Bala_de_plata
    noch kein A2
  • Ausstattungspakete
  • Soundausstattung
  • Panoramaglasdach
  • Klimaanlage
  • Anhängerkupplung
    ФРГ
Hobbies
  • Hobbies
    keine
Beruf
  • Beruf
    guter
5.191 Profilaufrufe
Leistung von Bala_de_plata
  1. firmware v2.9.4_b40 27.09.2022 Firmware updated. Changes: - fixed display of the current gear for automatic transmission (in “PRNDS+1234” mode) - fixed CAN bus selection in CAN monitor (TT8J) firmware v2.9.4_b39 21.09.2022 Firmware updated. Changes: - fixed display of data on the chart in diagnostics - fixed bugs in changing some settings in the menu - updated display of parking sensors - added transition to the service settings by the “service” button (А48Е) - added confirmation of resetting Trip data - added custom color settings
  2. firmware v2.9.4_b38 Changes: fixed bug in Russian font added the ability to display data from diagnostic on the main screen changed menu structure (Design) fixed display of Russian in RNS-E audio data fixed work with CAN-buses (Comfort and Info) fixed minor errors in the menu and data display
  3. firmware v2.9.4_b37 31.01.2022 Firmware updated. Changes: fixed display of parking sensors updated code for working with parking sensors A6/A8 updated list of available blocks for diagnostics fixed work of diagnostics for KWP2000 sleep order changed changed the output of messages about malfunctions of DHRC/AFS systems speedup graphics processing fixed update of navigation data on A4 B7 (clusters with a color screen) added information about ESP/ASR for TT8J added output of messages about malfunctions of the steering system (PQ35) added function to display data from OPS A6/A8 to RNS-E PU added rear view BAP-camera emulator (RNS-E PU + OPS) added data output from Extended miniCAN to the main screen, to the OK zone and to gauges added the ability to connect a reverse gear signal to TrInput11 for T4 (manual transmission) added data change effects on the main screen separate data change effect settings for main screen and OK zone firmware v2.9.4_b36 02.05.2021 Firmware updated. Changes: fixed: incorrect display of total mileage on some PQ35 fixed: broken images (Air suspension and TPMS) firmware v2.9.4_b35 25.04.2021 Firmware updated. Changes: fixed: false triggering of low oil pressure (TFSI engines) fixed: blocking of audio data when telematics phone is present
  4. firmware v2.9.4_b36 02.05.2021 Firmware updated. Changes: fixed: incorrect display of total mileage on some PQ35 fixed: broken images (Air suspension and TPMS) firmware v2.9.4_b35 25.04.2021 Firmware updated. Changes: fixed: false triggering of low oil pressure (TFSI engines) fixed: blocking of audio data when telematics phone is present firmware v2.9.4_b34 16.04.2021 Firmware updated. Changes: fixed: some Info-CAN issues fixed: CAN-monitor issues fixed: display current gear while use CCS (manual transmission) updated: air suspension support updated: CNG support updated: optimization of the diagnostic protocol and adding more texts of error codes updated: control buttons usage (MFSW support also updated) added: CCS speed calibration added: advanced service settings added: manual setting for speedup time measure
  5. firmware v2.9.4_b33 05.01.2021 Firmware updated. Changes: changed: sleep mode updated: OPS A3 support updated: OPS A6C6 support fixed: gauge scales for boost pressure fixed: translation for some languages updated: main code for processor hardware added: additional tooltip for gear shifting (manual transmission) added: the ability to connect a reverse gear signal to TrInput15 (A3 8L, TT 8N, Sharan) (manual transmission) added: overspeed alarm by tire index added: display of total mileage and time in the upper area
  6. ColorMFA ist auch mit neueren PDC-Steuergeräten kompatibel, siehe Bild.
  7. From Russia with love: PDC vorn + hinten + Steuergerät + ColorMFA
  8. firmware v2.9.4_b32 20.06.2020 Firmware updated. Changes: changed: updated support of original TPMS fixed: sleep mode issue (A4(8E), A3(8P), A2) fixed: some small bugs in BAP protocol fixed: coffee-break settings added: support original BiFuel cars (gas + petrol) fixed: small bugs in Extended Info screen added: more values on Extended Info screen changed: faster update ‘boost’ on screen changed: ‘boost’ calibration from analog sources added: Trip2 data to main selection of displayed values (disabled hot key for switching Trip1/Trip2) added: consumption at idle on bottom of screen added: display selectable or fixed data in ‘OK’ area (if there are no errors)
  9. Hallo zusammen, ich hätte eine Frage bzgl. NW-Lager für 1.4TDI BHC. Worin unterscheiden sich 038 103 673A/B/C und welchen Brand würdet ihr empfehlen (KS, Borsehung, Glyco, ET, etc.)? Danke euch!
  10. firmware v2.9.4_b31 29.12.2019 Firmware updated. Changes: fixed: error in TP2.0 and TP1.6
  11. firmware v2.9.4_b30 27.12.2019 Firmware updated. Changes: changed: diagnostic connection mode added: some diagnostics protocols support added: show outside temperature to center main screen added: DDP2 and BAP support for audio/navi (experimental) added: user custom units settings added: coffee-break with distance check added: Trip3 (need enable in hidden menu) changed: average consumption calculation added: some statistics values for TripX fixed: DDP (VW) connection problem in some cars/navi fixed: some small bugs in code and in translations
  12. Einbau ColorMFA mit Bildern bzw Beschreibung der Reihenfolge.
  13. Wird getestet: Neue SW mit km/l als optionale KST-Verbrauchsanzeige.
  14. Beide sind mit ColorMFA kompatibel und bei Bedarf nachrüstbar, wenn man das große FIS hat.
