1.2TDI problems with reverse and then problems with basic settings
Hello,
The car was running correctly and then when I tired to reverse from my driving the klaxon started pinging and the car would not find reverse.
I then tried basic settings and got an RTFM! 12. The reverse light did not light at the stages reverse is meant to be found but a wire across the terminals lights the reversing light when R selected on stick.
I have changed the reversing light switch on the gearbox today but still the basic settings made 28 steps twice and again RTFM! 12 is logged.
The car shows N when D/E by the Tiptronic gate is selected but if you turn the ignition the car starts and immediately stops.
Can it be the nut that needs to be loosened and retightened is too loose and is there anyway to make the car find the correct positions again?
The voltage in the KNZ is 1.91v. The 12v power is 12.2V or so with the car connected to an external charger.
I am out of my depth here and need some advice! Please help!
John
RTFM12 is always caused by a malfunction of the gear actuator. Sometimes there is too much clearance in the mechanic parts and that causes that the gears can't be selected correctly.
First of all you should try to insert the reverse gear manually after unplugging the hydraulic pump and depressurize it.
The reverse lights have to light up when ignition is on.
When this was checked, you should run another basic setting. In the ADJUST step, the gear actuator will be in zero position. Then you have to release the 13mm nut and put the gear selector in it's zero position as well. Just wobble a little  at the gearbox mechanic. Then tighten the nut and go on with the basic setting.
In the steps 5 to 8 the reverse lights have to light up. If the don't, the basic setting will fail.
Hi Mankmil,
Fantastic. This should be possible to try.
Is there a guide here to manually selecting the reverse gear. Which direction to push and so on?
Could I have worsened the problem by releasing the 13mm nut at an odd angle leaning under the car?
Is it possible I could have knocked the selector out of place and so I have a new problem rather than the not working reverse switch?
John
I got the shifter back into place and managed to manually find reverse.
The basic settings still cannot complete with the following logged:
19:07:38 Group 014: Gear Selecter Adaptation
  RTFM!  Instruction(s)
  28.0  Transmission Position
  12.0  (no units)
  3.98 V  Voltage
It seems the voltage is not changing much as the 28 steps are performed.
What should I look at next? Could it be as simple as a loose connector?
vor 34 Minuten schrieb JohnL:
RTFM! 12.0
That's how the Error-Message is meant.
What you need to tell us: Do the reverse lights go on, when you manually insert the reverse gear?
Do the reverse lights go on in the steps 5 to 8 (2nd Field -> Transmission Position) ?
RTFM 12 is always a gear actuator malfunction. Are there any error codes stored in the transmission control unit?
Hi,
The reversing light came on during the basic setting steps 5-8 and also when I manually selected reverse gear.
On turning the car on the robot starts movement whilst the car is still in P. Does this help identify a problem?
I will check for error codes again.
vor 23 Minuten schrieb JohnL:
It could help a lot. Otherwise there is no hint what went wrong.
I assume that the basic setting runs twice form 1 to 28 and then you get RFTM 12. Do the reverse lights go on in both runs?
If there are no error codes set, there are two options left: Check gear actuator mechanic for clearance or change the position in the elongated hole in the "ADJUST" step.
There must be absolutely NO clearance in the ball joints between the actuator and the lever. Also remember to put on a charger when you do the basic adjustment, since the voltage can easily drop below 12V. Good luck!
And also check the aluminium arm which the top ball joint sits on, if this arm is not well fixed to its splined shaft this will give the same result as clearance in the ball joints, causing rtfm12 .
The only error listed is that the basic setting was unable to complete. During the 28 steps the reversing light comes on in both runs.
I will check the clearances on the ball joints.
For changing the position in the elongated hole in the "ADJUST" step is moving up or down more likely to help?
The car is in a car port with little space to work and it is not so easy to get under the car and so this is proving to be quite challenging to observe/inspect anything.
The graph of the basic settings shows the setpoint to stay in the 3.Xv range most of the time but with drops to less than 2v twice. The voltage is pretty close to 12V and so I suspect the leaving the car charging a while to build up voltage would be beneficial before trying again.
On trying again the 28 steps complete twice with the reversing light coming on between steps 5 and 8 but it still fails with RTFM 12 at the end.
The voltage is over 12v for the entire process and the only logged error is that the basic setting was unable to complete.
What would be good to look at next?
In my own experience it is not possible to succeed with this basic setting if there is a significant clearance in the ball joints or in the splined shaft mounting of the aluminium arm which has the male part (the ball!) of the upper ball joint.
This spline can be tightened through a small screw but access is very limited. I managed this first after removing the whole gear actuator from the gearbox.
I think you need to have sufficient room to allow work from below.
Thanks! I will have to see if I can solve this. I do not think the top will be so accessible. How critical is the voltage? Could the voltage dropping just below 12v be enough to cause a problem and can low voltage cause an RTFM 12 or would it present with a different error?
I got the car working again and other than the battery being much better 12.84v not much ekse seemed different.
It seems the voltage has more impact than would be expected. Before with the car plugged in I only had 12.04v when I started the process but with mains power connected.
I did not adjust position of the bolt on the bottom of the operating rod.
    2. 13
    3. 40
    4. 626
    5. 21
    6. 21
    7. 626
    8. 40
    9. 21
    10. 21
