1.2 tdi startet nur i N
Starting only in N position
First excuse me for not writing in German, I do understand but writing is too difficult. So please answer in German if easier.
Background
I haven’t use my A2 1.2tdi for a while so I took the car one day and it work perfect. I parked the car and when I should start again after 2 hours I couldn’t start. Battery Ok. I tried to start with gearshift in N position but without success. I disconnected the battery for 10-20 sec but no change. I had to take the car home on a trailer.
I went for holiday for one week and when I came back I tried to start the car, it started but only in N position of the gearlever!
I read out failure codes , many failure codes but none on the gearbox. I deleted all failure codes and tested again .(The battery have been flat so many codes where related to that)
These failures codes remains.
Hope you can read have, translated the codes that I think is relevant from Swedish.
More background
I repaired the” gearbox control” some month ago, hydraulic oil leakage in , play in “gate control arm” after that I made a “Basic setting “ of the gearbox.
Only failure that I know of except “staring just I N” is “Oil temp/level” sensor (G266)
Here I hope for some help
-Why start only I N position
-Because of the failure codes “Intermittent erors” ?
-Some kind of safety function in the software of the gearbox ECU when there are failure codes saved related to gearbox
-Will a new basic setting help ?
-Any idea why intermittent errors ?
- Where to search? Connector error?
-Other reason(s) ?
BR/MFG
/Kurt Myhr
Hallo Kurt,
mein Schwedisch ist nicht so gut daher meine Antwort in deutsch....
schaue mal in diese beiden Threads...es waren unterschiedliche Ursachen..
A2 1,2L startet nur in N (mit Auflösung)
Starten nur in Position N möglich
schreibst du bitte noch wieviel Kilometer dein 1.2er schon hat...
und ob du regelmäßig (alle 30.000Km) eine Getriebegrundeinstellung gemacht hast.
Hallo "Karat 21"
It seems that I have to take away the gearbox and check the "Führungshülse".
I read through the "startet nur in N (mit auflösungen). Probably I have the same problem and than it is logical that the cars starts in N but not in S/P
/Kurt
Hallo
In my first post in this subject an attachment with a log fil (Reda out of failure codes was missing.
I think I have a good clue re "startet nur N".
Here under the log file.
Any idea where to search for the "intermittent errors" ?
Log File ( see translation to English)
Onsdag,28,Mars,2012,12:30:50:18143
VCDS version: AER 10.6.4
Dataversion: 20110418
Chassityp: 8Z - Audi A2 00>
Skanna: 01 02 03 08 15 16 17 18 37 45 46 56 57 75 76 77
VIN: WAUZZZ8Z42N018234 Mätarställning: 229170km
Adress 01: Motor Labels: Textfilsfel!
Artikelnr: 045 906 019 D
Komponent: 1,2l R3 EDC 0001DS 1452
Kodning: 00005
Verkstad #: WSC 02154
VCID: 162664975817
WAUZZZ8Z42N018234 AUZ7Z0A1998696
1 fel funnet:
18062 - Läs av felminnet för: kombiinstrumentet 18062-Read failure memory : Combine instrument
P1654 - 35-10 - - - Intermittent fel Intermittent error
Readiness: 0 0 X X X
Adress 02: Automatväxel Labels: saknas
Artikelnr: 6N0 927 735 D
Komponent: DS085 Getriebe 3081
Kodning: 00000
Verkstad #: WSC 00000
VCID: 397C8F2B09C9
Ingen felkod funnen. No failure codes
Adress 03: Bromselektronik Labels: 8Z0-907-379-MK60.lbl Brake electronics
Artikelnr: 8Z0 907 379 C
Komponent: ESP FRONT MK60 0101
Kodning: 0019474
Verkstad #: WSC 02154 785 00200
VCID: 489AFAEF4223
Adress 08: Klimatanläggning Labels: saknas
Artikelnr: 8Z0 820 043 D
Komponent: A2-KLIMAVOLLAUTOMAT 0510
VCID: 377889133FDD
8 Funna fel: 8 failures identified
00710 - Ställmotor för defrosterspjäll (V107) 00710- Acutator for def-flap
41-10 - Blockerad eller ingen spänningsmatning - Intermittent fel
41-10 Blocked or no voltage supply -intermittent error
01272 - Ställmotor för centralspjäll (V70)
01271 - Ställmotor för temperaturspjäll (V68)
00601 - Potentiometer-ställmotor för centralspjäll (G112)
30-10 - Avbrott eller kortsluten till plus - Intermittent fel
00600 - Potentiometer-ställmotor för temperaturspjäll (G92)
00819 - Högtryckgivare (G65)
29-10 - kortslutning till jord - Intermittent fel
00818 - Givare för utströmningstemperatur förångare (G263)
30-00 - Avbrott eller kortsluten till plus
01273 - Friskluftsfläkt (V2)
17-10 - Kontrollavvikelse - Intermittent fel
Adress 15: Krockkuddar Labels: 8Z0-959-655.lbl
Artikelnr: 8Z0 959 655 E
Komponent: Airbag Front+Seite 5005
Kodning: 00102
Verkstad #: WSC 02152
VCID: 4E96CCF7A047
Adress 17: Instrument Labels: 8Z0-920-xxx-17.lbl
Artikelnr: 8Z0 920 930 Q
Komponent: KOMBI+WEGFAHRS. VDO D06
Kodning: 01135
Verkstad #: WSC 40350
VCID: 4A9EC0E75C2F
5 Funna fel:
01176 - Nyckel
07-10 - Signal för låg - Intermittent fel
01314 - Motorstyrdon
49-10 - Ingen kommunikation - Intermittent fel
01315 - Växellådstyrdon
01309 - Styrdon för styrservo (J500)
00562 - Givare för oljenivå-/temperatur (G266)
29-00 - kortslutning till jord
01176-Key
07-10 signal low -intermittent error
01314- Engine ECU
49-10-no communication-intermittent error
01315-Gearbox ECU
01309 Power acc stearing ECU
00562 Senosr oil level /Temp (G266)
29-00 Shorts curcuit to ground
Adress 46: Komfortcentral Labels: saknas
Artikelnr: 8Z0 959 433 M
Komponent: Komfortgerát T05 0615
Kodning: 06720
VCID: 50AAD28FBA73
Artikelnr: 8Z1959801
Komponent: Tõrsteuer.FS BRM 0001
Artikelnr: 8Z1959802
Komponent: Tõrsteuer.BF BRM 0001
5 Funna fel:
01330 - Centralstyrdon för komfortsystem (J393)
53-10 - Matningsspänning för liten - Intermittent fel
01366 - öppning på grund av krocksignal
36-10 - Avbrott - Intermittent fel
01331 - Dörrstyrdon förarsidan (J386)
01559 - Förardörr
37-10 - Felaktig - Intermittent fel
01560 - Passagerardörr
53-10 Voltage to low- intermitten error
01366- open as conseues of chrasch signal
0331-Door ECU driverdoor
49-10-No communication- Intermittent error
01559-Driver door
37-10- Failure- Intermittent error
01560 Passager door
Slut --------------------------------------------------------------------
Hallo
....intermittent error
Ich habe probleme mit kalte lötungen am kombiinstrument gehabt.
Macht sinn für mich (dich :-), als das kombiinstrument das "gateway/central" für alle andre module sind. Dafür alle die verschiedene modul-fehler im fehler log.
Kupplung Führungshülse is nicht mein erster wahl, als genau diese fehler, nicht immer im fehler log auftreten (selbst gerprüft).
Gruss aus Kopenhagen, DK.
Bearbeitet von JesperB
  • 2 Monate später...
Help no movement of “gangsteller” !!
Background
At last I decide to take away the gearbox to change the ”guide for the clutch bearing” as I had just “start in N” and yes it was broken.
Changed clutch ,bearing, and “guide”.(fuhrungshulse)
Put the gearbox back filled the hydraulic oil , connected the battery.
Hydraulic oil was coming out from the “gangsteller” where the gasket is !! Haven’t happened before !! Disconnected the battery and check , tightened the screws on the “gansteller”. Connected the battery ,still leaking but suddenly the leak stopped! Tried to do a basic setting but no movement of the “gangsteller” !!
Took the” gangsteller away and changed the gasket.
Still no movment on the “gangsteller”, Clutch working so hydraulic pressure ok.
On can here the solenoid vales are working during “basic setting” but “gansteller “doesn’t move.
Checked all measuring block and found no failure.
WHY ?
-Dirt in the hydraulic circuit ?
-Other reason ?
BR/MFG
Kurt Myhr
    2. 46
    3. 1
    4. 1
    5. 8
      LED-Kennzeichenbeleuchtung
    6. 7
    7. 2.296
    8. 2.296
