McFly Geschrieben 17. Oktober 2015 Geschrieben 17. Oktober 2015 Cool. Would you mind spending a few words on how you did this (procedure, products)? Is this also helping with the micro cracks that are visible on more or less all older lights with the clear plastic cover? Thanks, Michael Zitieren
herr_tichy Geschrieben 17. Oktober 2015 Geschrieben 17. Oktober 2015 Friendly reminder that, if you want to communicate with pocoloco, English is the weapon of choice. Zitieren
Aluminum_Bullet Geschrieben 17. Oktober 2015 Geschrieben 17. Oktober 2015 Amazing! I'll send you the headlights from my A6 :D Zitieren
pocoloco Geschrieben 17. Oktober 2015 Autor Geschrieben 17. Oktober 2015 Cool. Would you mind spending a few words on how you did this (procedure, products)? Is this also helping with the micro cracks that are visible on more or less all older lights with the clear plastic cover? Thanks, Michael You have an hour to the barns, myself have done the steps 320/400 /500/ 600/1000 / 1500en last 3000met water sanded .The first step 320 there you can see what you get out , which is a kind of protective layer that mat is beaten or crushed stone has . After that all the steps actually polishing.The headlights popping certainly very much , but a little on the inner side is you do not get away .I once had a leak and now I see calcification in the headlight Zitieren
Romulus Geschrieben 17. Oktober 2015 Geschrieben 17. Oktober 2015 Some small additions, as Google Translate is not that smart with technical words... You have to sand them for an hour, myself have done the steps 320/400 /500/ 600/1000 / 1500 and last 3000 wet sanded .The first step 320 there you can see what you get out, which is a kind of protective layer that went mat or has pitting. After that all the steps are actually polishing. The headlights certainly improve very much, but a little on the inner side is you do not get away. I once had a leak and now I see calcification in the headlight Nice job George! I had this done three years ago on my A2 too and the head lights still look like new. It is a problem that occurs very frequently on cars of this age with plastic head light units, although the A2 is usually not that bad. The operation improves the looks of the car so much Zitieren
Klassikfan Geschrieben 17. Oktober 2015 Geschrieben 17. Oktober 2015 (bearbeitet) Interessant.... Scheinwerfer "neu zu lackieren", hätte ich ohne diese Fotos für einen Aprilscherz gehalten.... Aber mit Lackieren ist es, meinen Recherchen zufolge, nicht getan, oder? Naßschleifen gehört wohl auch dazu? I Und bekommt man damit diese Mikrorisse in den Scheiben weg oder sind die tief im Material? Bearbeitet 17. Oktober 2015 von Klassikfan Zitieren
Nagah Geschrieben 17. Oktober 2015 Geschrieben 17. Oktober 2015 Das hat er ja geschrieben: In mehreren Gängen von 320er bis 3000er Nasschliff und dann versiegeln. Zitieren
aluboy Geschrieben 17. Oktober 2015 Geschrieben 17. Oktober 2015 (bearbeitet) Hatte im Sommer ebenfalls beide Scheinwerfer von extremer Vergilbung und netzartiger Micro- rissbildung befreit. Die Microrisse befanden sich ausschliesslich auf der Scheinwerferaussen- seite. Erhielt Top Ergebnis nach Schliff -> Politur. Behandlung vollständig in Handarbeit mit Schleifklotz und Microfaserpoliertuch. 5 Stunden Zuwendung für beide Scheinwerfer. Wichtig: Schliff nur im Kreuzgang ( längs und quer ) keinesfalls Kreise. Immer Wasserfilm zwischen Schleifpapier und Scheinwerferglas. Schleifpapier öfter in Eimer tauchen, um Partikel abzuspülen. Nach der Politur muss jährlich 2-3 mal ein UV-Schutz aufgetragen werden, um erneute Vergilbung zu unterbinden. Wasserschleifpapier ( Korn 400 - 3000 ) Politur: SONAX Kratzer Entferner Kunststoff NanoPro UV-Schutz: Maguiars Headlight Protectant Wiederaufbereitete Scheinwerfer wurden nicht lackiert, da sich der Lack im Laufe der Zeit durch Steinschlageinwirkung wieder löst. Darauf muss gesamte Wiederaufbereitungsaktion erneut aus- geführt werden. Vorteil unlackierter Scheinwerfer: Das Scheinwerferglas kann jederzeit punktuell aufgefrischt werden. Restoreergebnis beider Ab- schlussprozeduren ( Politur mit UV-Schutz ; Lackierung ) nahezu identisch. Preislich wesentlich interessanter, da kein Lackierer bemüht werden muss. Bearbeitet 18. Oktober 2015 von aluboy Zitieren
Klassikfan Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 Das hat er ja geschrieben: In mehreren Gängen von 320er bis 3000er Nasschliff und dann versiegeln. Mei Inglisch is not se best! Zitieren
McFly Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 UV-Schutz: Maguiars Headlight Protectant Wiederaufbereitete Scheinwerfer wurden nicht lackiert, da sich der Lack im Laufe der Zeit durch Steinschlageinwirkung wieder löst. Ah, genau das hatte ich mich bei pocoloco gefragt weil nur polieren den UV-Schutz wegnimmt. Den Eingangspost hatte ich dahingehend verstanden, daß im Anschluß ans Schleifen ein Klarlack drüber gekommen ist. Also schleifen, polieren, und mit UV-Schutz "eincremen", was aber häufiger wiederholt werden muß. Ich hatte gehofft, das man statt Polieren nach dem letzten Nassschleifgang direkt einen Klarlack verwenden könnte um die Scheiben zum einen wieder klar werden zu lassen, und zum anderen eine gute Haftung zu erzielen da auf der noch schleifrauen Oberfläche lackiert würde. Bin ja eher so der Typ, der lieber fünf Jahre nix macht und dann einmal etwas mehr, statt regelmässig am Auto rumzupflegen... Cheers, Michael Zitieren
vfralex1977 Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 es gibt doch auch klarlack, bei dem der UV-schutz drinnen ist. alternative? Glasurit | Glasurit 923-109 HS-UV-Klarlack Zitieren
Kawa-racer Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 Oder nachm lackieren eine Folie drauf Zitieren
Romulus Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 Mein Lackierer hat anschließend wieder mit Klarlack versiegelt, so daß UV-Schutz gegeben ist. Jedenfalls habe ich seitdem nichts außer normaler Pflege daran gemacht. Zitieren
aluboy Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 (bearbeitet) @ McFly Das Meguiars Headlight Protectant wird 2-3 mal jährlich auf dem Scheinwerferglas aufgebracht. Dazu etwa bohnengrosse Menge UV-Schutz Paste in kreisenden Bewegung ca. 1 Minute lang mit einem weichen Lappen einarbeiten. Fertig. Wirklich kein grosser Act. Die Lackierung platzt wegen Steinschlag über kurz oder lang wieder ab und bildet unschöne Schadstellen, die sich weiter ausbreiten. Wie es sich mit der Lacktrübung verhält, noch garnicht abzuschätzen. Abge- platze Lackbereiche am Scheinwerfer kann man nicht mehr so einfach austupfen, wegen dem unter- schiedlichen Lichtbrechungsverhalten. Dann muss also alles wieder abgeschliffen und neu aufgebaut wer- den. Mit Lackieraufwand sehr teuer. Politur mit UV-Schutz Versiegelung kann immer leicht aufgefrischt werden. Es darf m.W.n keine Folie auf das Scheinwerferglas geklebt werden, da das Lichtbrechungsverhalten bzw. Leuchtkraft zu stark beeinträchtigt wird. Über die Jahre trübt Klarsichtfolie auch ein. Ob der Tüv die Folie ignoriert ? Bearbeitet 18. Oktober 2015 von aluboy Zitieren
Kawa-racer Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 @ McFly Das Meguiars Headlight Protectant wird 2-3 mal jährlich auf dem Scheinwerferglas aufgebracht. Dazu etwa bohnengrosse Menge UV-Schutz Paste in kreisenden Bewegung ca. 1 Minute lang mit einem weichen Lappen einarbeiten. Fertig. Wirklich kein grosser Act. Die Lackierung platzt wegen Steinschlag über kurz oder lang wieder ab und bildet unschöne Schadstellen, die sich weiter ausbreiten. Wie es sich mit der Lacktrübung verhält, noch garnicht abzuschätzen. Abge- platze Lackbereiche am Scheinwerfer kann man nicht mehr so einfach austupfen, wegen dem unter- schiedlichen Lichtbrechungsverhalten. Dann muss also alles wieder abgeschliffen und neu aufgebaut wer- den. Mit Lackieraufwand sehr teuer. Politur mit UV-Schutz Versiegelung kann immer leicht aufgefrischt werden. Es darf m.W.n keine Folie auf das Scheinwerferglas geklebt werden, da das Lichtbrechungsverhalten bzw. Leuchtkraft zu stark beeinträchtigt wird. Dann darfst du auch die Scheinwerfer nicht abschleifen geschweige lackieren Und nein, ordentliche Folie ändert nichts an der Helligkeit. Zitieren
aluboy Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 @ Kawaracer gleichmässiger Schliff, mit darauffolgender Politur und Versiegelung ändert nichts am Strahlverhalten des Scheinwerfers. Kam kein Lack auf meine Scheinwerfer ( Schliff - Politur - UV Versiegelung ). Fertig. Zitieren
Kawa-racer Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 Glaub mir... schleifen ist verboten. Sollte ein TÜVer feststellen das geschliffen wurde fliegst du durch Durch das Schleifen kannst du keinen gleichmäßigen Schliff garantieren. Lackieren wäre mir lieber da dadurch diese Regenbogenfarben wiederkommen. Zitieren
Frank8143 Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 Hi Pocoloco, i had an idea like you, but to see what a profssionel car varnisher, is able to do, was very interesting for me. There is only one problem: The german TÜV doesnt like it, polishing is ok but no paint. In 90% they will not recognize it, but if there is only one dustpoint, problems rise up. If it so perect like your work, it would fit to the shine of your red_snail, no one will say annything. We will meet us in Legden, i am the second copter pilot there Best regards Frank Zitieren
aluboy Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 (bearbeitet) @ Kawaracer also lieber Kawaracer, wenn der Scheinwerfer nach der Prozedur vergleichbaren Neuzustand zeigt, dann kann der Tüv nichts feststellen. Habe ja schliesslich schon beide Scheinwerfer aufbereitet. Nach dem 3000er Schliff wird noch poliert. da sind keine Schleifriefen mehr auszumachen. Versiegelung härtet auf Scheinwerfer aus und schimmert. Gleichmässiger Druck erzeugt gleichmässigen Schleifabtrag. Tip vom Schreiner und Industriedesigner. Und wie der Aufbereitungsprofi " Frank 8143 " unter deinem Post schreibt: " There is only one problem: The german TÜV doesnt like it, polishing is ok but no paint. In 90% they will not recognize it, but if there is only one dustpoint, problems rise up. additionally: " As soon paint coat starts peeling off, german-Tüv denies Tüv-sticker " Ein völlig verlebter Scheinwerfer ( Vergilbungen, Eintrübungen, grauslige Micronetzrisse ) muss immer abgeschliffen werden. Sobald die Lackierung aufgrund Steinschlag abplatzt, erkennt der Tüv die Lackierung -> neue Scheinwerfer. Sinn von Folie auf Lackierung mal ganz dahingestellt. Ich will hier nur darstellen, wie einfach und kostengünstig ein dauerhafter Aufbereitungszustand erzeugt werden kann. Alle anderen können natürlich teuerere und anfälligere Massnahmen er- greifen. Der Tüv wird euch schon darauf hinweisen, wann denn der Scheinwerfer zu wechseln ist. Sobald der Politureffekt einwenig nachlässt, einfach nochmal kurz mit Lumpen drüberpolieren und wieder versiegeln. Lackiermethode lohnt nicht, da zwei neue Scheinwerfer schon für 150 Euro/Stück erhältlich. Dann gleich Fabrikneu. Bearbeitet 18. Oktober 2015 von aluboy Zitieren
pocoloco Geschrieben 18. Oktober 2015 Autor Geschrieben 18. Oktober 2015 Dustpoint no problem Zitieren
pocoloco Geschrieben 18. Oktober 2015 Autor Geschrieben 18. Oktober 2015 There are several methods to restore your headlights again .Some use toothpaste , others do the polishing.But it always comes back and you must do it again. I have shown how it is done in Holland with professional companies. That does not mean that I reject the other methods , certainly not.Everyone should do what he thinks best. Zitieren
aluboy Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 (bearbeitet) @ pocoloco yes it´s true, refurbished headlights ( sanded, polished an treated with UV-Protector ) loosing their gloss over time. But it takes only a view minutes to bring them back into " Life ". Frontlight´s don´t have to be sanded again. So treat them with a soft towel ( Polish and Sealing ) in a very short process. Since new Headlight´s cost 300 Euros a pair, for me it´s a better deal to buy new one, than paint coating. greetings Bearbeitet 18. Oktober 2015 von aluboy Zitieren
pocoloco Geschrieben 18. Oktober 2015 Autor Geschrieben 18. Oktober 2015 You're right , it's not cheap. Probably read little German A2 members the Dutch A2 forum because they do not understand. I have 14 Nov organized a winter meeting to prepare the A2 For the winter , this is in the bodyshop of my wife . I give a workshop with 15 members as to their headlights like new There are 15 members in the workshop, the price is as true of 25euro per headlight .Normally cost a headlight repair between 125/175 euros. corpse me a good price for your headlamps have to be new or not ? Zitieren
aluboy Geschrieben 18. Oktober 2015 Geschrieben 18. Oktober 2015 (bearbeitet) @ pocoloco your work is always exceptional. ( Except Brake Caliper Plastic Cover :D) Your workshop, bringing back worn out Headlight´s into Life for 25 Euro´s is a bargain. But paying 125-175 Euro´s for refurbishing one piece is crazy. Here you can order Headlight´s from Valeo ( Producer of original Audi Headlamps ). The prices have dropped to 127 Euro and 137 Euro. One pair for 264 Euros. Brand New. DAPARTO – Hauptscheinwerfer (Hauptscheinwerfer, -Einsatz) Audi A2 [8Z] 1.6 FSI Bearbeitet 18. Oktober 2015 von aluboy Zitieren
pocoloco Geschrieben 18. Oktober 2015 Autor Geschrieben 18. Oktober 2015 @ pocoloco your work is always exceptional. ( Except Brake Caliper Plastic Cover :D) I love them:D:D:D Zitieren
