bret
Administrator
Alle erstellten Inhalte von bret
  1. fine, so ask the question in english anyway. We need more information. - Bret
  2. bret
    ITX Livethread
    I would assume nothing regarding a future track layout from this year's. And I mean nothing - there was no input from me on this.... I was looking for a long straight, too, but didn't get one. Freifläche is the one remaining thing I'd like to see. - Bret
  3. bret
    ITX Livethread
    I think this was one of the best yet. Very good group. The hotel works well (even if there are some things which could be better!) and the trackmeister is awesome. Makes a big difference when the weather is dodgy and the snow walls are soft There's very little to improve for 2020, ITXX. I think an awful lot of people wish to return; we have to see how to limit the group size because much bigger than this is really hard to control. Thanks to all attendees! - Bret
  4. bret
    ITX Livethread
    lol. Bergungsarbeit war ja genug da. Und ein Traktor dafür ist wirklich was feines. Ja, 2 Tracks. Links etwas grösser, rechts (Östlich) kürzer und langsamer. Ja, Drohnenbilder kommen. Ja, vieles in 4k. Ja, weit über 500GB z.Zt bei mir. Ohne einiges..... - Bret
  5. Under -10 the insides of the windows freeze in all cars. if your pollen filter is clean and dry, you have an interesting problem. I am assuming you use the fan and it's towards teh windscreen? You must have airflow across the screen in winter or it will have condensation on it. You should also clean it to make sure as little fluid as possible sticks to it. Auto climate control or manual? If auto, are you 100% sure all the flaps are working correctly? - Bret
  6. bret
    ITX Livethread
    davon haben wir mehr als genug. Und es schmilzt bei Helsinki, echt eklig. - Bret
  7. bret
    ITX Livethread
    yes, andre now has a TT. - Bret
  8. bret
    ITX Livethread
    enjoy! - Bret
  9. bret
    ITX Livethread
    Unser schnee liegt hier seit November. Anfang Dezember war es kurz über null, aber seit dem Dauerfrost. - Bret
  10. bret
    ITX Livethread
    um eine Frage zu beantworten: in Kouvola war es um 0. Hier wiederum -8. Schmelzen tut sich nicht so schnell - es ist schön durchgekühlt überall und entsprechend dauert es bis tatsächlich taut. Helsinki war gestern etwas über null, aber nicht viel. Und dann kam der Schnee wieder... urgh. Schlimm ist im Moment nur die Mittelstreifen auf den Strassen; da ist meist ungeräumt und es macht überholungen *richtig* interessant. Noch geht's Heute um Hütchen und dann heute Abend um lichter. - Bret
  11. bret
    ITX Livethread
    you should join us one time - Bret
  12. bret
    ITX Livethread
    so... schnee wieder geräumt. Jetzt ist der Haufen ca. 4 x 4 x 1.5m x 2 --> da komme ich auf ca 35m3 schnee. Und es kommt weiter runter... - Bret
  13. bret
    #ITX: Icetrack2019
    ^^ das hat Wochen gedauert. Fast überall nur Probleme mit Eis - sehr langsam gekommen da es so viel schnee gibt.... yr meint auch inzwischen um -2 bis 0 mit plusgraden erst spät am Sonntag. Schauen wir mal. - Bret
  14. bret
    #ITX: Icetrack2019
    Kar de Mumma war sehr gut heute... ich war ja in Jyväskylä. Sicht war teilweise unglaublich schlecht wegen aufgewühlten Schnee - und der GRA vom Octy schaltet sich auch wenn ein ESP-Eingriff notwendig wird... Friday Menü: Käsige Lachssuppe Rind / Chorizo eintopf mifu-gemüse wok und das übliche á la carte. ich werde wieder ein Hähnchenwrap und Butteraugensemmel nehmen. Morgens waren die noch warm, da ist mir Butter auf'm Teller rausgequollen. Sehr gut. Die Espressos sind auch noch ganz tolerabel. - Bret
  15. bret
    #ITX: Icetrack2019
    Alles sieht im Moment noch gut aus. Wettermässig ist es etwas fragwürdig; könnte sein dass die ernsten Spikes nicht benutzt werden können, wenn die der Oberfläche zu arg angreifen. Alles eine Frage des Wetters. Es gab wieder Stress wegen Schnee hier - es hat nochmals gut 10cm geschneit und es hat Trackmeister das Leben sehr schwer gemacht. - Bret
  16. bret
    IT10 Unsinnsthread
    jo, wir werden sehen wie es wird... wir hatten gestern Nacht nochmals 7cm oder so, und der Vorhersage wechselt von Tag zu Tag... - Bret
  17. bret
    IT10 Unsinnsthread
    mierda. Kältewarnung ausgesprochen; -25 und weiter für mindestens eine Woche. Oho. - Bret
  18. bret
    IT10 Unsinnsthread
    Wetter sieht echt nicht schlecht aus - -25 morgen und dann zurück auf -15 bis -10. Geht. Hier haben wir gerade wieder Schnee abbekommen, ca. 10 cm... - Bret
  19. Funktionierte der GRA noch? - Bret
  20. mit 80km/h habe ich regelmässig hierzulande 5,x gesehen, der unterschied zwischen 100 und 120 ist schon einiges. Habe es mal erläutert. Aber eher 100 also 120 ist ziemlich gut.. die Frage stellt sich aber schon, warum so arg versuchen Sprit zu sparen? Es hilft nicht mit Zeit, es hilft nicht wirklich auf Kosten (fähre ist sowieso der grosse Brocken) und für 500km 5l Benzin sparen.. das ist dann €7 und eine Stunde länger unterwegs sein. - Bret
  21. fest hinter Lenkstange und fest hinter Handschuhfach. Schnell ist es nicht. - Bret
  22. bret
    #ITX: Icetrack2019
    schienenlicht? Hätte es eher mit Eisen-teich übersetzt, aber ... whatever - Bret
  23. bret
    IT10 Unsinnsthread
    i can't drift the swift yet, it's only just done 500kms. But yes, the limited experience with this car and the tests with its "Markenbrüder" say yes, you're absolutely right - Bret
  24. alles im Wiki. Grundsätzlich unten am A-Säule, und der im Motorraum unter der linke Scheinwerfer wäre auch ein guter Ansatzpunkt. Baud auf 96008N1 senken wenn möglich. Und vielleicht mit ein anderes Kabel prüfen.... - Bret
  25. welchen Software und Adapterkabel? Baudrate geändert, wenn es unter Windows läuft? P1314 scheint ein Gemisch oder Kat Problem mit Bank2 zu tun zu haben, ich würde aber eigentlich die Fehlermeldungen erst löschen und dann schauen welches genau zurückkommt. - Bret
