New finding, when I'm trying to start it in Parking mode in the display I see 5 .... it means it is in 5th gear now? maybe that is why it is not allowing to start it? but the car is rolling when I push it. So it is not in the 5th gear it only thinks so
tested it woks, it even pulled the clutch when I did the test.... so what else? maybe this?
http://wiki.ross-tech.com/wiki/index.php/5-Speed_Electronic_Manual_Transmission_(085)
how to check that solenoid valve for clutch that I was changing the seals? those green leads are somehow moving back and forth. Maybe I pulled them at some point and broke the connection?
Yes it runs and stops when the system is pressurized as usual.
but for example I cant even change gears in triptronic mode with engine off, but I used to do that when I was checking the accumulator.
Hallo Freunde
I have changed all the seals on the pipes but now I realized that it is leaking from another place and I didn't see anyone having such a problem. Please look at the picture. It is leaking from behind of this sensor (the big one in the middle) or what ever it is. But I don't understand how to remove it and see if there is any seal behind. it is turning freely but has no thread so that I could twist it out like some bolt.
Bitte hilfen sie mir
Now I'm replacing the seals on the ends of those pipe, bet now I wonder which goes where, there are three terminals on the pump P T K... where do I connect blue one and where the white one? Yellow one is in the middle for sure
we are filling it in as we lose the oil, when we lose it the reservoir becomes empty and the gears stop changing. Then we fill it up and the box works again.
If I loosen the bomb oil drips from under it.
