Audi Forum Treffen bei D&W in Bochum
LIVE-Thread - 25 Jahre Audi A2 in Neckarsulm 19.9. und 20.9.2025
Hiermit schonmal die Bitte, auch die Galerie zu füllen, und nicht nur den Thread https://a2-freun.de/forum/gallery/category/205-2025-25-jahre-audi-a2-produktion-in-neckarsulm/ -
46
[1.2 TDI ANY] hydraulic oil pump constantly running
When you took a pump from another car, the gaskets could be still fine. Nevertheless you should use it with ATF oil too long. As you have seen, the pump itself can reach the threshold pressure. So I think it is needed to replace the gaskets on the valves of the gear actuator. There are 2 parts in the system with a high and low pressure side: pump and gear actuator. Worn out gaskets will lead to a bypass between high and low pressure resulting in problems like yours. The clutch actuator works differently. -
46
Ok, this it is gaskets. Gaskets in pump unite, gaskets in gear selector? There is no kits to care all all unites. My pump is from another car and it not runned with ATF oil. Left clutch actuator and gears selector. You mean i need those two parts? -
35
and the last of this batch- 3
35
35
35
