[1.2 TDI ANY] Sammelthread für Kupplungsnehmerzylinder mit Hall-Sensor-Umbau + HINWEIS!
Lupo_3L antwortete auf Phoenix A2's Thema in Technik
You say pump is running constantly. Question number 1.: Is there enough hydraulic fluid in the system? The pump should definitely not run constantly. Even with a bad pressure accumulator it would not constantly run. -
Germantas antwortete auf Phoenix A2's Thema in Technik
Sorry that I am writing in English. Like all of you my Audi a2 1.2 tdi have a problem with gears shifting. I spend a lot of time to read all problem related forums but didn’t find solution. My A2 hydraulic pump was running all the time, and I decided to change an accumulator tank. I bought new one Febi (with adaptor) and use one with a pump from my friend (5-6 gear changes before starts pump). Clutch disengaged at 1.84v and engaging 3.85. Did basics adjustments. Problem: pump is running constantly when engine is on. Car starts in S and N but won’t run. When I change to D or R car engine is revving but not drive because clutch is ON. VCDS group 3 showing Clutch position (Actual) 99.6% and Clutch position (specified) just running in a circle from 2% to 75% and back. Some time, when I start a car in N and then to D is disengage clutch and it drives and changes gears, but pump is running constantly. There is no leakage in a system. I on the way to buy a new clutch cylinder, but not sure it will help, and is not so cheap just to buy it and try. Can someone have advice? There is video from VCDS: - Heute
OK, tatsächlich das gleiche bezüglich der Kurbelwelle...
Gut also Kompressionsprüfung in den Zylindern - was dürfen die haben beim 1.2 tdi?
Wieso Loctide im SSP mit d statt t geschrieben wird? Da hat der Praktikant geschlampt ... :-)
Die haben aber nicht diese Zuganker, oder? Das kommt ja beim 1,2er noch dazu. Lange Rede kurzer Sinn, ich würde statt einer Überholung auch auf die Suche nach einem Motor mit guter Kompression gehen, ist vermutlich einfacher und am Ende billiger. Die Motoren sind schon sehr haltbar gebaut.
Ja das gleiche gilt auch für die 1.4 16V Gibt bei uns trotzdem 3 Blöcke, die das in der Werksausbildung überhört haben Aber beim Diesel: Kette der Ölpumpe und Zylinderkopf WG den PDE Elemente / Stützhalter. Danach fahr mal erstmal die 1 Mio km;)
Laut Selbststudienprogramm kann man den Motor nicht volständig revidieren: Das ssp223 findet man über die Google Suche beim https://www.vw3literlupoclub.com und bei Nininet.
Moin, an meinem A2 ist leider ein Kühlschlauch kaputt. Laut Werkstatt und eigener Recherche lässt sich kein neues bzw. auch kein gebrauchtes Ersatzteil mehr finden. Die Teilenummer ist 8Z0819371J. Es finden sich jedoch nur Ersatzschläuche mit der Endung K. Weiß jemand wo ich den richtigen Schlauch kaufen könnte? Vielen Dank! Mfg Nelly
Teilnehmerliste 19.9. und 20.9.25 - 25 Jahre Audi A2 in Neckarsulm
Martin Kathi A2 antwortete auf morgoth's Thema in Treffen
Guten Morgen, wir müssen leider wegen Krankheit absagen, die Buchung im Küffner Hof ist bereits storniert. Bitte uns auch aus der Essensliste austragen, danke... MfG Martin -
morgoth, eine Person, ein A2, kobaltblau Fr | Abendessen Freitag Nupi & Tatzino, 2 Personen, ein A2 Senior, äh Lichtsilber met. Fr + Sa + Ausfahrt, (Hotel Küffner Hof gebucht) A2magica, 1 Person, A2 "CS: Mattschwarz an Estorilblau Kristalleffekt", Fr + Sa + Ausfahrt, (Hotel Küffner Hof gebucht) seinelektriker, 1 Person, A2 "CS: Misanorot Perleffekt", Fr + Sa + Ausfahrt, (Hotel Küffner Hof gebucht) Granitei 2 Personen, ein A2, akoyasilber Fr.-Sa. + Ausfahrt, Hotel Küffner Hof gebucht. durnesss 2 Personen, ein A2, silber/matt/grau, Fr-Sa Hotel Küffler Hof, müssen spätestens Sa. Mittag zurück. Zweierlehrling, eine Person, ein A2, schwarz a2-701, eine Person, ein A2, CS:blau Seb Gurkyh, eine Person, ein A2 Milke, 1 Person , ein A2, Amulletrot, Fr 1 Person, Sa + Ausfahrt + Essen mit 4 Personen (Erw. + 2 Kinder) AudiA216RS nebst Streetfreak, zwei Personen, A2 CS Sprintblau, A2 CS Papayaorange, Do-Sa Hotel Küffler Hof Krebserl, 1 Person in einem meiner gelben A2-CS Elch A2 1-2 Personen ein A2 Kastellrot A2-s-line, 1 Person + evtl 2 Kids, einA2, ebonyschwarz - wenn, dann nur am Samstag Freitag ChristianFfm, eine Person, ein A2,optional Orga der PR Frickler, eine Person und ggf. 2 Zwerge, ein A2 A2-Aluflitzer, eine Person, ein A2, vermutlich schwarz (unter Vorbehalt vembicon, eine Person, ein Nicht-A2 olsta, 1-2 Personen, ein A2, Lichtsilber (vorr. nur Freitag) A2 HL Jense 1-2 Personen, mindestens 1, vielleicht 2 A2, auf jeden Fall Azurblau perleffekt, vielleicht zusätzlich CS blau Aida|Reisegruppe besteht aus: 1 Kind (Kita), 1 Kegel (erwachsen), 1 A2 (4G/LY3C) Istvan 1-3 Personen, ein A2 ebonyschwarz Sa + Ausfahrt 3ltdi|Reisegruppe besteht aus: 1 Kind (Kita) + Doppelkegel, vermutlich A2 3L grüne Pinie flipper493 1-2 Personen, ein A2 (nur Freitag) mamawutz + Frau mamawutz I 2 Personen, ein A2, Fr + Sa + Ausfahrt, (Hotel Küffner Hof gebucht, Delphingrau Audifanatiker 3 Personen, ein A2 (Atlantikblau) + ein weiterer A2 (Kastellrot) / Fr. + Sa. / FR. Abendessen + Zimmer Küffner-Hof HolgerBY, 1 Person, ein A2, ebonyschwarz HEY_A2, 1 Person, ein A2 Powdertiger, 1 A2 mauritiusblau, 1P jungera2ler, 2 Personen, 1x Colour.Storm Rot, 1x 3L Ebonyschwarz mit weißer Nase Joachim_A2, 1 - 2 Personen; 1x A2; Akoyasilber; Fr. + Sa. | Abendessen: Freitag, Küffner-Hof | Samstag: Teilnahme an Ausfahrt bis ca. 14:45 Uhr (nach Mittagessen auf Burg Stettenfels). murmeli 2 Personen , ein A2, Merlotrot Samstag + Ausfahrt AQuadrat 1-2 Personen, Papaya Orange FZR-rider 3-4 Personen, 2 A2, Atlantikblau & Kobaltblau YetAnotherA2Freund 1 Person, 1 A2, Ebonyschwarz-Perleffekt A2-Nerd 1-2 Personen, 1 A2, Kobaltblau audi22, 2 Pers, 1-2 A2`s, ebonyschwarz (& evtl. kobaltblau) bret, 1 pers, (1 A2) , Kristallblau. Noch ist nichts gebucht... bjoern1981 1 Pers, 1 A2, Ebonyschwarz Perleffekt ModiA2tdi, eine Pers, ein A2, silber (unter Vorbehalt) Kuestenbazi, 1-2 Personen, A2 FSI Color Storm Imolagelb Thomas L, 2 Personen; A2 1,4 islandgrün metaillic Praslin + 1 Person Audi A2 1,4 ATL silber MAK10 und Fauchilein 2 Personen Audi A2 1.4 ATL Color Storm Blau bart01 1-2 Personen, A2 1.4 Color Storm Imolagelb Mike Brachtvogel, 1 bis 2 Personen, Audi A2 1,6 FSI Ebony Schwarz Metallic A2-Sammler, 1-? Personen, A2 "in Planung" jfps, 1-? Personen, A2 "in Planung" A2-BW, 1 Person, 1 A2 1.4 Lichtsilber Metallic (voraussichtlich nur Freitag) Alu- Green 2 Personen, 1 A2 Lichtsilber DZ + AE 2 Personen pilot_malte 4 Personen, 1 A2 1.6 FSI piniengrün ulle0102 3 Personen ANY oder ATL, vielleicht auch beide Popeye82 2 Personen ANY Islandgrün, voraussichtlich nur Freitag SteSo, 1-2 Personen + evtl. 2Kids, A2 1.4 Schwarz metallic (nur am Samstag) basti11, 2 Personen + 1 Kid, A2 1.4TDI, silber (nur Freitag) Uli64 1 Person, A2 1.6 FSI Lichtsilber Metallic gonemillion 1 Person silber schwarz Martin Kathi A2 Personen, A2 1.4 AUA schwarz Fr. + Sa. |2 Personen | Abendessen: Freitag, Küffner-Hof Übernachtung gebucht | Samstag: Teilnahme an Ausfahrt Colortom Z1/P1/A1 A2 dti AMF Imolagelb,A- Tirol Tachostand fast 400t km Do bis Sa Kaiserin 1-2 Personen, nur Samstag ColorstormRHD 2 Personen,1.4 BBY Colorstorm Imolagelb, nur Freitag LeMans5 2 Personen, 1 Audi A2 S-line, Anthrazit, aus Tirol, von Do bis Sa Karlsruhe ? Personen, 1 A2, nur Freitag Silberteufel 2 Personen mit A2 - 1,4 ATL Akoyasilber Teilnahme mit Diner kein ÜF , Freitag + Samstag Morgen Phoenix A2 1 Person, 1 A2, Freitag + Samstag Morgen PROVOTEC 2 Personen, A2 Lichtsilber (unter Vorbehalt) A2^2 1 Person, A2 1.4 TDI Azurblau Freitag + Samstag Tomtath 1 Person Samstag nur 10 - 13 Uhr blauer CS 1,4 mit blauem Dach (unter Vorbehalt) ANY-Fahrerin 1 Person 1 A2 (ATL, schwarz, OSS) nur Samstag Leon1999 3 Personen, 1 A2 (AUA, Ebonyschwarz Perleffekt, OSS) voraussichtlich nur Freitag 70. Leypi 1 Person Samstag BHC CS blau -
Dann nehme ich das doch mal Volley : wenn die Motoren standfest sind, passen also die Kolbenabstreifringe - Sind Undichtigkeiten an den Injektoren für diese nicht gechipten ANY bekannt?
Jut dann danke erstmal soweit. Dann „nur noch“ nen neuen Turbo rein.
Meist sind es eher die auf 90 PS gemappten und entsprechend bewegten ANY A2s, wo die Motoren irgendwann durch sind. Bei einem eher unwahrscheinlich... Tatsächlich streuen die aber in der Leistung ziemlich, so mein Eindruck nach inzwischen einigen 3L... Gibt hier im Forum jemanden, der die überholt aber das ist schon deutlich teurer als ein Tauschmotor...
Es gab hier letztens gerade einen Thread darüber mit der Quintessenz, daß die ANY normalerweise selbst bei enormen km-Leistungen nicht kaputt gehen und für den unwahrscheinlichen Fall, daß sie es doch tun, steht auf dem Gebrauchtmarkt ausreichend Ersatz zur Verfügung und deshalb gibt es keinen, der sich mit Motorüberholung des ANY beschäftigt, weil es einfach keinen Bedarf dafür gibt. Ganz abgesehen davon, daß man glaube ich die Kurbelwelle gar nicht entfernen darf wegen möglichem Verzug des Motorblocks, soweit ich mich recht erinnere... Edith: Da: https://a2-freun.de/forum/forums/topic/98239-12-tdi-any-motorinstandsetzung/#comment-1066220
Moin Community, ich bin auf der Suche den 1,2 tdi von unserem Holländer einmal revidieren zu lassen. Hat dazu jemand Empfehlungen? Ein bloßer AT Motor kommt nicht in Betracht, die Hydraulik und das Getriebe wurden beide überarbeitet, und da das Auto noch lange fahren soll hätte ich was das angeht gerne einfach auch die Gewissheit: Jawohl ist gemacht worden. Und noch ne Frage zum Forum: Ich würd so gern einfach Fotos vom IPhone hier hochladen, ich weiß es gibt ne Größenbegrenzung, aber warum dann nicht die Fotos automatisch runter rendern? Dann kann ich auch endlich mal unsere beiden unter Projekte anlegen. Grüße
Wie hast du das gemessen, Zangenamperemeter? Übliche Verdächtige sinḍ das Komfortsteuergerät (einfach mal abklemmen) und wieder messen. Bei mir war es mal der Microschalter in der Heckklappe, da brannte umbemerkt die Kofferraumbeleuchtung. Wie man das Auto im standby messen kann, habe ich mich auch schon gefragt, man muss ja an die Batterie, geht es auch in Standby, wenn die heckklappe noch auf ist oder kann man da einen Schließbügel mit einer Schraube faken und ins schloss stecken um "zu" vorzutäuschen.
Moin. Danke für den Hinweis. Hab's geändert
ich habe ebenfalls Herausforderungen mit meiner Batterie. Um Herauszufinden ob diese "fällig" ist oder die Ursache woanders liegt wollte ich prüfen: - lädt die Lichtmaschine ausreichend: Ergebnis JA - Test der Batterie durch Messgerät: "sollte bald ausgetauscht werden" - Gibt es Verbraucher im Ruhezustand, welche die Batterie leersaugen: Hierzu habe ich direkt an den Sicherungen gemessen (Man soll diese nicht herausziehen). Dabei fielen mit 2 Sicherungen auf, welche einen geringen Wert anzeigten. Nr. 36 (ZV Leuchten, Klima, Heizungsbetätigung) und Nr42 (Innenleuchten, Leseleuchten, DWA, ZV). Das Fahrzeug hatte ich für die Messung "abgeschlossen (Fahrertür offen) - Wie lange muss man warten bis alle Steuergeräte in den Schlafmodus sind?
Hallo, ich habe eben von dem A2 Treffen in Neckarsulm erfahren. Ich würde gerne vorbeikommen, allerdings wenn dann kurzfristig am Samstag, muss leider am Freitag arbeiten. Ich fahre, seit gestern, nach ca. 12 Jahren wieder einen etwas pflegebedürftigen A2 FSI, jetzt mit Open Sky, in Delphingrau. Falls ich es nicht schaffe wünsche ich allen ein schönes Treffen. Grüße von der Mosel Thomas
Einfach vorbeikommen - und bis dahin die aktuellen Änderungen im Blick behalten unter https://a2-freun.de/forum/. Weiteres kann man vor Ort besprechen. Terminablauf für Samstag den 20.09.2025: 10:00 Uhr bis 13:00 Uhr: Parken mit Fotosession und Fachgesprächen auf dem Plaza für Audi A2 Fahrzeuge ab 13:00 Uhr: Ausfahrt mit den Audi A2 mit Mittagessen, spannenden Zwischenstopps und Actionfotos. Ein Guide zur genauen Route und anderen Besonderheiten der Ausfahrt wird erst kurz vor dem Event zur Verfügung stehen, um ggf. notwendige Anpassungen durch Wetter o.Ä. einzubeziehen.
Die haben sich aktiv (vor uns) versteckt, damit sie nicht auffallen.
Servus aus Heilbronn. Wir würden gerne mit unserem Merlorotem A2 auch mitmachen. Können aber leider nur am Samstag bis 14h. Wäre das noch möglich und was wäre ich Euch schuldig. Ciao Astrid und Heinz.
Beim beschleunigen hört sich nach Antriebswelle an, glaube die inneren gelenke
