ET should not be 45mm or so as it is on the Audi A4 (as I remember). It should be more between 32 and 38mm.
Maybe that helps a bit..
See the original S-line rims for the A2 (7J17 ET38). You also can fit the RS-look or MAM rims with 7,5J17 ET38 (?) bit is is allready a problem at the inside.
      Verbandskasten
    2. 75
      OBDEleven Fahrzeugdiagnose
    3. 14
    4. 55
      Verbandskasten
    5. 55
      Verbandskasten
    6. 55
      Verbandskasten
    7. 55
      Verbandskasten
    8. 55
      Verbandskasten
    9. 14
