[1.6 FSI] Benzin Hochdruckpumpe defekt. Reparatur oder gebr. Bezugsquelle?
Hi As my German skills are somewhat limited (= what I learned in Swedish school as my third language over three-four years, like 35 years ago) I will write this post in English to save you the frustration of reading my bad German texts 😉. One of my A2 1.2TDI (2001) is not always reliable over time. I first noted this last summer when it wouldnt start after a short restaurant visit. I checked that the brake light switch and light was ok, but only after zapping slightly on the cluch wire I managed to get it to start. I could notice uncomfortable cluch control while driving back. After that I checked some clutch values with VCDS followed by a GGE which solved the issue. The car then started and drove well again, as it usually had. But now after taking the car back in traffic after having spent winter standing still in a garage, and driving it some weeks problems started again. I noticed rough clutch engagements after stopping at crossroads, and bad gear changes. I quickly disengaged ECO to avoid engine shutoffs at crossroads and headed home. After turning it off it couldnt start again (as I feared/ suspected). Please see my screenshot from VCDS at this point. What conclusion can be made, if any? I noticee the 12.5% value. Is this the reason for not enabling the starter? I.e has something caused the GECU SW adaptive algoritms to malfunction or what? -
[1.4 TDI AMF] ZK am getauscht - Erfahrungsbericht
Alles klar.... Bin auf der Terrasse und warte auf Lieferung -
10.726
So muss eine Anzeige erstmal von den Fotos aussehen, anständige Auflösung, Wagen sauber innen wie außen. Da hast du schon mal vieles gewonnen. Klar die Feinheiten wird natürlich nur ein A2-Spezi schon auf den Fotos erkennen. Den Text würde ich mal für die Goofy-Abteilung überarbeiten. Es gibt ja auch die Tagesschau in einfacher Sprache. Ansonsten haben die Vorredner ja schon reichlich Input geliefert. In dem optischen und technischen Zustand finde ich den Preis gerechtfertigt. Autoverkauf ist zur Zeit ne echte Lotterie, da gilt es Geduld haben. Mir persönlich wäre er mir...., sagen wir mal zu "Blau". Aber die CS haben eine Fangemeinde und mit deinem hat man sicherlich ein Auto ohne Überraschungen. Viel Erfolg beim Verkauf. -
Maße zum Felgendeckel 8Z0601165F zwecks 3D-Neumodelierung gesucht
Macht eigentlich wenig Sinn die selber zu drucken. Der Aufwand der Nacharbeitung ist zu groß, und lackieren muss man sie auch noch. Es gibt recht gute bei Aiexpress, für sehr wenig Geld. Die müssen nur ein bisschen nachgearbeitet werden.- 1
69
Spoiler/Schwelleransätze der Firma CSR
Da meine Frage nach weiterem Zubehör damals mit nein beantwortet wurde und nun aber doch noch was gekommen ist, gehe ich davon aus, dass das nicht nach außen kommuniziert wird. -
69
Weiß man, ob da noch Ansätze für die Schweller kommen? Nur diese, doch recht tief kommende Lippe, das würde gesamt für mich zu unharmonisch! -
Ist das Projekt eingeschlafen ist gibt es da erfolgreiche Drucke? -
Hi, Springt nun an und trackert vor sich hin. Manni ich mach dir ein Bier auf 💪. signal-2025-05-11-10-41-50-788.mp4 Mp4 ist das video Vielen Dank, werde endlich nach 7 monaten die Parklücke wieder frei machen. Gruß Dani -
[Erledigt/Verkauft] A2 abzugeben
69
Mutig! 😎 Schön wäre es, wenn du dann auch die Heckspoiler ABE hier einstellen würdest! 🤗 DANKE!
