Hello everybody!
I am new to this forum and what brought me here is, as it often happens, a big problem that I can't figure out myself...
My lovely A2 1.6 FSI, which I own for less than a year started misfiring about 6 months ago. It started as barely noticeable and gradually it's getting worse and worse...
The engine works perfectly for 3-5 minutes after cold start.
Then after a little warming up (say, 3-5 km travelled):
   Works ok at ide.
   Works ok (ish) at revs >4000 RPM.
   Noticeably misfires at RPMs around 2000-2500, especially around 50% throttle.
Check engine blinks then light up. Here are the errors I am getting all the time:
Control Module Part Number: 036 906 013 F
Component and/or Version: MED7.5.11 4628
Software Coding: 00051
Work Shop Code: WSC 02138
Additional Info: WAUZZZ8Z53N005638 AUZ7Z0B2098087
VCID: 122DCA0A5E18EB8E3D9-5000
6 Faults Found:
17443 - Sensor for NOx (G295)
P1035 - 35-10 - Signal Implausible - Intermittent
16523 - Oxygen (Lambda) Sensor B1 S2
P0139 - 35-00 - Response too Slow
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst
P1176 - 35-00 - Control Limit Reached
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
Misfiring cylinders are randomly different every time.
What I did so far:
Fuel system:
-          Replaced fuel filler cap – no effect
-          Replaced fuel filter – no effect
-          Replaced fuel pressure regulator – no effect
-          Replaced Activated charcoal canister – no effect
-          Replaced N80 solenoid valve – no effect
-          Used injector cleaning fuel additives several times – sometimes they seemed to have helped a little, maybe…
Ignition:
-          Replaced spark plugs – this probably helped a little
-          Replaced ignition coils – this helped a lot but didn’t solve the problem
Engine mechanics:
-          Checked compression
I did this in a garage – I don’t remember the numbers, but the guys said all cylinders are even and the values are good.
-          Cleaned up the grounding point behind the left headlight – didn’t do much.
Now I’m puzzled where to look next.
I attach also here a few logs.
Any advice will be highly appreciated!
Screenshot 2024-10-11 at 19.16.26.pngVETRA · 14 Oct 2024 at 11:08 AM
LOG-01-007-140-142.csv LOG-01-007-140-142 1.csv LOG-01-007-140-142 2.csv LOG-01-007-140-142 3.csv
Hey Vetra,
just a few Tipps that i discoverd while having my 1.6FSI.
The Software from ProBoost did a LOT of a diffrence to the car. Highly recommended!
There are 2 diffrent Types of Misfires (at least in German).
One Type is caused by the Spartplugs and Coils.
One is caused by coked injectors.
Since you have allready change the Plugs and Coils i would suggest to clean the Injectors.
Maybe try UMS -> https://ultimatesolutions.de/produkt/einspritzduesen-reinigung-service/#
I think they will help you out too, even when you are from France.
The Injectors have to be removed and send to them for cleaning and testing.
Good Luck!
greetz
Marius
Thank you Marius!!
I spoke with my garage guys - they said they are quite afraid of the amount of labour for taking out the injectors... but it looks like this is the way to go...
(I live in a tiny village.........)
I'll study a bit - maybe I could try to do it myself...
Thanks again!
Cheers
Vitaly
Hi Vitaly,
give it a try. Sadly the Injectors aren't available at the market anymore so you have to improvise :-D
Let me know if it works!
Sometimes a Missfire can also be cause by some kind of leakage. Maybe its also worth a try to investigate this also.
cheers!
Am 2.4.2025 um 18:29 schrieb VETRA:
Thank you Marius!!
In this posting a guy describes, that he found an aftermarket alternative of new injectors and installed them.
https://a2-freun.de/forum/forums/topic/84861-16-fsi-einspritzdüsen-nicht-mehr-lieferbar/page/3/#findComment-1051310
He is very happy with them, but ther is no longtime-experience, because he just installed them.
I made a good experience with letting clean and refurbish www.vierliter.de a complete set of old injectors from ebay. Works perfect sinde 12.000 km.
Problem is, that the correct injectors for an A2 are rare and therefore hard to find at an affordable price.
My garage needed 3,5 h to replace them, but they have A2 experience, so better calculate with 5-6h.
Thank you HellSoldier!
"Some kind of leakage" - you mean the air leak? Or coolant leak? Or fuel leak?
My engine looks dry on the outside... :$ Any particular area to focus on?
Thanks again! :TOP:
Thank you Lubomir!
This is very interesting! :WB2
I wrote the guy (Bastek555) a PM asking for more details...
Thanks again! 9_9
vor 18 Minuten schrieb VETRA:
Thanks again! :TOP:
Hi, the Engines are kind of know for beeing extremly picky when it comes to air leaks and some big errors.
Check:
- Oil filling Tube (Front of the Engine, From the Serviceflap opening to the Oilpan) and the
- Crankcase Ventilation (Back of the Engine, only reachable from under the Car. Located under the Intake Manifold)
- EGR Tube (Driverside over the Gearbox to the Intakemanifold)
- Sealings of the Injectors (Inside of the Intakemanifold, really fuck*d up position)
Those bits are known for Airleaks and wrong Air/Fule ratios.
Thanks HellSoldier! :HURRA:
By the way, I sometimes have this error:
and most of the times this one:
P1033 - 35-10 - Signal Too Low - Permanent
Is this a cause of the misfires, or could this be the reason (impacting the fuel/air mixture to be too lean or too reach) ?
Is it worth taking out and cleaning the NOx sensor head? Or replacing the NOx sensor for a new one?
(they cost around 100Eur and they are not difficult to replace - as compared to the injectors...)
I think it has nothing in common with the misfires.
It's definitly worth a try to replace it. For Petrol Engines its quite common that the Oxigensensors to fail over time.
    2. 4.578
      Zeigt her eure A2!
    3. 16
      Ersatzteilsituation
    4. 4.578
      Zeigt her eure A2!
    5. 4.578
      Zeigt her eure A2!
    6. 16
      Ersatzteilsituation
    7. 9
      Fehlzündung
    8. 16
      Ersatzteilsituation
    9. 42
