  2. Lange ist es her.... Die Diodenplatte der Lichtmaschine alleine zu wechseln brachte kleinen Erfolg. Ja es war wohl die Nichtladung. Nach Austausch der kompletten Lichtmaschine war das Problem beseitigt. Ladespannung während der Fahrt am Zigarettenanzüder 14,6 V Danke für die Hilfe
  3. Ergänzung: 1. Mein A2, 1,4 Benziner und BBY Ausführung Baujahr 2005. 2. Sind die anderen Anleitungen *.pdf die ich per Flat gefunden habe insgesamt 42 Stück alles oder habe ich da einige übersehen? Anbei Bilder der Datei-Namesliste Sind das alle möglichen Dateien oder fehlt noch was? Danke für eure Hilfe
  4. Gestern
  5. If you do the transmission basic setting, the value of the clutch sensor at closed clutch (typical at 1,8 to 2,0 V) is set to 0% clutch opening. And 100% clutch opening is always the value for closed clutch plus 2,0 V, so just below 4 V. The problem is: if the control unit gets a lower value from the clutch sensor, this value gets the new 0% value. This is done to compensate the abrasion of the clutch disc (clutch gets thinner). But if the clutch sensor is faulty - mostly because of a worn potentiometer - the control unit might get spurious values from the clutch sensor from time to time. So if the control unit gets a reading of 1,0 V because of a faulty sensor, it will set 1,0V to 0% clutch opening. But now - as the value for 100% clutch is fixed to "closed clutch value plus 2,0V" - the control unit will only pull the clutch until the sensor shows 3,0 V - because the control unit thinks, now the clutch is fully open. So the range from clutch closed to opened is totally messed up. Depending on how wrong the values are, the car might still be driveable with hard engaging of the clutch or it is not driveable at all because it will stall the engine if you try to start driving. At least it won't start anymore once the motor is off because the value is out of range. If you do the transmission basic setting again with VCDS, the problem might be gone for some time. My problem was, that I have not seen any single faulty reading during monitoring the clutch sensor value with VCDS for quite a long time. So I wasn't absolutely sure that this was really the problem - although it was the highly probable cause. At the end suddenly I couldn't do a successfull transmission basic setting anymore and finally there were faulty readings visible at VCDS. So I changed the clutch slave cylinder with a renewed one with hall sensor - so never again any problems with faulty readings because of a worn potentiometer. Until now the car is running just fine.
  6. Falls sich noch niemand gefunden hat, gerne per PN melden. Wenn die Felgen nicht zu groß sind bekomme ich diese neben dem ganzen Werkzeug noch in die Kugel.
  7. Wie ist der aktuelle Stand? Bist du fündig geworden?
  8. Schonmal gut zu wissen ... Codieren kann man ja weiter mit VCDS. Ich wünsche mir das nur als Ergänzung, weil mir manchmal der Laptop zu sperrig ist für Logfahrten. Vielleicht finde ich da auch mal einen Anhaltspunkt, warum mein A2 aus dem Start/Stop nur noch ausnahmsweise wieder erwacht. Bye pax
  9. Danke Dir für die Rückmeldung und das Angebot! Kann selbst nicht auslesen - wohne aber auf der richtigen Seite und würde auch mal fix nach Lübeck düsen...
  10. Es ist schon eine geballte Ladung, die Ausstellung. Hatte die nächsten zwei Tage Muskelkater vom lauten Grinsen. Es lohnt sich wirklich, viele mir unbekannte Skizzen und Bilder. Als Audi-A2-Forist hätte ich mich sehr über das Avatarbildchen vom @Manualmediziner als Ausstellungsbestandteil gefreut.
  11. Moderator: Überschrift angepasst. - Nagah
  12. Korrekt. Allerdings spritzt die Düse auch im Homogenbetrieb fächerförmig. Der Kolbenboden ist so gestaltet, dass sowohl im Schichtlade- als auch Homogenbetrieb die Zerstäubung durch die Düse ein optimales Zündgemisch und geringe Emissionen ermöglicht. Wenn die Düse nun ein anderes Strahlbild und entsprechend dadurch eine andere Zerstäubung bzw. Verwirbelung des Kraftstoffs erzeugt, kann das Einfluß auf Emissionen, Leistung, erhöhte Klopfneigung unter Vollast … haben. Kann ich nicht beurteilen, weil dazu müsste man alle möglichen Messungen und Berechnungen durchführen. Da der 016er die gleiche Düsenform wie der 005er Injektor hat, sehe ich eher Chancen mit diesem Injektor und Proboost da was hinzubekommen…
  13. It is easy to dissaemble the manifold shaft and all the flaps. Overall 15min to completely disassemble it. Then you can remove material with a belt sander from the flaps. I would rather do this than grind / sand on the walls of the manifold. It is difficult to reach all areas with the flaps still in place and even more difficult to be precise…. Since sticking flaps are an annoying error and disassembly of the manifold is also a pain in the ass I would make a solid overhaul once, then you have peace of mind for the next 100k mls. But it is your choice what you do.
  14. Der Gutachter war heute da. Jetzt warten wir auf das Christkind und das Gutachten. Ich werde berichten.
  15. Einfach auf der Beifahrerseite unten angeklebt, hält, genauso wie der GypS-Sockel der Dashcam links vom Innenspiegel. Gruß Uli
  16. Was für Gussquerlenker? wenn du den PQ25 Achsträger verbaust musst du auch die PQ25 Blechquerlenker verbauen. Mach doch mal Fotos von den Sachen die du hast oder Schreib die Teilenummern hier rein (Fotos wären eindeutiger) grüße Marius
  17. Hallo, Habe das gleiche Problem, suche auch AC oder ersetzt in AF
  18. Danke, hatte ich auch gefunden. Das sind leider nicht die richtigen LEDs.
