Beiträge erstellt von clekilein
Da gibt sein ellenlanges Thema hier im Forum dazu.
(!) ABS ASR Problem
vor einer Stunde schrieb TitusM:
Any hints? What should be the consumption at 130km/h highway speed and how hard should it be to maintain this speed?
Maintaining 130 shouldnt be a problem at all, there are not many hills on the autobahn that can push you below 130
roughly it should be like this:
80 --> 2.x l
100/110 --> 3.0 l
130 --> 4 l
150 --> 5 l
160 --> 5.6 l
While sailing at 100km/h it should show you 0.5 l/100 km or 1.0l at sailing 50 km/h
(Sometimes the display does need some time - it shows you a calculated short term average)
A good engine can easily drive 160 (tachometer) in eco mode w/ a fuel consumption less than max in eco mode.
(No "Kickdown" ofc - this stops the ECO mode)
i dont know max fuel exactly in 5th gear but its around 6.X something.
More it cant consume in 5th gear due to the limit maps.
When reaching 160 it should throttle a bit.
A bad engine struggles with 160 a bit, but less than 140 is totally abnormal.
I have 2 ANY A2, one throttles at 160 the other struggles w/ 160.
The second one has always around 0.5l average fuel consumption more.
I checked many things, cleaned the turbo, oil change, new tires, checking the brakes, injectors... but i had to realize that one engine is a bit better in combustion efficiency.
So long story short;
either something is getting hot in/at your car while driving (brakes, tires, gear, ...) or the efficiency of your engine is gone and this probably results in a new/other engine
One Question @Titus,
How fast does your car drive in ECO Mode V-Max?
Does it really drives upt to 160km/h until it cuts off in eco mode?
Das Jaipurrot ist schon ganz OK, gefällt mir besser als die meisten anderen Farben beim A2. Sowas ähnliches gibts im Moment auch beim Q2, nennt sich "Korallenorange Metallic"
Die oben gezeigte, polierte Kugel ist natürlich schon etwas Besonders vom Zustand des Lackes.
vor 56 Minuten schrieb MustPunish:
...Einschätzung ist aber, dass 2.000 € für diese Schäden extrem hoch angesetzt ist...
das befürchte ich zwar auch, aber somit haben alle schon mal ´ne Hausnummer, dass er nicht für 500€ weggehen wird.
Meine Überführungsfahrt ist schief gegangen, anbei das Resultat:
https://suchen.mobile.de/fahrzeuge/details.html?id=301731035
Bitte fragt noch nicht nach einzelnen Filetstückchen von dem Auto, mir wäre ein Komplettverkauf am liebsten.
Beim Preis signalisiere ich Verhandlungsspielraum
Moderator:
Preis in Mobile ist mit 1.999 Euro angesetzt.
Hallo in die Runde,
Die Überführungsfahrt von meiner neuen Kugel ist leider total in die Hose gegangen. Will jemand die Kiste im ganzen haben?
Notfalls muss ich die Kiste schlachten, aber wirklich lust habe ich nicht.
- 6
vor 22 Stunden schrieb Trizz:
Wurde da neulich erst auch eines besseren belehrt:
A2 gabs entweder mit Klimaautomatik oder "mit ohne" Klima (Heizung mit Drehknäufen), letztere hatten die Nacktfrosch/Hardcore-3L bzw. 1.2er.
Trizz
Das stimmt nicht so ganz,
es gab den D4 - der hatte eine nur extrem eingeschränkte Aufpreisliste --> keine Klima, Servo und umklappbare Sitze etc. möglich. --> 2.99 l/ 100km Normverbrauch
und es gab den Euro 3 - der hatte die normale 1.2er Aufpreisliste, wo man das meiste aus dem A2 Sortiment ankreuzen konnte (4x efh und Oss waren da trotzdem nicht drauf) zur Verfügung, das heißt aber nicht, dass man da immer ´ne Klima hat! Ich besitze so einen A2.
Ich persönlich suche noch zu meiner "Sammlung" einen komplett nackten, also ohne Servo, ohne Klima und ohne klappbare Sitze und mit echten 2.99 l Normverbrauch.
Wenns mir im Sommer zu heiß ist, ist mir aber ein Auto mit Klima aber lieber.
Kleine Geschichte von mir, geht aber eher um: wann macht der Motor aus.
habe einen 1.2er der ständig, bei jeder Gelegenheit, den Motor ausmacht. Der hat ´ne neue 90Ah Batterie. Der Anlasser läuft aber mittlerweile bei Kälte etwas nach.
Mein anderer 1.2er macht den Motor nur in 2 von 10 Fällen aus.
Der zweite braucht paar Sekunden nach dem losfahren bis die Batterielampe aus ist und hat eine der ältesten Autobatterien von ständig benutzen Autos in Deutschland. Nämlich noch die erste aus dem Jahr 2000 (und das bei ner start/stopp Karre mit 350.000 km). Außerdem läuft die Hydraulikpumpe beim Runterschalten relativ oft. Aber noch nicht ungesund oft.
Höchste Start/Stop anteile erreicht die Kiste nach Autobahnetappen und manuellem schalten vor der Ampelankunft um den Druckverbrauch zu reduzieren. Wenn dann die Hydraulikpumpe vorm anhalten nicht angesprungen ist, geht er auch brav in den Start/Stopp.
Wenn ich jetzt von meinen Erfahrungen auf andere schließe, empfehle ich eher die elektrische Seite, wenn es um das "Ausgeh-Verhalten" geht.
Bei haben unter meiner Regie noch NIE es nicht geschafft wieder den Motor zu Starten.
Wenn die Kiste trotz neuer Batterie und Kabel zum Anlasser nicht anspringen will, empfehle ich bei den mechanischen Dingen nachzugucken.
Kannst Du mal ein Video machen? Es erscheint mir wichtig, zu erkennen Wann/Wie/Wo er wieder ausgeht beim Startversuch. GGF ist es was völlig anderes.
Gestern A9 Richtung Leipzig aus Norden:
grüße an den Mintgrünen 3l, den ich mit meinem Atlantikblauen 3l überholte.
Bei FFB ist das genauso!
vor 2 Minuten schrieb Mankmil:
...Du fährst bis heute meinen allerersten Prototypen, bei dem ich selbst nicht mutig genug war, das Ding im Alltag zu testen.
Naja, jetzt stellst Du dein Licht ganz schön unter den Schemel, soweit ich mich erinnern kann wolltest Du nicht bis zur Saison warten...
Am 13.2.2018 um 05:54 schrieb Mankmil:
, gerade weil einige schon seit bald 3 Jahren damit fahren. Ich selber habe schon 25 und 12tkm in meinen beiden A2 mit dem Hall-KNZ abgespult.
Ich habe meinen Freiherrn seit exakt zwei Jahren und bin damit kurz davor ins dritte jahr mit deinem KNZ zu gehen.
Könnten ca. 60.000 km mit KNZmHS sein. Letze GGE mit Einstellung des KNZmHS? ca. 50.000 km her
h1 am a2?
ich hab hier sogar ein paar warmweiße H7 LEDs gefunden
Wahrscheinlich müsste man einen Satz kaltweiß und einen Satz Warmweiß kaufen, umschrauben/löten/kleben und hätte dann am Ende das "perfekte" Licht.
GGE kann auch bedeuten, dass er dann nicht mehr selber in die Werkstatt fahren kann, oder ein Austausch Getriebesteuergerät braucht, damit er interimsmäßig wieder vom Platz kommt.
Ich schraube immer ERST rum und mache DANN die GGE. Sonst bekommst Du nur sowas wie ein RFTM12 und dein Auto zeigt dir den Stinkefinger.
Von den meisten LEDs gibt es ja 3 Varianten: tageslicht, kalt und warmweiß.
toll wäre es, wenn man H7 warmweiß LEDs kaufen könnte. Mehr licht, "normale" Farbe.
da lobe ich mir meine beiden 1.2er
gibts schon updates zum weißschimmelA2?
bin ich jetzt höchstbietender? kriege ich hauslieferung?
hätte jetzt schon lust auf den weißschimmel
käsea2 -
achja, bitte mal die fenster runter machen, sonst wächst der innen noch so zu, dass man nicht mehr ins auto einsteigen kann.
Also ich steh voll auf Edelschimmel.
ich biete 500
Der Heckspoiler ist zu kurz.
[1.2 TDI ANY] Wo Druckspeicher günstig kaufen?
in Technik
Es gibt keine Speicher mehr zu kaufen?
