Spits
    1.4 TDI (ATL)
  • Farbe
    Kristallblau Metallic (4J)
  • Panoramaglasdach
    nein
  • Klimaanlage
    ja
  • Anhängerkupplung
    ja
    010 Niederlande
932 Profilaufrufe
Leistung von Spits
  1. Spits
    Zeigt her eure A2!
    First; I'm sorry this turns out in a English conversation and also it's off topic! Correct, the A8 D2 rims are forged rims, have a flat back and can be considered very strong to add some other lochkreis. I would not consider making extra lug holes in a normal cast rim. As an example a picture from a company which alters rims for autocross: It's an A3 pepperpot. Would you install it? I would not, but on a light vehicle on a track it can widstand incredible forces without deforming, and shows how strong forged rims are (also note the extra created lochkreis, 5x130 in this case). Personally I don't want adapters, I don't mind if people are using them. Another lochkreis in forged rims is secure, although others will say; no it is not. It's a conversation which has no end, and I'm not going there anymore. Oh, just to tease......😜 Picture;
  2. Spits
    Zeigt her eure A2!
    There's a guy in Holland too....... There's a lot to say for it (and said about it!), each to their own. The forged flatbacked rims are no use (to me) if I would use them with a heavy adapter. Call me ignorant or careless or dangerous to society...... Well, I better don't post a solo picture of the 5x100/5x112 rim('s). They are under my A2's for 3+ years.
  3. Spits
    Zeigt her eure A2!
    Well, that's a pity and asks for measurements 😉! So, here's my AMF with, again A8 D2 winterfelgen, although different in design and equipped with 5 speed MZN Bluemotion gearbox and remapped ECU. And since those rims should also weigh 6.1Kg according to above mentioned website and because they are now on the shelf in the Shed, I thought it was nice to weigh them personally; 6,37Kg, so not far off but certainly not spot on...... With summer tyre size 195/50-16 they weigh around 14,6Kg on the scales. Tyre brand, size and what kind(XL and/or wintertyre) will be of influence on weight ofcourse.
  4. Spits
    Zeigt her eure A2!
    Oh! I'm amazed info on mentioned site (being a German site, which can be considered Grundlich...) is not correct...... Next opportunity I will personally weigh them with some scales.
  5. Spits
    Zeigt her eure A2!
    Thanx! According to this site https://www.original-felgen.com/4d0601025aaz33.html they are 6,1 Kg.
  6. Spits
    Zeigt her eure A2!
    My ATL with A8 D2 Winterfelgen. Tyre size is 195/50-16. PTW 6 speed gearbox and remapped ECU. At the front Weitec coilovers, but possible swap to Bilstein B8 in the future.
  7. @biohaufen Hero, can you tell some more how to alter and/or change the BIP map. My ATL develops the same 2-step idle character when changed to remap/tuning software! Apparantly something is changed in the hardware department of my car..... In the end swapped back to former software and all was fine again.
  8. A question about the 4pot flywheel. In my search for a replacement SMF flywheel (to ditch the ATL DMF,) I'd understand that a 4 pot SMF is creating (unwanted) unbalancing of the 3 pot....... that's why I installed an AMF SMF, which unfortunely only takes a small diameter (215mm) clutch. I take it you're driven your tuned set up, or enough at least, to say if there's vibration in any of the rev range? Woul'd you be so kind to give info what 4pot flywheel (partnumbers) is used and/or if the flywheel is re-balanced for a 3pot? Thanx!
  9. A2 friends, a compliment to your fine and informative forum! Every time I'm surprised to find some new information which is beneficial to keep Audi's finest on the road. This time it was a post of @A2-D2 about a PQ25 console & wishbone which could be installed as an alternative to the original PQ24! Maybe nothing special to someone who delivers his car to a dealer or garage for maintenance........ But very interesting for people who wants to do everything by themselves! My German is nicht so gut (understated ?) but, man, what a big source of information this forum is, Big Thanx for sharing! ?????
  10. Hello all! Sorry to reply in English.... If you don't mind; I'm Menno from the Netherlands, this my first posting and this subject triggered me to become a member an react on it. I bought a febi kit with 3 sprockets and bought the 4th sprocket from the far east. When the Febi kit arrived it was defective (one of the guide rail was broken loose). I returned the kit and ordered a Borsehung with 4 sprockets. The quality comparison is there. The Borsehung sprocket is well made in comparison with the Chinese one, and was to be expected..... Top sprocket Chinese, bottom one Borsehung; It's clear that the top gear is coarser, also the teeth are wider in radius and are sharper........ Almost would think it's been used.
