vor 1 Minute schrieb djrer:
hello everybody i'm french 1.4 tdi ATL
this OK
how to pull out this case
once take off take off
it is blocked by the flywhee
its ok for that.
all the screws are removed
the oil block moves. It blocks at the flywheel
i can up down turn the block but 2cm at flywheel is blocked
i think we can dislabed the block oil whitout remouve gearbox
You have to turn the flywheel maybe 30 degrees from the position you removed the screws.
Try it in 2 stages.
First you can pull out the oil block in front (or backside)of the car and then you turn the flywhell back to remove te oil block completely.
It works.
In the next stage be very carefull to remove the plastic protection. It breaks very easy.
Good luck.
i'm blocked at 2 arrow green
i tried turn the flywheel for to remove i tried front and backside
Bearbeitet von morgoth
ETKA Bild entfernt
      BHC - Ölstandssensor defekt?
    2. 446
    3. 446
    4. 891
    5. 92
    6. 18
    7. 90
    8. 90
    9. 5
      Tacho Tausch möglich ?
    10. 5
