problem with audi a2 motor
gianni21
hi guys i've a problem with my a2.
today when i'm traveling on an highway has been ignited a blinking spy like spiral/coil it's color amber.
My speed was 100 km/h and the motor temperature was 90°.
the spy deignited after i was exit by highway...
and it's appear in the city 15 minutes after...
what's happened?
the coolant is ok.
can be the oil?
thank's
Do you have the possibility to have a look at the error memory (ist das richtig für Fehlerspeicher??) ? If not, ask your Audi partner to do so. I think, you'll get more information about it and where the error is coming from.
Anika
Hi!
Could you please tell us which model / engine you have? If your car is a Diesel, I assume it could be one of the injection valves.
If the colour of the "error" message in your dashboard is amber (orange), this means that the misfunction is not critical, and that you are "allowed" to drive carefully, but you should solve your problem within short. Of course, an Audi dealer can check the "black box" upon "error" entries - and will tell you exactly what's going wrong. If he is a nice dealer, he will not charge anything for that simple check.
CU!
Martin
    2. 26
    3. 1.374
      LED anstelle H7
    4. 26
    5. 5
    6. 6
    7. 11
    8. 1
    9. 26
    10. 11
