Ich hab den neuen schon drinn, könnte mir aber auch vorstellen das der alte noch funktioniert. Sauber gemacht habe ich den alten natürlich. Liegt jetzt bei den anderen alten Teilen... (ja ich hebe sowas immer auf)
Ich würde die AHK-Steckdose mal öffnen: bei mir hatte ich ein ähnliches Problem und da waren ein paar Kabel aus den Schraubklemmen gerutscht und kamen in Kontakt
Kann mir jemand sagen wo ich diese Dichtung her bekomme. Das ist die vom AGR Rohr welche an die Drosselklappe rangeht. Bzw. hat jemand ne Teilenummer? Die gelieferte ist definitiv zu groß.
Good day, The car is A2 2005 1.2tdi. I have got a problem with the basic setting, the error is RTFM 12. The lower lever of the selector was broken (it was welded earlier by previous onwer, but the work is carried out not quality and it is broken once again ). After welding the lever is mounted again, I suppose the position of it is right because I try to act accordning to the inctructions of this forum and wiki. Now after 2 cycles I have got the RTFM 12, before repairing it worked properly. 1. The Errors are not present. 1. Rare lights turn on 5-8 steps on each cycle, then they turn off. 2. Manually all gears are sellected with out any problems, the indication of G240 is 3,9V-2,9V-2,1V-1,05V (the percents is normally too), the indication of G239 is 1,5V-2,65V-3,9V (the percents is not so good, about 85%-45%-1-2%). I move a little (right left) the flag of G239 the voltages also a little change, for example, 1,6V-2,75V-4,0V (percents recalculate, but lower border (2,4 gears) can not achieve 100%-90%) I noticed, if I manually overcome the resistance of the gearbox shaft spring and continue pulling the lever to the left, I can reach about 95% of G239 (2,4 gears) , but this is not fixed position. If I shift the lever on the shaft on 1 tooth left or right I can not select all gears. Thus I suppose it is only one right positon of the lever (the working area of the lower lever without connecting to the shaft of the gearbox is about only 4 teeth) Can this cause the error RTFM 12? 3. The voltage of clutch cylinder is about 1,95V and 4,0-4,05V accordingly 4. During the procedure of the basic setting I can see under the car due to the long cable that all gears are selected R-1-2-3-4-5, then N between the 1st and 2nd cycles and once again R-1-2-3-4-5, on the FIS indicator chooses step by step 1-2-3-4-5 and stays on the 5th until starting of the 2nd cycle. Could you advise something? Thanks.
Verratnix antwortete auf A2_5SeatLegend's Thema in Technik
Getdilt Norddeutschland/ Hamburger Umland
INHRO antwortete auf Flyingcircus's Thema in Verbraucherberatung
oh. Wer lesen kann ist klar im Vorteil ;-) hatte das mit der Kette übersehen. *mist -
Lupo_3L antwortete auf avant-tdi's Thema in Verbraucherberatung
Nur wenn du das Zitat so kürzt, wie du es getan hast ... Darum geht es Die genannten Stahlfelgen sind günstig sogar neu noch verfügbar, XL1 Felgen sind überhaupt nicht verfügbar. Deswegen ist das eine eine Option, das andere nicht. Hast du vermutlich anders verstanden. Tachoanpassung siehe oben! Warum wiederholst du das jetzt nochmal? Muss ich es nochmal verlinken? Lösungen zu suchen und zu finden für das Problem, dass die 145er nicht mehr lieferbar sind ist unsere gemeinsame Mission, oder?
- Carpinus
- Schwabe
- Durnesss
- Titoph127
- NSM
- Mesti
- Kreiskoenig
- America
- AudiA216RS
- ThePurpleKnight
- Cklas
- Aluigel
- aeppelken
- Zweierlehrling
- ThomasDitlev
- leonleon2
- willem docter
- NSUFahrer
- DerWeißeA2
- Smoke–k2
- redmkiv
- janihani
- MrE
- seinelektriker
- Freakazoid
- Räubermutti
- luis.
- Goggele
- arosist
- Audi_Coupe_S
- Mr.Smith
- HellSoldier
- A2 Papayaorange
