12 hours ago, Mankmil said:
I actually have two of them now, but haven't installed either of them yet. I did take the sensor apart, though.
It's built a little differently, and I have some doubts that it measures exactly the same thing as the original.
Do they stop the error in the dashboard? in fact that is the most annoying part. If the error in the dashboard disappears it's worth it.
It looks like the thinner version does not have minimum level detection. The original has a small strip at the end that looks like it would trigger when the minimum is met.
You have to be careful to read the oil level like any other normal person with the stick:)) but again if the annoying error disappears from the dashboard than is worth it.
vor 1 Stunde schrieb TitusM:
To reach this goal, you just need to install any kind of VAG 3Pin Oil-Level sensor somewhere in dry in the engine compartment.
But you need to install it in such a way so it would not trigger "low oil level" alert. Unfortunately is not that easy in this case but you could somehow get a normal oil sensor and make a contact on the level circuit so it does not trigger the error.
This could work indeed for some people.
Bearbeitet von TitusM
correction
vor einer Stunde schrieb Mankmil:
Und das gibt dann keinen Fehler, wenn der Sensor nicht im Öl hängt? Was zeigt VCDS dann für einen Ölstand an?
vor 52 Minuten schrieb TitusM:
No, I don't know why, but a dry sensor mounted to the harness calms any error messages.
Why shouldn't it be as easy as that? All you need is a cheap oil level sensor and some cable ties
vor 20 Minuten schrieb A2 HL jense:
Nein!
Keine Ahnung, aber das ist ja auch nicht wichtig, wenn man die Fehlermehldung so umgehen möchte..
Bearbeitet von Mankmil
Moderator:
Gents,
just a friendly reminder that this is the English language part of your beloved A2 friends board. So it would be highly appreciated if you would try to stick to that language instead of posting in German. :TOP:
Oder auf "gut Deutsch": Hier nix schreiben auf Deutsch! :D
Thanks a lot!
IT WILL...
There will be a new error: LOW OIL LEVEL for sure. I tested and that is what is shows. If there is no oil to actually set the level.
It is a oil level sensor...if there is no oil there is no medium to make contact on the film that is in the pictures -- hence: LOW LEVEL warning appears instead of sensor error.
After a Motor conversion (to AUB) I drove severly years with an original Audi oil level sensor placed above suspension in a dry plastic bag. No warning, no problems. Sometimes the sensor "felt down" and a warning comes up, so I have to replace the sensor again in a "good" position.
21 minutes ago, A2 HL jense said:
There are people driving around with dry sensors and no warning, it probably depends on the sensor you tried?
That might be -- the audi oem version.
It is even annoying sometimes that it raises the low oil level warning but when i check the dip stick it is ok. It is related to that switch in the bonnet that resets the oil level only.
vor 58 Minuten schrieb TitusM:
That function is really weird, because i doesnt reset right away when you open the bonnet, it just kills the warning for some time and you have to drive 15 or 50 km or somethimngs to see the new oil level in the system if i remeber that right.
Ich hatte mit einem Verkäufer auf kleinanzeigen Kontakt, bei ihm scheint es zu funktionieren.
Moderator:
I was in contact with a seller on classifieds; it seems to work for him.
Am 20.1.2026 um 11:45 schrieb TitusM:
i think the sensor senses by heating up with a certain current and measuring the resistance + cooling down time, so you can fill any  VAG Sensor with any kind of potting, i once used a dummy filled with silicon glue until i repaired the original one.
so the sensor always senses "full"-no low oil level alert any more.
vor 3 Stunden schrieb GeS:
Funny enough, you don't need to fill the dummy's at all. They think it is full with anything, in this case it's air.
Am 21.1.2026 um 10:58 schrieb A2 HL jense:
That function is there for a reason. Since it takes several hours to adjust to the now proper oil level, the lamp still indicates too little oil. People would simply overfill.
Try  to disconnect the service flap sensor, wait until the oil warning comes on, refill, and you will see that the oil warning will remain for quite some time.
Am 21.1.2026 um 09:15 schrieb TitusM:
IT WILL...
vor 43 Minuten schrieb Lupo_3L:
Who is right here?
@Mankmil also says, no error at all with a dummy sensor.
Bearbeitet von A2 HL jense
Hi guys, got mine now from same seller (without the extra package as you guys). Might be a stupid question, but I don't have the car at the house right now to check. Is there an easy way to install it without having a way to go under the car?
Only found that instruction:  https://a2-freun.de/forum/forums/topic/7615-12-tdi-any-%C3%B6lstandssensor-spinnt/#findComment-524217
Bearbeitet von Michael.k
Zitat
I offer a new oil level sensor for the Audi A2 1.2 TDI of the years 2001 to 2005 with MKB ANY.
Original part number 045 907 660B.
These are originally packaged new products from Chinese post-production. The minimum order quantity was 2 pieces.
The other copy I have installed in my own car, works perfectly without error message.
Another one working properly.
https://www.kleinanzeigen.de/s-anzeige/oelstandssensor-a2-1-2-tdi-045907660b-any/3315748185-223-1017
Just make sure you have the orings on. Mine came without the dipstick o-ring.
If you do not install a dipstick oil you will have an air leak there and possibly some small oil leak.
I detected mine only when i put the smoke machine on the car.
The aliexpress version arrived also. I did not have time to test it. It has no codes written on it of any kind. The construction seems fine.
  • 1 Monat später...
Am 6.2.2026 um 08:46 schrieb A2 HL jense:
I bought this exact sensor a few days ago on eBay Kleinanzeigen after my original sensor failed. After replacing it, the error disappeared. After about 100 km, the "Oil Min" warning appeared. So I topped up the oil according to the dipstick until I thought it was okay. Then, shortly after, the "Oil Min" warning reappeared. This time, I watched the dipstick very closely and added a little more oil (a total of 1 liter). Then it was fine again, but after another 100 km, the "Oil Min" warning came on again.
Since I know there's now enough oil in the engine and my car isn't leaking, I unfortunately have to assume that the oil level sensor from Alibaba isn't a solution either. Perhaps someone has had better experiences with this?
Thank you for sharing this experience. That the message will be calmed for some 100km is triggered by opening the service flap. So, to check what values the Chinese delivers, you should read the values from the ECU with a tester.
  • 1 Monat später...
Hi Mankmil,
it‘s a strange behavior. The oil level jumps up and down while the car is in parking position and the engine didn‘t run. See the attached picture.
Yesterday I also changed the oil and filled up the exact amount of 3,8 liters.
BR Mäddis
Bearbeitet von mäddis
      Ladedruck ATL nach Turbotausch
    2. 5
    3. 88
      Quelle für neue A2 Scheinwerfer gesucht
    4. 60
      TÜV - Lizenz zum Gelddrucken?
    5. 22
      Einbau Standheizung
    6. 2
      DWA deaktivieren?
    7. 31
      [1.6 FSI] Probleme beim Kaltstart und Aussetzer im Leerlauf
    8. 85
      Leitfaden zum Nachfüllen des Getriebeöls
    9. 14
      Tankgeberschlüssel
