8x17 ET 48 Reifenfrage
[1.2 TDI ANY] hydraulic oil pump constantly running
I checked O rings in old pump unite, they looks OK. I'm just not undertand why system was filed with not correct oil. There is no visible lekage, and system was not only refiled with ATF but there was no evidens off egsisting Green oil in a system. Will chech gearboz bults, maybe gearbox was removed. Car i bought from ownes son, and he don't know what it was with it. -
166
Klingt plausibel... Naja, es war eben schon immer etwas teurer, einen besonderen Geschmack zu haben 😅 Wenn ich bedenke, dass ich für meine 34 Jahre alte und nur 7000x gebaute Corvette ZR-1 16 (ja, SECHZEHN) komplett überholte und flow matched sortierte Injektoren, die auch für diesen Motor spezifisch waren, für um die 800€ bekomme, wird der A2 sogar sehr besonders 🤣 Ergo: mehr Corvette fahren!- 1
40
Thanks to him, he killed the whole hydraulic system. ATF lets all gaskets swell up and they get a consistence like pudding/slime. -
40
So this is measurement Block 020 field 4 https://wiki.a2-freun.de/wiki/index.php/Messungen_und_Prüfungen_am_automatisierten_Schaltgetriebe_durchführen#Hydraulikdruck_und_Hydraulikpumpe_pr.C3.BCfen -
40
Yes, previous owner instead of green filed system with ATF. I replaced with correct oil and replaced pump unite. There is no visible leakage of oil and just need to guess that there is no internal leakage. Mankmil wrote many interesting things what i need to check. I just confirm, when i open a driver doors pump working about 15 sek then stops. When Ignition ON it almost never stop. I newer checked what is pressure in a hydraulic system because didn't know that possibility to do in VCDS. Today first i will do this. I don't think a clutch have mechanical problem, there was no strange sound or something strange from the clutch. Just after last test drive next day car won't to drive. -
Kompatibilität der 02T-Getriebe
Meinst Du den kupplungsseitigen Simmerring? Tausch der Simmerringe der Antriebswellenflanschen ist guter Hinweis . Hat jemand zufällig die Teilenummer dieser Simmerringe parat? -
27
LIVE-Thread - 25 Jahre Audi A2 in Neckarsulm 19.9. und 20.9.2025
Und auch beim Aussteller hängt der Himmel...- 4
18
18
Antriebswellenflasch ausbauen
Ratsam wäre vorher die Kreuzschraube herauszudrehen, um eine Abscherung oder Beschädigung zu vermeiden und dann zwei Radbozen hineindrehen um das Drehen zu blockieren.
