[1.2 TDI ANY] hydraulic oil pump constantly running
Sorry that I am writing in English. Like all of you my Audi a2 1.2 tdi have a problem with gears shifting. I spend a lot of time to read all problem related forums but didn’t find solution. My A2 hydraulic   pump was running all the time, and I decided to change an accumulator tank. I bought new one Febi (with adaptor) and use one with a pump from my friend (5-6 gear changes before starts pump). Clutch disengaged at 1.84v and engaging 3.85. Did basics adjustments. Problem: pump is running constantly when engine is on. Car starts in S and N but won’t run. When I change to D or R car engine is revving but not drive because clutch is ON. VCDS group 3 showing Clutch position (Actual) 99.6% and Clutch position (specified) just running in a circle from 2% to 75% and back. Some time, when I start a car in N and then to D is disengage clutch and it drives and changes gears, but pump is running constantly. There is no leakage in a system. I on the way to buy a new clutch cylinder, but not sure it will help, and is not so cheap just to buy it and try. Can someone have advice?
There is video from VCDS:
You say pump is running constantly. Question number 1.: Is there enough hydraulic fluid in the system?
The pump should definitely not run constantly. Even with a bad pressure accumulator it would not constantly run.
Hydraulic fluid I changed to new and level is correct. When I open a door ,pump is running for maybe 30 sec, then stops until I start engine. Then will run again 30sec. Will stay until press a brake or trying to change a gear. When test run a car, I hear that pump is run constantly, because clutch is engaging and disengaging and  gears is changing. Sounds like accumulator tank is bad, but it is totally new and even tried with use one who works perfectly on another car.
Your video don't show the value of the clutch cylinder (G162). As the clutch position is shown at ~100%, the voltage value for G162 should be constant near 4V. Is this correct?
But you write:
vor einer Stunde schrieb Germantas:
Because if the clutch cylinder would be active engaging and disengaging all the time, the constantly running pump would be understandable. But the 100% value would say that the clutch is and stays open the whole time.
Your video, is it in D or N? Does anything change if the motor is not running?
VCDS show 99.6% and voltage is if i remember correctly 3.85v. I did video when engine is running, and gear shifter is in D. When I am starting a car in S position, then go to N and D, engine just revving buy car not driving (my video did in this stage). But, when starting engine in N and then to D, not always but often, clutch is disengaging, and I can drive. I didn't check how is when engine not runs. Will do it today. What more i can try or read with VCDS to be shure there is a problem?
I would check following situations:
Motor off, N
Motor off, D
Motor off, D, brake pedal pressed
Motor on, N
Motor on, D
Motor on, D, brake pedal pressed
What happens in each situation with the G162 value and the both clutch position values?
There are some strange readings.
If you are in N, the clutch should be pulled. And regarding to your readings, it is.
But the target value (clutch position specified) is changing. As it should close.
In N it should never close.
So first - why is the control unit wanting to close the clutch? And furthermore, why is the clutch not closed, if the control units wants to? (even if it is not correct to close the clutch in N...)
You have not filmed the instrument cluster the whole time. I remarked when you selected D, there was no gear shown in the display.
What happens if you change the lever to the left - tiptronic? Are the numbers 1 to 5 shown?
If you do this with motor stopped, you should also be able to change the selected gear with + and -
Did you try to do the basic setting?
"So first - why is the control unit wanting to close the clutch?"
Gearbox in D and no brakes. Clutch need to be closed and car need to drive. This is my understanding. Sorry for video,i not made it to show all. But mostly i will show that car engine starts in S or N, but when switching to D or R clutch still open and car can not drive. And pump os constantly running.
No no,
at 5:06 you are in N and the "Clutch position (specified)" is going down to 0.2%, so the control unit says the clutch should be closed.
In N the clutch should be open. And regarding to G162 and "Clutch position (actual)" it IS open. But the control unit says "close".
So, why does the control unit wants to close the clutch in N? And if the control unit wants this (even if it's wrong), why is the clutch not closed?
There is something total mixed up.
Did you tried the basic setting?
https://wiki.a2-freun.de/wiki/index.php/Getriebegrundeinstellung
Edit: I think this discussion should get it's own thread. Maybe an admin can move it?
Bearbeitet von Eumeltier
You are totally right! Spend lot of time to read English and German forum about gearbox  problems and solutions. Wrote to this forum because i'm confused and can't find a answer what is it. For example, yesterday i just started engine and test drive s car without a problem. Just pump was running constantly. Then i decided to drive a car to a garage and got this problem some was from las weekend when i change accumulator tank ang fluid. From my video you see, when car is in D snd brake is released clutch specific values is moving up and down, but actual is always showing 99.6 %, it's mean clutch is open. Why...?
At this moment I don't see the evidence that the clutch valve is the problem.
The clutch valve needs the hydraulic pressure to OPEN. But it is open. All the time.
Did you see the clutch closed with VCDS? If you just turn the ignition on with the lever on STOP and no break pedal pressed, is the G162 below 2V?
If the clutch is still open, disconnect the electric plug at the hydraulic block and release the accumulator tank 1/4 turn. Then all hydraulic pressure is gone and the pump won't work anymore. At this moment the clutch must be closed.
If it is still opened without hydraulic pressure, I assume a mechanic defect with the clutch itself. Then the new clutch valvue won't help at all.
So I think at first you have to be sure about the reason for the problems before changing any parts.
Yes,i see clutch is closing some times. But you are right, maybe is some mechanical problem and is stuck and some time just release. Now is dark, will try to do the same test, but will try to move by hand a clutch lever. And, if i have this situation, it's mean clutch leaver need to be pulled ans stuck,but clutch valve  cable need to be pulled off?
Bearbeitet von Germantas
If your clutch won't close and you want to exclude that it is because the hydraulic system gone wild for some reason, you have to release all pressure.
https://wiki.a2-freun.de/wiki/index.php/Getriebegrundeinstellung#System_drucklos_machen
I don't know if you can read any german?
- Loose the coolant tank and put it aside
- Remove the black electric plug at the hydraulic pump. So the pump won't work anymore
- Loose the hydraulic accumulator tank by 1/2 turn. So the pressure is released, all hydraulic oil will go back into the reservoir
After this the clutch has to be closed, because there is no more hydraulic pressure left.
If the clutch is not closed, then you have a mechanical problem.
Don't forget to tighten the accumulator tank before connecting the pump again, otherwise the oil will spill...
I know how to do this. I did it more than 10 times. Will do this tomorrow one more time. Funny, i learned a German in school. But it was 30 year ago. And if you not using it  in your life, you forgetting it.
I have 5 pcs. Audi A2. Two is 1.4i,two is BCB( did swap). I decided to buy 1.2tdi and didn't imagine that it will be so complicated:)
8 hours ago, _Manni_ said:
Maybe you start your one thread with information, instead of posting in the KNZ hall sensor repair thread.
Only a hint ;)
I will happy to do this, but i'm not German and don't know how are people reacts when i writing in not forum native language. I can use a google translate, but can't be shure if it translate correctly
vor 1 Stunde schrieb Germantas:
vor 10 Stunden schrieb _Manni_:
You dont need a german passport to start a thread here ;)
And you see... We try to speak english with you without a problem.
  • DerWeißeA2 änderte den Titel in [1.2 TDI ANY] hydraulic oil pump constantly running
Yes, I had this error code with my green 1.2 TDI.
The pump was running after every gear shift. And sometimes the clutch didn't open fast enough when stopping. The problems where solved with a new pressure accumulator.
But I don't think this is the only reason for the problems of Germantas' car.
Now looked to clutch leaver. Clutch cylinder moving it just les ten 10mm. I tried to puch it with bid metal stick, but it can't move . If it stuck,it stuck in very strange position. Maybe pump is running almost without a stop to trying create a pressure to move a leaver. My question is: how hard is to move clutch leaver to open a clutch? I think,a problem is with mechanical clutch parts and to be shure i need remove gearbox.
vor 16 Minuten schrieb Germantas:
I don't think this is logical. According to your VCDS readings the clutch is open and won't close. But the hydraulic pressure is needed to open the clutch. Not to close it.
vor 2 Stunden schrieb Lupo_3L:
When this fault is saved, it's very likely the reason.
I can not imagine that it would be the only reason for all the strange effects.
But if course it should be checked. But Germantas wrote he already replaced the hydraulic accumulator with a new one.
Also we don't know what he has already tried with the car and if this error is real or because some experiments. So it would be interesting if the error comes back after clearing it.
Little of history: A2 is 2005 with milage 240 000km. I bought it two weeks ago. Previous owner told that car drive good,but when engine is warn,it won't start. This is indication of worn injectors gaskets and i replaced it. Can drives well, gears is changing smoothly. I never had before this car and can't compare with another. It was two problem left. One is turbo vastgate accurator not working and gear box hidtaulic pump starting after first gear change. When i checked hydraulic system, recognize that instead of green oil it was filet with red ATF. Don't know why. There was visibal leakage. I bought new Febi accumulator and adapter for it. Replaced correct oil and installed Febi. Did all adaptations. Car car drive,but pump still working almost constantly. I bought nother pump with confirmed working ( 4 gears change) original accumutor,but results is the same. Now after last test drive i got this situation where i explained early and in video
roughly 250.000 km is the milage where problems starts with the "Führungshülse" and the G162 value (therefore Mankmil built the hall effect modification for the clutch cylinder to never have this problem again).
Did the previous owner told you anything about repairs at the gearbox, the clutch itself and the "Führungshülse" ?
If the Führungshülse hasn't changed yet it is highly probable defect - regardeless if this has something to do with your actual problem.
No, previous owner had this car only one year, and drive 5000km. That way i need to investigate or guess what i need to do.  Now ii looks like tomorrow after work i need to put a car on thet lift  and dismount a gearbox. I already contacted Mankmil ,but looks and ask about how to exchange old valvo to new one. Waiting answer
vor 6 Stunden schrieb Germantas:
An Audi A2 3L Not starting has to be specified: starter is not engaging at all, or starter is engaging and spinning the engine, but engine does not start.
Unlikely that all 3 injectors quit at the same time and the basically last forever
And yes, please get a new pressure accumulator. It’s game over and won’t get any better.
Lupo 3L maybe you missed my previous comments. I have 3 pcs. pressure accumulators. One is new Febi with Mankmill adaptor (currently it is installed on a car). Another one is original with confirmed 4 gears changing before pump starts. Last was with a car when i bought and i don't know his condition.  Just one very important moment what I missed when I too much concentrated on a clutch system. Car is always in neutral! Gears are not changing when I move to D or R. On the video you can see VCDS showing "selected gear is LG 3-4” and doesn’t change. Maybe clutch is working, just problem in a hydraulic system because is not creating working pressure? If YES, what part I need to change, clutch valve? What tests I need to do to recognize a problem.
Could you confirm above question? Not staring or starter not being activated?
If hydraulic pressure is too low, the pump would be my first guess.
Bearbeitet von Lupo_3L
vor 4 Stunden schrieb Germantas:
I'm quite sure, your clutch is working fine. You can check the clutch actuator's value in the measurements block #002. The clutch is open at a value >3V
I think you have a problem getting the pressure up to a value where your system operates normally. There is also a measuring block for the pressure-sensor-voltage (I don't know the correct block at the moment). That matches to all what I see on the video. The car accepts gas (engine turns up) so it waits for having enough pressure to put a gear in and release the clutch.
But it never reaches the point where pressure is high enough, so the car doesn't move.
I think you have already tested what happens we you open the door and waits until pump stops. It should stop shorter than 1 minute. If it takes longer, the CU stops the pump to avoid damages (due to overload or dry run).
If this works fine, there could be a problem with the N255 valve or your pressure gets lost in the gear actuator.
A 2nd test could be, to switch on ignition and awaits the pump to stop. If it never stops, there remain several issues. Maybe you can try to put a dedicated gear in and check the pump's behavior. For example if it stops with Reverse gear but goes on in LG3-4 it might be a hint, that the gear actuator cause the trouble.
On the other hand, if it doesn't matter what the gear actuator does but it never stops when clutch is open, the N255 could be the problem.
Have you checked what kind of oil was used in the hydraulic? Sometimes people use read automatic gearbox oil. This destroys all the gaskets in pump and gear actuator.
vor 18 Stunden schrieb Germantas:
vor 7 Minuten schrieb Mankmil:
So I assume this is a very bad situation....
Yes, previous owner instead of green filed system with ATF. I replaced with correct oil and replaced pump unite. There is no visible leakage of oil and just need to guess that there is no internal leakage. Mankmil wrote many interesting things what i need to check. I just confirm, when i open a driver doors pump working about 15 sek then stops. When Ignition ON it almost never stop. I newer checked what is pressure in a hydraulic system because didn't know that possibility to do in VCDS. Today first i will do this. I don't think a clutch have mechanical problem, there was no strange sound or something strange from the clutch. Just after last test drive next day car won't to drive.
vor 4 Minuten schrieb Germantas:
So this is measurement Block 020 field 4
https://wiki.a2-freun.de/wiki/index.php/Messungen_und_Prüfungen_am_automatisierten_Schaltgetriebe_durchführen#Hydraulikdruck_und_Hydraulikpumpe_pr.C3.BCfen
vor 10 Minuten schrieb Germantas:
Thanks to him, he killed the whole hydraulic system. ATF lets all gaskets swell up and they get a consistence like pudding/slime.
I checked O rings in old pump unite, they looks OK. I'm just not undertand why system was filed with not correct oil. There is no visible lekage, and system was not only refiled with ATF but there was no evidens off egsisting Green oil in a system. Will chech gearboz bults, maybe gearbox was removed. Car i bought from ownes son, and he don't know what it was with it.
Today i opened drivers door and pump doesn't start. Looks like it still have a good pressure from yesterday. Ignition ON,pump starts for maybe 15 sek and then it  stopt. I hear at same time gear changed from N( car was in N from yesterday) to 1 gear.Sounds promising. Then i pushed brakes and old history came back. Pump starts immediately and won't stop. Car engine started in S, don't know when, gut gear now is in N and i can't engage to D or R. I stoped engine,switchen off and on ignition and pump now running all the time without a Stop
 VCDS screenshots: Nr.1 when ignition was on, Nr.2. when Ignition, Nr. 3 Engine running.
Screenshot_20250919-155254.Photos2.thumb.png.4c7aafd40dcb9efc743cd3134c03fc4b.pngScreenshot_20250919-155058.Photos2.thumb.png.59deba47db7ad9ae5faf3247f888d27e.png
Look at the G270 values in picture 2 and 3. The value is too low, so you have too low pressure and so the pump is running all the time.
Therefore your system is probably loosing pressure somewhere.
You should better stop trying before you kill the pump.
As I mentioned,  your pump never reaches enough pressure for driving and I'm pretty sure the gaskets were destroyed by the ATF oil.
Ok, this it is gaskets. Gaskets in pump unite, gaskets in gear selector? There is no kits to care all all unites. My pump is from another car and it not runned with ATF oil. Left clutch actuator and gears selector. You mean i need those two parts?
When you took a pump from another car, the gaskets could be still fine. Nevertheless you should use it with ATF oil too long. As you have seen, the pump itself can reach the threshold pressure.
So I think it is needed to replace the gaskets on the valves of the gear actuator. There are 2 parts in the system with a high and low pressure side: pump and gear actuator. Worn out gaskets will lead to a bypass between high and low pressure resulting in problems like yours.
The clutch actuator works differently.
Good morning, friends! Yesterday I removed the gear actuator. From the outside it looks fine, just a bit dirty. One of the pipes (the upper one) is moving/loose in its place, while the other one sits more firmly. Is that normal, or is it a problem?
Now that I have the actuator in my hands, I’m thinking about what to do. To start disassembling it, I’d need spare parts like O-rings, etc. Unfortunately, there are no complete kits available, so I’d have to search and buy everything one by one.
I can buy another actuator in fully working condition for €120–150, but it was removed from a Lupo. I read somewhere that they are the same, only the high-pressure pipes are a different length. Is that true?
    2. 17
    3. 10
    4. 17
    5. 22
    6. 35
    7. 35
    8. 35
