ANY startet erst nach machmal sehr langem Orgeln
Das ist doch schon mal prima, keine undichten PDE-Sitze, sondern "nur" ein Leck im Kraftstoffzulauf. -
56
[1.2 TDI ANY] hydraulic oil pump constantly running
I have a guy that updates the hole system including hall sensor for clutch actuator. Modifies the xValve for better control and repairs everything else on the system. Also you can get an adaptor for the pressure reservoir to fit the bigger febi version. If you are still interested live a message in PV. You do have to take everything off and ship it and wait for it to return and of course to have a little faith:)). What you have to remember with the new parts is that the basic settings is not done with clutch at 1.8+ but between 1 and a.14. I did send the pump and the clutch actuator. For me it is a big difference. I intent to visit him and have the gearbox done and the gearbox actuator. cheers and good luck -
Ja, jetzt fuhr ich ohne Luftblasen...., aus der Flasche. Obwohl der 1m lange neue Vorlaufschlauch in die Flasche leer war, sprang der ANY beim ersten Mucks des Anlassers an. Nach zwei Minuten waren VL und RL völlig blasenfrei. Bin soeben im Quartier ohne Haube ein wenig gefahren, einige Male Stop/Start war ganz normal. Werde dann ein paar km spazieren fahren, einen Liter kann ich vergeuden... -
105
[1.2 TDI ANY] - HELP: 6.9L/100km
https://www.oeamtc.at/tests/reifentest/2018-sommerreifentest/falken-sincera-sn832-ecorun-23603235 2,5 at fuel economy is good, Kinergy eco has 1,7, but i think that it ist not such a major difference -
105
I did not want to sell a kidney for it:)). I have falken sincera sn832A eco run on it now. Decent price and decent quality so far. It was 30-40% cheaper when i bought them than today. It says B in consumption...better than the C of ectopia's:)) Total wheel weight is less than 1 kg extra (compared to original magnesium with old ecopias) so In theory it should not make such a big difference. -
BBY startet schlecht
Der Luftfilter ist ok, wie oben geschrieben stimmt dir ausgelesene Temperatur bei kaltem Motor mit der Aussentemperatur überein. Der Tank ist kurz vor Reserve, die Zündkerzen sind ok (optisch), den Benzindruck habe ich noch nicht gemessen, Fehlerspeicher ist leer. -
Der Motor hat 200 Tkm. Bei laufenden Motor kommen jede Menge Blasen. Ich habe jetzt am Rücklauf (wo man trennt beim Motorausbau) einen Schlauch angeschlossen und ein gereinigtes Gefäss mit gefiltertem Diesel gefüllt. Im Rücklauf war dann Schaum, siehe Bild. Im nächsten Schritt werde ich gleich an Pumpenvorlauf einen Schlauch aufstecken und in das Gefäss hängen. Dann läuft das Teil autonom aus der Flasche. 1,5l füllen dauerte übrigens ca. 2 oder 3 Minuten. Ich bin gespannt, wie die Sache ohne Luft im Diesel aussieht und werde berichten. -
105
In think that makes a big difference, long distance it should be much less, if you do not drive over 120 kmh. Most of the users here are long distance drivers. I have an overall consumption from 3,2 with 145 and 3,5 with 165, bit when in drive around just 15 minutes in the city. With traffic, i get 5,5 liters too. The 165 are what kind of tires? They're are very fuel efficient 165er in the market, Hancock kinergy eco or Conti Eco contact , that also makes a big difference. Some users say, there are not very safe, but I am happy with the Hancook.- 1
Auf den würde ich auch mal mein Augenmerk richten. Außerdem günstig zu beschaffen. -
105
When downhill i do not drive in eco because it coasts and consumption is higher than when car is in gear. Downhill i get 1l/100 and uphill around 10-12...so that's why my over all is closer to 5.5. I must make a longer trip ...maybe 100km to see what are the readings now. It would be so....crazy ...if this really has such a big influence....
