Bala_de_plata
Alle erstellten Inhalte von Bala_de_plata
firmware v2.9.4_b40 27.09.2022 Firmware updated. Changes: - fixed display of the current gear for automatic transmission (in “PRNDS+1234” mode) - fixed CAN bus selection in CAN monitor (TT8J) firmware v2.9.4_b39 21.09.2022 Firmware updated. Changes: - fixed display of data on the chart in diagnostics - fixed bugs in changing some settings in the menu - updated display of parking sensors - added transition to the service settings by the “service” button (А48Е) - added confirmation of resetting Trip data - added custom color settings
firmware v2.9.4_b38 Changes: fixed bug in Russian font added the ability to display data from diagnostic on the main screen changed menu structure (Design) fixed display of Russian in RNS-E audio data fixed work with CAN-buses (Comfort and Info) fixed minor errors in the menu and data display
firmware v2.9.4_b37 31.01.2022 Firmware updated. Changes: fixed display of parking sensors updated code for working with parking sensors A6/A8 updated list of available blocks for diagnostics fixed work of diagnostics for KWP2000 sleep order changed changed the output of messages about malfunctions of DHRC/AFS systems speedup graphics processing fixed update of navigation data on A4 B7 (clusters with a color screen) added information about ESP/ASR for TT8J added output of messages about malfunctions of the steering system (PQ35) added function to display data from OPS A6/A8 to RNS-E PU added rear view BAP-camera emulator (RNS-E PU + OPS) added data output from Extended miniCAN to the main screen, to the OK zone and to gauges added the ability to connect a reverse gear signal to TrInput11 for T4 (manual transmission) added data change effects on the main screen separate data change effect settings for main screen and OK zone firmware v2.9.4_b36 02.05.2021 Firmware updated. Changes: fixed: incorrect display of total mileage on some PQ35 fixed: broken images (Air suspension and TPMS) firmware v2.9.4_b35 25.04.2021 Firmware updated. Changes: fixed: false triggering of low oil pressure (TFSI engines) fixed: blocking of audio data when telematics phone is present
firmware v2.9.4_b36 02.05.2021 Firmware updated. Changes: fixed: incorrect display of total mileage on some PQ35 fixed: broken images (Air suspension and TPMS) firmware v2.9.4_b35 25.04.2021 Firmware updated. Changes: fixed: false triggering of low oil pressure (TFSI engines) fixed: blocking of audio data when telematics phone is present firmware v2.9.4_b34 16.04.2021 Firmware updated. Changes: fixed: some Info-CAN issues fixed: CAN-monitor issues fixed: display current gear while use CCS (manual transmission) updated: air suspension support updated: CNG support updated: optimization of the diagnostic protocol and adding more texts of error codes updated: control buttons usage (MFSW support also updated) added: CCS speed calibration added: advanced service settings added: manual setting for speedup time measure
firmware v2.9.4_b33 05.01.2021 Firmware updated. Changes: changed: sleep mode updated: OPS A3 support updated: OPS A6C6 support fixed: gauge scales for boost pressure fixed: translation for some languages updated: main code for processor hardware added: additional tooltip for gear shifting (manual transmission) added: the ability to connect a reverse gear signal to TrInput15 (A3 8L, TT 8N, Sharan) (manual transmission) added: overspeed alarm by tire index added: display of total mileage and time in the upper area
Nachrüstung der "Einparkhilfe" Teilenr.
Bala_de_plata antwortete auf wufi the master's Thema in Ausstattungen & Umbauten
BN-Pipes Sportauspuff am 1.4er (BBY)
Bala_de_plata antwortete auf Smartrek's Thema in Ausstattungen & Umbauten
BN habe ich noch im Keller...- 33 Antworten
- bn-pipes
- sportauspuff
(und 4 weitere)
firmware v2.9.4_b32 20.06.2020 Firmware updated. Changes: changed: updated support of original TPMS fixed: sleep mode issue (A4(8E), A3(8P), A2) fixed: some small bugs in BAP protocol fixed: coffee-break settings added: support original BiFuel cars (gas + petrol) fixed: small bugs in Extended Info screen added: more values on Extended Info screen changed: faster update ‘boost’ on screen changed: ‘boost’ calibration from analog sources added: Trip2 data to main selection of displayed values (disabled hot key for switching Trip1/Trip2) added: consumption at idle on bottom of screen added: display selectable or fixed data in ‘OK’ area (if there are no errors)
Hallo zusammen, ich hätte eine Frage bzgl. NW-Lager für 1.4TDI BHC. Worin unterscheiden sich 038 103 673A/B/C und welchen Brand würdet ihr empfehlen (KS, Borsehung, Glyco, ET, etc.)? Danke euch!
firmware v2.9.4_b31 29.12.2019 Firmware updated. Changes: fixed: error in TP2.0 and TP1.6
firmware v2.9.4_b30 27.12.2019 Firmware updated. Changes: changed: diagnostic connection mode added: some diagnostics protocols support added: show outside temperature to center main screen added: DDP2 and BAP support for audio/navi (experimental) added: user custom units settings added: coffee-break with distance check added: Trip3 (need enable in hidden menu) changed: average consumption calculation added: some statistics values for TripX fixed: DDP (VW) connection problem in some cars/navi fixed: some small bugs in code and in translations
Einbau ColorMFA mit Bildern bzw Beschreibung der Reihenfolge.
Beide sind mit ColorMFA kompatibel und bei Bedarf nachrüstbar, wenn man das große FIS hat.
Polar FIS ist im Prinzip was Ähnliches: https://www.mft-shop.de/auto-polar/116/auto-polar-fis-mk5/mk6/8p-pf04-mfa-daten-erweiterungs-box In der Beschreibung steht offenbar die Antwort auf deine Frage.
Dreckschleuder 1.4TDI ist einfach durch nix du ersetzen.
@Nagah, geringere Pedalkraft bei der gleichen Bremswirkung.
Der HBZ von VW Bora BJ2001 könnte man einbauen. Allerdings wären folgende Umbauten notwendig: 1) 1x neue Bremsleitung vom ABS-Stg zum HBZ muss bestellt oder angefertigt werden. Beim HBZ vom Bora sind beide Anschlüsse auf der rechten Seite, bei dem vom A2 gibt es je Seite einen Anschluss. 2) Ausgleichsbehälter für die Bremsflüssigkeit vom Polo 9N oder ähnlich. Der vom A2 ist zwar kompatibel, dessen Deckel lässt sich nach dem Umbau nicht mehr öffnen. 3) Der Einbau von einem größeren HBZ wird dazu führen, dass das Bremspedal etwas härter und der Pedalweg kürzer wird. Dahet empfiehlt es sich, den HBZ samt BKV (Bremskraftverstärker) umzubauen. Der vom Bora ist 10", beim A2 ist dieser bloß 8,5" groß.
From Russia with love... Durchschnittsverbrauchsanzeige im KI ohne VollFIS aktiviert man wie folgt. KI: 17 Codierung: 07 AUA: 04045 Die letzte Ziffer muss wohl 5 sein. Danke an Ivan! Gruß, B_d_P
firmware v2.9.4_b29 20.06.2019 Firmware updated. Changes: changed: car images (firmwares b5* and sharan) changed: selection CAN-bus as boost source (if supported in car) changed: oil level calculation added: brightness calibration (for automatic mode only) added: rear gear connection to TrInput12 for A6 (manual transmission) changed: rewrited code for CAN-bus driver and audio/navi protocols added: display Trip2 data on main screen (avg.cons., avg.speed, traveled dist., traveled time) – hold “reset” and immediately press “up”
Das ist echt ein tolles Feature! Nach dem Motorabstellen wird je nach Auswahl ein Logo/Bild Daten von BK1 (Strecke, Zeit, Geschw., Verbrauch) Daten von BK2 (dito) kurz eingeblendet.
firmware v2.9.4_b28 11.03.2019 Firmware updated. Changes: changed: optimizing startup logo and animation fixed: gauges drawing changed: displaying lamp error mode (Sharan) changed: speedup backlight at startup while logo/animation show fixed: compressor error changed: displayed list of ECUs for diagnostics (Audi А3) fixed: some small bugs added: show image/animation/trip data at poweroff (aka “goodbye” mode) added: check rear left sliding door (Т4) added: Slovak translation added: Portuguese translation LogoLoader software is updated 11.03.2019 Software for uploading logo images to ColorMFA is updated to version 1.3 Fixed compressor error. Added some animation logos for download (see Logo_images.rar)
Wie kritisch ist ein weiterer Motorbetrieb mit dem alten KW-Rad? Wie lange hält es erfahrungsgemäß? Gibt es andere Bezugsquellen? Gibt es passende Sätze samt KW-Rad von einem 1.9TDI? Febi 32266 oder SWAG 99 13 2266 werde ich demnächst ohne KW-Rad bestellen.
