nuttinnew
Beiträge erstellt von nuttinnew
I may have found another way of getting there with accomodation;
I can get a brand new US 2008 spec RNS-E for a good price but are there any problems using it in Europe (radio frequencies usw)?
It's probably cheap enough to make me not worry about holding for a 2010 spec but pointless if it won't work correctly.
Thanks
There was a standard Veyron there also that got taken out for a few laps quick enough to get the brakes rather hot
A very big thank you to Shadout (& Herr Tichy's support)
A lot of work, a lot of hospitality and a much easier drive home.
Thank you very much
A random pic from the weekend;
I always am
Pretty please....with a cherry on the top
Happy Birthday
Can anyone complete my gra for me please?
The switch & wiring is present, the + & msg wires need to be connected and it needs to be activated.
I'm going from Calais to the Nurburgring on Friday, returning on Sunday.
Is anyone on the route willing to do it (euros will obviously and willing be involved ) ?
Danke
Well spotted.
It does look damaged doesn't it:(
Flights to Helsinki aren't so bad 8)
Ooh 8)
I'm going to the Nordschleife next weekend so I would be able to collect 8)
Max axle loads for my 1.4 benz A2 SE with OSS, Bose, rear electric windows, klima, 34l
va 745 kg
ha 740kg
Fox 1.4 bj2006
va 830kg
ha 790kg
Hmmm, maybe the fronts would be suited to an A2 tdi.
I'll have to get axle loadings for tdi, fsi and 42l ha also.
If only the fronts were as easy to change as the rears
How do G22 springs and dampers differ from G07?
I see they're listed with longer bumpstops so I'm guessing they're softer and worth changing to, using something like B4 to avoid elking.
Something I'm curious about is the standard damping on Foxes; the front springs on my A2 are also listed to fit a Fox and having driven a few Foxes I'd be happy to have my A2 ride and handle like one so I'd thought about using standard Fox dampers but they're 70kg heavier axle loading so will probably be too firm in bump for the A2 and not solve the problem.
Hmm!
Do FSDs raising the front effectively make the spring rates higher and is that why benz standard Spidans are suggested for tdis to keep standard ride height? If so I guess the ones for a 1.4 enz you'd want base spec ones (no OSS/klima/Bose etc).
Aye Bret, trying to do the same thing I did last time when the camera had stopped recording; the last time it turned round to face the sun just as the lyric 'in the sunshine'. It was accidental timing but perfect. This time was a slightly different line and it didn't pivot around the front axle, reminding me very quickly I was 2400km from home.
Oh, I've since found out the front subframe wasn't mounted straight, part of the reason it was handling oddly (beforehand:D). I thinks it's a left inner driveshaft joint causing other problems, will hopefully replace this weekend and find out.
Thomas...and he still went on to 300k km :cool:
Danke
The wires to the msg, do you just remove the pins in there and replace with the gra wiring? I am stupid, I stumble (still) at this point
I'm trying to work out if I can afford/fit it in; I would say I'm spending too much on holidays but if I had more I'd spend it on the same
I'll have a look at flying/renting, see what that's like.
Jahrestreffen 2012 - diskussionsthread
in Jahrestreffen
I'm there in August, maybe not in the A2 though.
Pretty much everywhere is 1000-1200km for me.
I don't think I'll have enough holiday or money to do everything
