ESP Warning Light (ABS, ASR, Brakes)
Hello everybody,
Many written about ESP faults, i wanna share mine if u dont mind.
My German is not very well so I try english..
Recently  while driving the car, Audi A2, 1.4 tdi, 55kw, 2001, AMF, the ASR light flashed followed by ASB and Brakes warning.
I already did some research and read the ABS system with my handscanner Autophix ES680.  Following errors
1. ABS system->01542 G202 Yaw rate sensor
2. Motor system-> 18057 Powertrain Data Bus missing message from ABS (P1649)
3. 00778 Steering Angle  G85
4. 16955 Brake Switch (F), Implausible Signal (P0157)
I went on and replaced the brake Switch , I read many threads causing this.
Unplugged multi-pin connector T47 from ABS with EDL control unit-J104 and measured for open circuit wires to connector on G202, all looking good, also +5 V power.
Re-attached T47 and G202 + G200, and after scanning ABS system now gives me 1 error 01423 G200 and again 16955 Brake switch.
I notice that when i switch on ignition, abs + asr lights dim and when I wiggle the whole unit in bracket (G202, G200) lights illuminate in dashboard,
I suspect faulty sensors, but u never can be shure, strange at first G202 and now G200, is my scanner no good or sensors bad or..? Anyone?
thank u
Moderator:
Moved thread to english sub forum and adapted the thread title.
Bearbeitet von Phoenix A2
Moved to english sub forum
i also have the possibility to read the [Measuring Blocks - 08] Group 004
field 1: steering angle  (G85) in beginning >3000 ° and when turning wheel < 300 °, dont seem right to me,
field 2 (G200) looks normal 0,5 m/s²
field 3 (G202) acts crazy with > 32 m/s², dont seem right to me.
Bearbeitet von Math
      Defekter Tankdeckelentriegelungsmechanismus
    2. 6.855
    3. 6.855
    4. 4
      Auto brummt ab 45 kmh
    5. 23
      [1.4 TDI ATL] Hoher Stromverbrauch
    6. 3
    7. 6.855
    8. 3
    9. 3
    10. 48
      Antriebswelle in Radnabe einkleben oder fetten?
