_Manni_
A2-Club Mitglied
Alle erstellten Inhalte von _Manni_
  1. Ja sie funktionieren auch... Haben halt nur die Fehlermeldung und man hört zB beim Abschalten der Klima, dass die Stellmotoren noch 2-3x Fahren. Nach dem Anlernen in VCDS laufen sie aber
  2. Here: https://www.kleinanzeigen.de/s-anzeige/audi-a2-1-4-klima-vollleder-tuev-neu/3185081633-216-1930?utm_source=copyToPasteboard&utm_campaign=socialbuttons&utm_medium=social&utm_content=app_ios Special seat color, aber you see the price If you have to pay 1 oder 1500 Eur Tax for importing to denmark ist would be unter 5k. With sunroof and leather
  3. a 10000km: I think you have to look for a 1,4 Petrol A2 Cheaper, faster warm, not so noisy and outside of failed components, the only topic is airtightness. The 1,4 TDI saves you 1-2L/100km, but it is louder and has a oilpumpchain to be changed from 250-300.000km If you dont save money with the tdi (here Diesel is at higher costs of insurance and tax) , cause you drive not so much and turbo kik is not important for you, search for a petrol one
  4. ....
  5. From the Germin sites, for germans setteling to denmark: https://motorst.dk/de-de/privatpersonen/kraftfahrzeugsteuern/zulassungssteuer/berechnung-der-zulassungssteuer-unverbindlich
  6. Yes... What is your goal.... "Third or foured" wagn for collection and a little bit driving. --> ok... if this car looks good for you Daily driving: to expensive .... Daily Driving + adding clima and power steering: No way... buy something else
  7. You try to buy a 3L with manuel clima and want to upgrade to cimatronic ?? Show us a link to the car. Sometimes new users only look at the mileage, but this is not really a quality sign on our cars. Example: a 150 tkm 3L A2 ist 50-100tkm in front of a new clutch, couse the wear of the clutch release bearing sleeve kills the clutch at 200-250 tkm If you by a 200tkm 3L with new clutch you are with less problems on the way as with 150 tkm Identically all seals. They are old in our cars. If it has driven 100 tkm or 200 tkm is not really a difference, but in the 200 tkm car the chance of a owner who said "ohh there are some repairs, lets do all at once" are bigger, then a driver with litte mileage/year
  8. I will happy to do this, but i'm not German and don't know how are people reacts when i writing in not forum native language. I can use a google translate, but can't be shure if it translate correctly You dont need a german passport to start a thread here And you see... We try to speak english with you without a problem.
  9. Sand im Benzin, Wasser statt Diesel: Italien-Sprit mit Qualitätsproblemen? https://www.gmx.net/magazine/auto/sand-benzin-wasser-diesel-italien-sprit-qualitaetsproblemen-41390106 Wenn dein Spritfilter 100ml Wasser frisst ist es natürlich vorbei und bei "Menge" zieht er dann zu viel Vakuum
  10. Maybe you start your one thread with information, instead of posting in the KNZ hall sensor repair thread. Only a hint
  11. Es versucht es
  12. Du weißt doch... einfach kann jeder
  13. Na ja die Teile (ZMS und EMS) sind ja mechansich kompatibel über den Zwischenringeinbau und nicht. 1,4er teilen sich mit den 1,9ern und 105 PS die MQ250 Getriebe, welche auch an den moderneren 1,6er TDIs hängen ( von denen einige sich ja auch die Getriebe eingebaut haben) und da gibbet: Und zur gelisteten Sachs Reibscheibe des ATL: Würde ich jetzt sagen: Sieht gut aus
  14. Zweimassenschwungrad falsch reingebastelt oder umgerüstet auf das von Valeo Conversion Kit ( Einmassenschwungrad mit Zweimassendämpfung ) Und A2 spezifisch die Lücke nicht drin
  15. Ja das gleiche gilt auch für die 1.4 16V Gibt bei uns trotzdem 3 Blöcke, die das in der Werksausbildung überhört haben Aber beim Diesel: Kette der Ölpumpe und Zylinderkopf WG den PDE Elemente / Stützhalter. Danach fahr mal erstmal die 1 Mio km;)
  16. Wo sind die aktiven Klapen ???
  17. Reifen und Montage der Felge nicht vergessen
  18. Stromkreis = Kabel und Stecker. 1. PD Kabelbaum auf Öl prüfen ( Stecker ab ) 2. Widerstand messen der einzelnen PD Elemente --------------------------------------- Dann ist "ohne Aktion" schon vorbei --> Dann muß die Haube ab --> Neue Ventildeckeldichtung --> Dann würde ich Tabula Rasa machen neue PD Kabelbaum und fertig
  19. Passend Lambda/4 abisolieren. # Lambda/4 = 18cm abisolieren oder eben ( wenn zu kurz ) den Innenleiter auf 18cm abisoliert verlängern
  20. Es gibt 2 Generationen und die letztere hat noch zu bekommende Injektoren.
  21. Reinige es doch und puste mal durch den AGR Teil. Ist der dicht würde ich nicht sofort tauschen.
  22. Schau mal nach deinem Sieb. Imho ist das doch relativ fein
  23. Ich habe da leider kein Gefühl... War froh es abbekommen und wieder draufbekommen zu haben. Aber klar. Bei manchen sorgen solche Laschen nicht für einen super halt, verhindern aber Vibrationen über Eck. Thema AMF.. Imho ist die Wanne für alle anderen Diesel. beim 3L ist doch die Ölwanne anders, der war doch anders geneigt. Da VW ja immer die gleichen Zylinderachabstände bohrt wäre der Unterschied mal interessant. Aber doof für dich .... grrrr Hier so in der Art. Ich würde aber nicht Nieten sondern Schrauben mit Schraubensicherung und so groß, dass es im Ölwannensieb hängen bleibt:
  24. Ich finde den cool.... Einen 5 stelligen Betrag für Stahlfelgen ausgeben.... Boah was müßte ich stoned sein und im Lotto gewonnen haben
