TitusM
Alle erstellten Inhalte von TitusM
  1. When I did the test last night I found that the consumption is indeed close to you specification. 80 ->3.x 100/110 ->4.x 130 and above ->4.5 -in my short test. In the graph you can see I was "pushing to the metal" it almost all the time (when i was no afraid of the wet conditions and steep curves). It is a steep uphill on this highway. I have to test it with the golf but I am sure it struggles to accelerate over 150 uphill. Anyhow when i was going uphill on the way home (like the last 4/5 km) the consumption jumped 1L. So from the total of ~ 50km the last 5 km were very demanding. So i tend to believe i am in a special case...when the road itself is "high consumption". Yes. Good catch. The consumption is actually a little bit higher when doing the calculations with full tank->full tank.
  2. Temperature of engine and wheel when I arrived home from the run above: Turbo intake temperature when I arrived home. It was a little hard to get but this was after 5 or 6 minutes of idle. engine temperatures from above. - the circle in the middle is the oil cap. front wheel disc temperature (same on both sides) rear drum temperature (on the other side 17):
  3. yeeees...I do that pretty often. before the long update from this evening i did a reset again.
  4. UPDATE and lots of details: Here are the logs for this evening run. I did a log with advanced measurements. Please tell me what you think. You can find the logs here directly as graph (or csv in attachment): https://log.tunezilla.com/search?part_number=045 906 019 D ->Click "view" on the logs from 13-10-2020 and with lots of groups. LOG-01-011-048-061-07C-105-112-137-152_city_eco.CSVLOG-01-011-048-061-07C-105-112-137-152_NONeco_city.CSVLOG-01-011-048-061-07C-105-112-137-152_external_eco.CSV the log files: 1)city_Eco - in the city with eco mode on 2)external - eco ->out of the city with eco on - and ~15km highway. The highway is not flat - i had a hard time reaching 130 uphill but after that i could reach the 160 limiter. 3)city _non eco -uphill home at the end (when going uphill the consumption jumped from ~4.5 to ~5.3 when I arrived home) Findings so far: -> cylinder deviation: It seems that cylinder 3 is a little off compared to the other 2 - it reached almost 1 at a certain point so it might be good to clean the injectors. Logging a run like this is useful because you can see that injector deviation can vary pretty much. it is very possible that cyl3 injector has issues. I found a max deviation of >0.9 compared to the others. When idle or short run this was not visible. boost vs speed seem fine: boost pressure vs intake temperature vs speed: (it could use better intercooler for uphill - the temperature is quite high at the end)
  5. @clekilein hmm good question. On highway it struggles to reach 130 in eco mode. 160km in eco mode with kickdown or not? The truth is I did not drive one of those before buying it. It was just a dream of mine:)...that now costed me more than the other car (and I still have to fix stuff). I owned a 1.4 fsi Lupo with the same gearbox so I knew what to expect and i had experience with bad actuator and clutch and etc. Right now I want to get out an test it out of the city. I will do a vcds log with speed and consumption and maybe boost. Any hints? What should be the consumption at 130km/h highway speed and how hard should it be to maintain this speed? Hooking up the vcds and going for a drive. I hope it can log such a long way.
  6. @DerWeißeA2 I changed the fuel filter myself:) this summer. It is surely new. I used MAN filter. About the diesel return line - any idea how to test?
  7. Can the diesel return line to the diesel tank be restricted and therefore have a greater consumption? Is this even a valid question?
  8. PCV CCV Valve? Is this breather important in fuel economy? I see some oil around the breather pipe. Does this mean that there is something wrong with it? https://forums.tdiclub.com/index.php?threads/diesels-do-not-have-pcv-valves.10234/ "Just thought I'd mention that the crankcase ventillation systems employed on diesels are not PCV (Positive Crankcase Ventillation) systems. They are Closed Crankcase Ventillation (CCV) systems."
  9. tunezilla has also the groups listed: https://log.tunezilla.com/groups?partNumber=045 906 019 D You can scroll to see all the groups (in case the graph shows something that you do not know where it comes from).
  10. Hi @Phoenix A2, I guess it is not. You would have to use the colors. Try the second one. It is much better. You can "hide" the colors you are not interested (press the color label). The first should do the same but it does not work as well. https://log.tunezilla.com/ example (I use only 3 from all lines - the rest are "cut off" when I press it.). This way you can see only what you are interested in in relation to other graphs: This is the full graph from the above (this is harder to read than the above one):
  11. https://log.tunezilla.com/ This is much better. Zoom works better and loads the file better. "Scroll" zoom works nice too. If you click on a label it does not plot that particular value. It becomes "cut out" and disappears from graph. And it has HISTORY :D:D...awesome. You can see the graphs for other engines like yours. You can access the history by pressing: "Find more logs or groups for the part number 045 906 019 D" https://log.tunezilla.com/search?part_number=045 906 019 D
  12. Also I did a vcds log when I went to pick up the kids. Downhill and uphill. It was raining so I was a little slower than usual. The dashboard sais now 6. You can plot the csv log here (all are free): https://kiksu.net/vcds-graph/ or https://forums.tdiclub.com/index.php?threads/vag-com-plotting-software.201161/ or https://www.logview.net/download-logview/ These were the values I could log now. If you have ideas I can log other groups. @Phoenix A2, @DerWeißeA2, @Romulus any ideeas what else to log? I own a vagcom so i can do readings whenever i have time. Back where i started....6.9Liters: The rubbing brake drum seems to not have had any influence (only better braking). The car does not feel underpowered like when a vacuum hose is out. If i disconnect the main vacuum line i can not go uphill with more than 50-60 km/h, I tested that. LOG-01-001-007-015.CSV
  13. updates: I had a little time today (after I changed the engine mounts) and did some print screens: What I do not understand is no: 023. It looks like it is way off but I think it might be a vcds error. Group 13 goes to 0.4 on cylinder 3 sometimes but this is in limits. I am not sure how to read g72 and g62 (it looks ok). I changed g62 this summer. - Schwabe i do not see the g2 you mentioned.
  14. No welding needed: You can use a 3mm thick sheet metal or washer to hold down the iron part. Use a washer under the sheet metal to keep things straight. 45mm distance between holes if you want to attach to the existing hole (as in picture) BUT is NOT needed. A wide thick washer on top is enough. (keep the 3mm thickness in mind) USE part no.: FEBI BILSTEIN 23882 price: i paid 73 euros from: VW Fox, VW Polo IV, SKODA Roomster, SKODA Fabia II, SKODA Fabia I, SEAT Ibiza IV, SEAT Cordoba III oem codes: 6Q0 199 167 CA SEAT 6Q0 199 167 CQ SEAT 6Q0 199 167 DH SEAT Admin: Unnütze Links entfernt. Zugangsdaten erforderlich. I forgot about Webasto and had to cut the excess metal :))). The original was not totally broken but there is a significant difference in engine start and vibrations. One more support to go. It arrives tomorrow. I will keep you posted. next one will be: LEMFOERDER 29978 01 - I will try to change the "rubber heart" of it. -> Pictures to come.
  15. Swap the end and grind if needed. Code: LEMFOERDER 36324 01 price: I paid ~35 euro from: Audi A1, SEAT Ibiza IV,SEAT Ibiza V,Polo IV, Polo V oem codes: 6Q0 199 851 AA AUDI 6Q0 199 851 AC AUDI 6Q0 199 851 AP AUDI Admin: Unnütze Links entfernt. Zugangsdaten erforderlich.
  16. This should be an interesting alternative:
  17. At Idle engine in VAGCOM it says: 0.3/0.4 liters
  18. personally i will try this: LEMFOERDER 36324 01 ->under FEBI BILSTEIN 23882 -> right side - needs cut and welding when you say this: The gearbox bearing can easily be replaced with the one from the Polo, something I have already done - which one do you mean? do you have a part number for us? google translate: wenn du das sagst: Das Getriebelager kann leicht durch das des Polo ersetzt werden, was ich bereits getan habe - welches meinst du? Haben Sie eine Teilenummer für uns? this also works on Any engine: 8Z0199555S
  19. google translate: Was ist mit den anderen 2 Reittieren? irgendwelche Alternativen? Die 2 Reittiere kosten heute> 500 Euro --------------- what about the other 2 mounts? any alternatives? the 2 mounts cost today >500euros
  20. Any ideea what other VCDS measurements to log? (I posted a log with boost levels - I also checked maf and injectors). They all seem fine except one interesting thing: When the car is in neutral and i read the boost levels(actual vs specified) it seems way off. When I drive the car this values are very close to each other. I am trying to rule out the boost part without dismantling it.
  21. Update: I reopened the rear brake drums and one of the pistons was stuck. (I ordered new rear brake pads and everything) Managed to unlock the piston. The consumption is now "back" around 5.5 ->6 liters on the same route. So good catch with the brakes:) Thanks for the guys who suggested. That wheel was not stuck but the brake was rubbing. I still have to dig forward to find the big culprit.
  22. When stationed there is no smoke. On hard acceleration there is very little black smoke. I will have to check the momentary consumption for flat road. Interesting idea. I must find a flat area:)...I am surrounded by hills. vcds: Block 13 is 0.20 maximum for one injector - very close to 0 most of them.
  23. I will have to take the turbocharger apart it seems. on the sensors it seems fine (i attached a graph with boost level -actual vs specified and they are very close) The egr was blocked on my car - i discovered that when i replaced the vacuum lines - the vacuum line that went to egr was blocked. I did check and replaces all the vacuum hoses. Do you have any idea what is the normal vacuum value for this engine? i am not sure how much it should be. The gauge i have shows ~ -0.7 to -0.8 bar of vacuum.
  24. Yep...the car still has original software. I will check the intake pipe of the filter box. The filter is new <3 months
  25. @DerWeißeA2 When the car was lifted on elevator the breaks were free. I hate the way it brakes (I changed a good pair of brake pads on front because they were awful - changed from textar to ate and now it brakes a little bit better). The rear drums also have no restriction. All filters are changed - including fuel filter. (usually I change the filters with the oil - at 15k not 30k) Wheel brake lines are changed also - front and back. @Schwabe : Charge air - or boost seems good. In the graph you can see that the actual boost vs specified boost are very close. This means that the boost is fine. I have to check the G2 and the G62. Any idea what group these are in vcds? I changed only one temperature sensor the one on top of the engine. Is there another one? I checked the brakes with a thermal camera. Usually when I arrive at home the front disk brakes are around 90degrees Celsius but this is due to braking. The drums are somewhere around 40degrees. I will check the brakes again but this consumption was almost the same before all this. Today I did 120 km on rural roads - quite some hills to climb. I got 5.6liters/100km. I would have expected at least somewhere under 5liters but the car was "full" - 2 extra passages. I get almost the same consumption with my golf 6 1.6 tdi as I do with the audi on the open road. Audi is around 5.6Liters (this is for Golf 1.6 tdi on highway ~135km/h). The golf consumes usually around 6.4 Liters on the open road but very hard driving (almost race style:). As a comparison: The golf dinks around 9Liters - the Audi drinks 6.9 on the same road (on the way home - uphill). Golf reaches ~140km/h maximum -> Audi around 115km/h maximum. I am starting to believe that the road home might be to heavy on the machines. I will check turbo and vacuum and...fuel system again...and why not the brakes too. What I never checked...is the CAT - maybe it is clogged although the evac seems free. The "smoke" comes out pretty strong from the tail pipe. But a I expect a clogged cat to make the car slower and it does not seem the case.
