TitusM
A2 Modell
1.2 TDI (ANY)
Baujahr
2002
Sommerfelgen
14" Alu-Schmiedeleichtbauräder
Winterfelgen
Panoramaglasdach
nein
Klimaanlage
ja
Anhängerkupplung
Sonderaustattung
Cluj-Napoca
1.796 Profilaufrufe
Leistung von TitusM
Anleitung: Trommelbremsen hinten auf Scheibenbremsen umbauen
TitusM antwortete auf A2TDI's Thema in Ausstattungen & Umbauten
https://www.lupogtimotorsport.de/anleitungen/ha-4x100-239x9/ 6n2 conversion here. Easier than using the adaptor plate. Did anyone try this easier idea? This would work for 1.2 tdi because of 4 hole discs. Google translate: 6N2-Umbau hier. Einfacher als mit der Adapterplatte. Hat jemand diese einfachere Lösung schon ausprobiert? Das würde beim 1.2 TDI wegen der 4-Loch-Bremsscheiben funktionieren.- 153 Antworten
- anleitung
- hinterachse
(und 3 weitere)
[1.2 TDI ANY] - oil temp/level sensor - 420907660 - compatible with - 045907660B ?
TitusM antwortete auf TitusM's Thema in English language forum
Just make sure you have the orings on. Mine came without the dipstick o-ring. If you do not install a dipstick oil you will have an air leak there and possibly some small oil leak. I detected mine only when i put the smoke machine on the car. The aliexpress version arrived also. I did not have time to test it. It has no codes written on it of any kind. The construction seems fine. -
Upgrading window switches. Early A2 to later A2 / A3 8P...
TitusM antwortete auf VETRA's Thema in English language forum
Do you have the part numbers for the new buttons? I am interested in replacing the driver's side but i do not know exactly what part to buy. Also can you do something about the photos? They are not visible in the post. Thank you. -
That might be -- the audi oem version. It is even annoying sometimes that it raises the low oil level warning but when i check the dip stick it is ok. It is related to that switch in the bonnet that resets the oil level only. -
IT WILL... There will be a new error: LOW OIL LEVEL for sure. I tested and that is what is shows. If there is no oil to actually set the level. It is a oil level sensor...if there is no oil there is no medium to make contact on the film that is in the pictures -- hence: LOW LEVEL warning appears instead of sensor error. -
But you need to install it in such a way so it would not trigger "low oil level" alert. Unfortunately is not that easy in this case but you could somehow get a normal oil sensor and make a contact on the level circuit so it does not trigger the error. This could work indeed for some people. -
Do they stop the error in the dashboard? in fact that is the most annoying part. If the error in the dashboard disappears it's worth it. It looks like the thinner version does not have minimum level detection. The original has a small strip at the end that looks like it would trigger when the minimum is met. You have to be careful to read the oil level like any other normal person with the stick:)) but again if the annoying error disappears from the dashboard than is worth it. -
A long awaited answer:))... Make sure you install the o-ring also. In my case the original one had the o-ring broken. When I tested the engine with a smoke machine this was one of the places where it would have a big leak. I used a normal o-ring from a standard o-ring kit. . If you made the change and you still use the car it's worth checking if you have a leak there or not. This can be an issue because the orings do not do that good with oil. -
What you say make sense. My issue now is ...which one is better. This means that Lupo has more power than the a2?...or i just got lucky and got a bunch of bad maf senzors. Yesterday when i was cleaning my shed i found another maf pierburg with casing that i tested a few years ago and i reverted to original after that. This "lupo" version seems to read better - more linear. I am testing it now...for a few months. This car make maximum 5000km a year so it takes a while to have an accurate reading:D
I might have found the issue. I just discovered that the MAF - mas air flow sensor in lupo has a different code than the one in Audi. Also you can find cheaper good quality versions - pierburg - only the sensor without the housing (almost half price). The price today 09-2025 here was 76 euros. The code for the part is: PIERBURG 7.22684.14.0 I did check the graph with vag com AAAAND surprise. The original bosh maf that seems to work does not read the same as the pierburg lupo one. I did replace the bosh with a meat&doria version longer ago but that one was even worse so I got back to the original. The original bosh has a very weird reading -- idle reads ~420. At 1000-1500 rpm reads 313. At 2000-3000 goes around 500 and it does almost reach 600 sometimes when rpm is around 4000+. The new pierburg maf at idle reads a little higher 440. At 1000-1500 rpm reads 480. At 2000-3000 reads almost 550-600. At 4000 reads 750-800. SOOOOO this one might be the headache I was having with bad consumption. It makes sense because the original maf was indeed defective and the replacement one that was not oem was another defective one. I will keep you posted if the consumption is better or not. I hope this will fix a bit part of the consumption Issue. So all of you that said MAF might have been right all along. What I did not really expect is bad maf reading. The car accelerates ok and has no other symptoms than bad consumption. More air would mean less fuel and more power...hopefully. Fingers crossed. The injectors and the cylinder head will be next on the list but that requires a bit more cash.
[1.2 TDI ANY] Getriebelager tauschen ohne Getriebeausbau möglich?
TitusM antwortete auf Phoenix A2's Thema in Technik
google translate: Ich würde das Auto so nicht fahren. Versuch lieber, die alten Schrauben zu ersetzen. Du brauchst einen Schraubenzieher – ein Set gibt es bestimmt für 10 Euro. Bevor du den Schraubenzieher ausprobierst, erwärme die alte Schraube. Hier ein Beispiel (es gibt auch Schraubenzieher, die keinen Bohrer benötigen, da sie selbst schon ein Bohrer sind): https://youtu.be/dCqU1LgsJfU Tipp: Bei korrodierten Schrauben gibt es zwei Möglichkeiten: 1) Mit einem kräftigen Hammer daraufschlagen, damit die Korrosion abbricht (funktioniert auch bei Bremsscheibenschrauben). 2) Mit einer Gasflamme (falls die Stelle es erlaubt) oder einem Induktionsofen erhitzen – die Schrauben öffnen sich wie Butter. Da das Aluminiumgehäuse auf alte Schrauben trifft, löst sich die Verbindung. ---------------------------------------------------------------------------------------------------------------------------------- original: I would not drive the car like that. Better try to find a solution to replace the old screws. You need to buy a broken screw remover - you should be able to find a set for 10 euros. Before you try the broken screw remover heat up the old remaining screw. Here is an example (there are removers that do not need a drill because it already is a drill itself): https://youtu.be/dCqU1LgsJfU As a hint - when ever you have some corroded bolts you have 2 options: 1) hammer very hard on it so the corrosion breaks off (works also for brake disks screw) 2) heat it up with a gas flame (if the location allows it) or induction coil - it will open like butter. Because of the aluminum case hitting old screws helps release the bond. Good luck -
And what are your stats now after new maf?
Where do you have this consumption? How much does it consume when driving out of the city. In my case I can say that I fixed lots of stuff that were wrong with the car. Unfortunately the consumption is not one of them:)). But I do have much better idle and no more leaks and the car is much more fun to drive. In your case - as far as i know polo is common rail. It is a non PD. Tehnically the next generation after lupo and audi 3l BUT the body is not the same. VW did not invest as much in bodywork anymore. My stats over all are 6.5-7 L/100km city and 4.4l/100Km outside/highway (usually city with the car almost empty and outside with the kids and wife so maybe around 120kg extra). I do own a vcds diagnose - without it is impossible to start somewhere(maybe vacuum leaks and other small checks). In your case I would start with the steps below: Usually with any car I start with (injectors and turbo are the last ones): 1)any visible leaks -- vacuum leaks -- and here I include N75 solenoid that moves the turbo vanes The easiest way to check this is with a hand vacuum pump (i bought a cheap one) with a meter on it. You pump and see the vacuum stays the same and also check each vacuum line - turbo, brakes, egr for leaks. To check the N75 solenoid I used a vacuum meter that I connected to the N75 output and i waw that the vacuum was not stable when idling. After fixing it I got less turbo lag. Lately i got a smoke machine from aliexpress. I fixed quite some issues with it(i did not know i had before it on the air intake side). The intake leaks fixed the lag quite a lot. 2)MAF -- in vcds engine -- see if when the engine runs the readings are moving and are in a reasonable area. This is usually one of the reasons vw's consume a lot. 3)lambda sensor if the engine has it. Euro 4+ usually have it. My 1.2 does not have lambda or nox sensor. You can check this if you look at the exhaust. If there is no sensor on it..than there is no nox/lambda sensor:)). Polo for sure has the sensor (maybe even 2 sensors one before and one after the catalytic converter) 4)check for any fuel leaks / even perforated filter hoses, fuel tank. Usually this type of leaks do not register on the car dash so you would catch those only if you calculate full/full. 5)check for stuck rear brakes but that usually is very easy because the rear rims get very hot if the case. 6)the last checks would be injectors and turbo. (also turbo leaks). In my case the injector deviation was fine until I changed the vacuum/tandem pump. After longer Idle there was "white" smoke. The high pressure pump was inserting oil into the fuel. After changing the tandem pump the car would idle better but when looking with vcds i noticed the injector deviation being greater (maybe the injectors were not as lubed with oil as before:)) ) What you have to take into considerations is that NONE of my cars consume "well". I owned: 1,2 tdi, 1.4 tdi, 1.6 tdi, 2.0 and hybrid gte. Each of them had their own particularities and i learned a lot about what causes consumption. I did not get as far as i got with the 1.2 tdi. This is the one I experienced a lot with and that I invested the most and learned a lot about diy diagnose. They tell me I drive quite aggressively so i assume at least 10 ,20% of consumption is my right foot.
Hi, Mine is euro3 so it does not have it. I checked. For now I believe the issue is one of the injectors (it was not visible until I changed the tandem/vacuum pump). The deviation is ~0.7 on one injector compared to the others. I read somewhere that on 1.2 the deviation is much smaller and 0.3 deviation might be an issue already. Since mine is 0.5 from 0 and 0.7 from the other injectors i declare it ...an issue:)). I will keep you posted. In September i will take the care to an expert shop for the gearbox and i will ask them to send the injectors and turbo for revision. I tested 2 other maf sensors - one pierburg and another miele and both of them give bad readings and even worse mileage. For now the original bosh maf seems to be the best (even on vcds the other ones give higher number when idle ~10% but when accelerating it drops very much compared to bosh).
yes:))) in the city.... And I am starting to believe that my driving style and the geography has a lot to do with it. When i get home i have to go uphill for 9KM. It is a demanding hill that asks a lot from the car (I drive usually full power). Outside the city the best I got so far is 4.4 l/100km.
