate the gear, but sometimes it requires to stop and start the engine to gain the drive-ability. What happens is that gear selection shows E or D but no gear numbers are displayed and no gear is selected. Also accelerator pedal is sometimes active but sometimes dead as the engine does not react on it any more. When this happens the only way to drive further is to manually switch gears and leave in 4th. then all is ok and car runs smooth and quiet. Also i noticed that when this happened and i tried to keep driving on and on there started a loud noise from gearbox in the first gear, then in the second and later in all four gears. but after a easy driving in 4th gear on a highway with some 30min stop in the middle the sound disappeared. Any suggestions where to start looking for a fault/solution? Casper from Latvia
Hello Dear 3L-ers - or in short FRIENDS I have owned a Lupo 3L in the past in around 2006 and loved the car. but had to sell it due to the well-known issue with gear shifting. Now in the recent week i have bought myself a Lupo 3L and Audi A2 1.2TDi again and am willing to choose one that will stay with me. the other one will be sold further on. I have read many times that Lupo is converted to manual gear shift and seems doable without a too big expense but i can not find info on the same conversion for the A2 model. Therefore i start my quest by asking you - do you know that it is a similar procedure for the A2 as it is for Lupo? maybe someone who has already done this can share the experience? Right now i have a slight problem with A2 - a strange sound from gearbox when engine is warm and driving - i think (and hope) it is a clutch bearing. Also A2 has a better fuel consuption compared to Lupo. A2 is about 3 ,3 Liters while Lupo shows around 4,5 with same driving. will check lupos air filter today, maybe that needs to be replaced. By the way, i write from Latvia, and believe me there is not much of these cars in here as they are not popular at all. therefore i search for advice with you friends. hope to hear back from you, regards, Casper
