1.4 AUA, Bilstein B6, KAW Federn 50/30: Teile?
ecoangeluk
1. Austauschteileliste "2 Fahrweksueberholung hab ich von andere Thema gufunden.
Aber was brauche ich:
Vorne: Domlager verstarkt order Normaler?
Hinten: Auflage oben 4mm order 11mm ?
2. Wenn mann die H&H Stabilager kauft, sind noch die Gummilager usw dabei?
Vielen Dank!
MfG
Use B8, not B6. The drop is too large for the B6s.
The standard links are fine, that's also what I have in place. The H&R stabis have rubber mounts with, the superpro ones are pretty good but may start squeaking after a while.
- Bret
Thanks Bret,
Alas the 1.4 Benziner is much lighter than the 1.4 TDI and 1.6FSI with KAW Springs so the displacement should be a lot less than those cars? There are several on the A2Freun.de forum who have used B6 sucessfully with KAW Springs. Also KAW seem to use a version of the standard Shock absorber - not short like B8 for their own range? K.A.W. Sportfahrwerk Audi A2 günstig kaufen
Schnelltreker mentioned using shorter ARB drop links a while ago from BMW?
In any case which rear spring rubbers 4mm or 11mm?
Front strut mounts: 6Q0 parts.
Rear spring rubber: try 11mm first.
Use Bilstein B8.
Get SuperPro bushings -> best quality
these parts fit on a2: spf2901-18k (spf2901-22k for 1.2tdi and H&R 33388-2 arb kit), spf3615k, spf2481k, spf2907-70k (not recommended for TDI)
You don't need shorter ARB links for clearance. shorter links -> more understeer.
Yes, and as a former K.A.W 50/30 user with B6 I tell you that: Take B8 all around. Do yourself a favor and use B8. The car will handle way too stiff with the B6 on longer rides. B8 will provide the same performance but with less loss of comfort.
For the "obere Federlager hinten": This depends on the weight of your car: Light A2 (thin) or heavy A2 (thick)
  • 1 Monat später...
  • 3 Wochen später...
    2. 61
    3. 0
    4. 13
    5. 1
    6. 1
    7. 9.979
    8. 6
    9. 13
    10. 26
