Motorüberholung
[1.2 TDI ANY] Sammelthread für Kupplungsnehmerzylinder mit Hall-Sensor-Umbau + HINWEIS!
You say pump is running constantly. Question number 1.: Is there enough hydraulic fluid in the system? The pump should definitely not run constantly. Even with a bad pressure accumulator it would not constantly run. -
38
Sorry that I am writing in English. Like all of you my Audi a2 1.2 tdi have a problem with gears shifting. I spend a lot of time to read all problem related forums but didn’t find solution. My A2 hydraulic pump was running all the time, and I decided to change an accumulator tank. I bought new one Febi (with adaptor) and use one with a pump from my friend (5-6 gear changes before starts pump). Clutch disengaged at 1.84v and engaging 3.85. Did basics adjustments. Problem: pump is running constantly when engine is on. Car starts in S and N but won’t run. When I change to D or R car engine is revving but not drive because clutch is ON. VCDS group 3 showing Clutch position (Actual) 99.6% and Clutch position (specified) just running in a circle from 2% to 75% and back. Some time, when I start a car in N and then to D is disengage clutch and it drives and changes gears, but pump is running constantly. There is no leakage in a system. I on the way to buy a new clutch cylinder, but not sure it will help, and is not so cheap just to buy it and try. Can someone have advice? There is video from VCDS: -
11
11
Motorüberholung
Gut also Kompressionsprüfung in den Zylindern - was dürfen die haben beim 1.2 tdi? -
11
Motorüberholung
Wieso Loctide im SSP mit d statt t geschrieben wird? Da hat der Praktikant geschlampt ... :-) -
11
11
Motorüberholung
Die haben aber nicht diese Zuganker, oder? Das kommt ja beim 1,2er noch dazu. Lange Rede kurzer Sinn, ich würde statt einer Überholung auch auf die Suche nach einem Motor mit guter Kompression gehen, ist vermutlich einfacher und am Ende billiger. Die Motoren sind schon sehr haltbar gebaut. -
11
Motorüberholung
Ja das gleiche gilt auch für die 1.4 16V Gibt bei uns trotzdem 3 Blöcke, die das in der Werksausbildung überhört haben Aber beim Diesel: Kette der Ölpumpe und Zylinderkopf WG den PDE Elemente / Stützhalter. Danach fahr mal erstmal die 1 Mio km;) -
11
Motorüberholung
Laut Selbststudienprogramm kann man den Motor nicht volständig revidieren: Das ssp223 findet man über die Google Suche beim https://www.vw3literlupoclub.com und bei Nininet. -
Kühlerschlauch defekt, suche Ersatzteil
Moin, an meinem A2 ist leider ein Kühlschlauch kaputt. Laut Werkstatt und eigener Recherche lässt sich kein neues bzw. auch kein gebrauchtes Ersatzteil mehr finden. Die Teilenummer ist 8Z0819371J. Es finden sich jedoch nur Ersatzschläuche mit der Endung K. Weiß jemand wo ich den richtigen Schlauch kaufen könnte? Vielen Dank! Mfg Nelly
