NavGear DSR-N 270
Prefelix
Hello!
My name is Liviu and i have some problems regarding the NavGear in question (DSR-N 270).  The problem is the following:
1. I copy some music and videos on the HDD
2. When i connect the HDD (Hard Drive) to NavGear via USB it says that the HDD is empty or blank and asks me to format it. I tried to change the file system from NTFS to FAT32 then to EXT2, 3 and still no success.
Is there any way to make it work?
i really am tired of searching and this forum seams like the last chance
Thank you and waiting for your reply!
Moderator:
Moved to correct sub forum.
vor 17 Stunden schrieb Prefelix:
Also just to let you know the HDD is 2TB...maybe that has something to do with it?
Yes, maybe... ;)
  • Perhaps the receiver does not support HDDs of (e.g.) ≥ 2TB?
  • Which USB standard is supported by the NavGear? USB3-HDDs usually require a current of 900 mA. If the NavGear supplies 500 mA only (which is the standard up to USB2), I could imagine that this is the problem.
  • Please also check the structure of the folders on your HDD. Sometimes the receiver cannot read data from sub-folders.  Does your HDD have more than 1 partition?
Thanks for the reply Heavy-metal. I had the HDD partitoned, but now it's only one partition of 32GB i will try to see if it works, also i will try what you said  :
I'll not put the files in folders.
Thanks!
Bearbeitet von Prefelix
    2. 5
    3. 5
    4. 5
    5. 5
    6. 5
    7. 332
    8. 10
    9. 5
    10. 7
      Kälteleitungen erneuern
