Guten Tag! Please excuse me writing in English (my German is very limited, - Iam trying to improve it).I would very much appreciate if someone could telll me the correct suspension components to order from Bilstein. I own a 2004 1.2tdi 3L I bought earlier this year in Germany, it currently has the standard factory suspension.I would like to know what part numbers I need for the complete suspension change, (hopefully to the B4 type) 4 dampers, 4 new springs, and any other parts that I need from Bilstein to make it work? (I can't find the front suspension in their website). Also, I was also thinking what other Audi parts I need, any rubber components or things recommended to replace at the same time to make a good job of it all? - I will be keeping the car for hopefully a long time. Sehr grober dank :) David.
There is a working solution for Bilstein B4 Suspension on 1.2. In short for the front suspension: B4 for Polo 6N2 (Bilstein-Part: VNE 4476) in combination with Golf 1 springs (VAG-Part: 171 411 105 G 952), all other parts may be replaced with original parts.
Have a look into this thread as well:
Alternativfahrwerk für den 1.2
All other like B4 or FSB are not allowed here. :erstlesen:
In germany it would require a separate audit (TÜV), but it's not generally forbidden. Don't know how strict the rules in UK are.
Bearbeitet von Phoenix A2
:) Danke, vielen dank fur die antworten. For the rear springs, should I choose bilstein springs, or the original audi springs? I just want the car to ride at the correct height and work as well as possible with the new B4 dampers. My car is a lightweight 3L, no airconditioning.(but it does have a radio). Danke
:) For the rear springs, should I choose bilstein springs, or the original audi springs? I just want the car to ride at the correct height and work as well as possible with the new B4 dampers.
I would just keep the old springs on the rear (if not broken). If in future one of the rear springs needs to be replaced anyway (Spidan springs are a good choice in that case), it is not so much work.
  • 5 Wochen später...
Guten abend .Hatte heute alle Komponenten montiert in der Garage, Golf MK 1 vorderen Federn, Spidan schwere hinten, und BILSTEIN B4. Ergebnis: super gut! :-). Fahrt verwandelt. Großes Dankeschön von mir.:)
  • 1 Jahr später...
      Neuer Schlüssel
    2. 30
      Zahnriemen gerissen 😢 Was nun? 🙏 Euere Expertise
    3. 31
      Von einem, der dachte, von einem Verkäufer einigermaßen fair behandelt zu werden, auch wenn er als Privatperson verkauft
    4. 30
    5. 109
      Anhängerkupplung nachrüsten
    6. 2
      Fensterheber ohne Funktion nach Schaltertausch
    7. 21
      Sitze ausbauen
    8. 19
      Wie am einfachsten Kühlflüssigkeit ablassen
    9. 31
    10. 31
