4. ATL Treffen 2013 an der Museumseisenbahn in Herscheid Hüinghausen
[1.2 TDI ANY] - HELP: 6.9L/100km
The stock Turbo is capable of doing 120 HP so I question the necessity of an upgrade Turbo especially since a bigger turbo usually does not spool up that fast. -
66
Fixed all the leaks from intake and added some superglue to the vacuum pump (there was no smoke coming out of it anymore). The turbo o-ring for the intake was a little hard to find but got one in the end. It is a different car now. It does not rattle so much in eco mode. It is a pain to drive 50km/hr (it rattles a bit because it shifts in 5th gear in eco mode). The consumption seems to have gone 1L down compared to the previous test I done in this topic last year. In eco mode mixed - mostly external I get now 3.9L/100km. In normal mode when i arrived at home after the steep hill the consumption was 4.4L/100km. I will be back with some city consumption after at least a month. (i do not drive the car that much ). STILL one weird thing: When pressuring the vacuum hoses with the smoke machine I noticed smoke coming from the engine air intake. I suspect that the tandem pump/vacuum pump is not good inside - it does not seal well between oil and vacuum maybe. The vacuum side should not communicate with the engine side/oil side at least not by my logic and knowledge so this might be another big issue. I ordered a new pump from pierburg (it seems to have a better design than the luk version i have on the car) . The new tandem pump price is around 200 euros today in 2024-05 on autodoc24 (the mobile app). This might also explain oil consumption - i taught that the valve seals might be old but now the tandem pump is also on the list. It would be nice if the pump solves the oil consumption too. The smoke test will be done again with the new pump. If the result is different this might be a good way to determine if the tandem pump is broken inside. I expect a big difference with the new tandem pump if not than the injectors and turbo will be next. The new turbo i've been looking at is this one: https://muchboost.com/product/1-2-tdi-hybrid-turbo-upgrade-audi-a2-volkswagen-lupo-seat-arosa-any-ayz/ . But for now i hope that the tandem pump will solve a lot. -
34
Audi A2 1.2 tdi turbo doesn't work properly
Not sure if this topic has a conclusion or not. For me the bad consumption had several sources: 1)The T on the fuel filter (if you have the metal version -- the older ones) -It was cracked and air got into fuel system. 2)Air intake leaks -- on the oil stick pipe one o-ring was missing - after plugging this there was a big improvement. Also check the oil level sensor for missing or worn out orings. 3)air leak near turbo intake hose -- the o-ring was warn out and turbo was aspirating false air. 4)tandem pump might be defective inside - this is yet to be proven after I replace the current one with a new one. Find updates on my post. Usually the older version of tandem pumps had that issue with the hose plug getting loose BUT also with the seals between oil side and fuel side and vacuum side. You need to get a smoke machine for detecting leaks. You would not believe where the leaks are until you test for it. The car runs well with this leaks also and you cannot find anything specific on vag-com or computer diagnose. -
11
Programm für das Jahrestreffen vom 05.07. bis zum 07.07.2024 am Grohnder Fährhaus
Teilnehmerliste Programm: Abendessen für bis zu 20 Personen am Freitag 05.07.2024 im Grohnder Fährhaus: Nupi Tatzino Durnesss DerWeißeA2 Everconnect Abendessen für bis zu 40 Personen am Samstag 06.07.2024 im Grohnder Fährhaus: Nupi Tatzino Durnesss Audifanatiker + 3 Personen DerWeißeA2 alleswirdgut2 + 1/2P a2-701 Everconnect -
145
Anleitung: Trommelbremsen hinten auf Scheibenbremsen umbauen
Sind gleich.- 1
- anleitung
- hinterachse
(und 3 weitere)
das muss ich nochmal zurückholen. Bei der letzten HU habe ich den DEKRA- Ing. gefragt, ob es denn zulässig wäre, die Scheiben hinten gegen Trommeln zu tauschen. Er meinte, da soll ich mal den Meister der Werkstatt, in der ich zur HU war, fragen. Deshalb noch eine Frage an das Forum: Sind Hauptbremszylinder und Bremskraftverstärker bei Trommel und Scheibe gleich? Oder gibts da Unterschiede? Wenn nicht gleich, wär DAS ein echter Hinderungs-Grund- anleitung
- hinterachse
(und 3 weitere)
[1.2 TDI ANY] Schaltprobleme mit der Automatik. Rückwärtsgang und 3 Gang geht nicht mehr rein.
Ok, danke erst mal. Werd mich mal am Wochenende unters Auto legen und schauen was ich tun kann. -
11
Copy&Paste von awg2 ... ergänzt mit Datumsangabe (sorry, neuer Berufshabitus). Teilnehmerliste Programm: Abendessen für bis zu 20 Personen am Freitag 05.07.2024 im Grohnder Fährhaus: Nupi Tatzino Durnesss DerWeißeA2 Abendessen für bis zu 40 Personen am Samstag 06.07.2024 im Grohnder Fährhaus: Nupi Tatzino Durnesss Audifanatiker + 3 Personen DerWeißeA2 alleswirdgut2 + 1/2P a2-701 PS Speicher Einbeck Hauptausstellung am Samstag 06.07.2024. Hier gibt es eine Gruppenermäßigung. Man kann auch mit Führung buchen. Liegt auch an der Teilnehmerzahl. Nupi Tatzino Durnesss Audifanatiker + 3 Personen DerWeißeA2 alleswirdgut2 + 1/2P a2-701 Für dem Freitag gibt es kein festes Programm. Aber es gibt Vorschläge: Einen Stadtbummel in Rinteln https://de.wikipedia.org/wiki/Rinteln Besuch des Jahrtausendblick https://www.rinteln.de/freizeit-und-kultur/freizeitziele/freizeitziele-in-rinteln/jahrtausendblick/ Das Kaiser Wilhelm Denkmal bei Porta Westfalica https://www.kaiser-wilhelm-denkmal.lwl.org/de/- 3
11
Teilnehmerliste Programm: Abendessen für bis zu 20 Personen am Freitag im Grohnder Fährhaus: Nupi Tatzino Durnesss DerWeißeA2 Abendessen für bis zu 40 Personen am Samstag im Grohnder Fährhaus: Nupi Tatzino Durnesss Audifanatiker + 3 Personen DerWeißeA2 alleswirdgut2 + 1/2P PS Speicher Einbeck Hauptausstellung am Samstag. Hier gibt es eine Gruppenermäßigung. Man kann auch mit Führung buchen. Liegt auch an der Teilnehmerzahl. Nupi Tatzino Durnesss Audifanatiker + 3 Personen DerWeißeA2 alleswirdgut2 + 1/2P Für dem Freitag gibt es kein festes Programm. Aber es gibt Vorschläge: Einen Stadtbummel in Rinteln https://de.wikipedia.org/wiki/Rinteln Besuch des Jahrtausendblick https://www.rinteln.de/freizeit-und-kultur/freizeitziele/freizeitziele-in-rinteln/jahrtausendblick/ Das Kaiser Wilhelm Denkmal bei Porta Westfalica https://www.kaiser-wilhelm-denkmal.lwl.org/de/- 2
32
Jahrestreffen 2024 Unterkunft
Nupi & Tatzino Hotel Grohnder Fährhaus (05.07-07.07.) durness Zelt (5.7.-7.7.) DerWeißeA2 Zelt (05.07-07.07.) Carpinus Hotel Grohnder Fährhaus (05.07.-07.07.) vembicon Zelt (5.7. - 7.7.) Audi-LK Mobilheim Grohnder Fährhaus (0507. - 07.07.) Auditom im Kip Shelter (6.7.) Unwissender & Frau Hotel Grohnder Fährhaus (05.07-07.07.) Audifanatiker mit Familie Mobilheim Grohnder Fährhaus (05.07. - 07.07.) mamawutz + Frau Hotel Grohnder Fährhaus RS655 + Copilotin Hotel Grohnder Fährhaus (05.07.-07.07.24 Everconnect , wohne in der Nähe FeWo Phoenix A2 Hotel Grohnder Fährhaus (05.07.-07.07.) A2 Papayaorange, Hotel Grohnder Fährhaus (06.07.-07.07.) AudiA216RS, Hotel Grohnder Fährhaus (06.07-07.07.) LeBodo - Britta & Clemens + Dackel / Camping 05. - 07.24 alleswirdgut2 - Jan & Nachwuchs / Zelt 05.07. - 07.07.
