FSI - bei -16° mag er nicht..
Hi Jense, würdest Du mir (auch gerne als PM) den Preis für die Restauration eines Lichtschalters mitteilen? Meiner hat allerdings mehr Piktogramme (6 an der Zahl => 0 - AUTO - Standlicht - Abblendlicht - Nebelscheinwerfer - Nebelschlussleuchte) Viele Grüsse Chris -
19
Seitenschweller
...mittlerweile ist die Kugel ein Erzgebirger ;-) ...hab ihn aber auf den Bildern gleich erkannt... -
NOx sensor wiring - for retrofitting Golf sensor
Give it a try, the internal wiring will be most likely the same because its a Carry-Over-Part used in many vag Cars. I would pin it according to the cable colours. -
Hello everybody! I have a permanent error on the NOx sensor (Signal too low) on my 2001 A2 1.6 FSI. So, I am looking to replace it. The original NOx sensor (8Z0 906 261) is >400Eur if I am lucky to find one available in stock... VW Golfs of 2003-2008 had the same (BAD) engine and their NOx sensors (036 906 261 D) look very similar - except for a shorter cable and a different plug. Our sensor: Golf's: The connectors look the same, so i would guess the pinout is the same - but this is just a guess... So I am thinking to take out my NOx sensor, cut the wires and solder in the sensor from Golf. The issue is - I am struggling to get the pinout of the Golf's sensor. Audi A2 (BAD) diagram: VW Golf (BAD) diagram: The exact pin-by-pin assignment of the G295 sensing element on VW GOLF 2003 – 1.6 l/81 kW, engine code BAD is not published in VW service literature, because on the BAD 1.6 FSI system the G295 NOx sensor and J583 NOx control unit are treated as one assembly. The service wiring diagrams only show the vehicle-side connector T10v (10-pin) at the J583 control module, not the internal sensor wiring. Has anybody here done this already? Do you know the Golf's NOx sensor G295 pins assignment? Is it identical to ours? Thanks alot!! -
Angebotener A2
Danke. Der Preis ist schon hoch. Querlenker, Koppelstangen, Bremsen hinten, Öle und Filter sind frisch. Winterreifen sind dabei. Ich schau mal. -
[1.6 FSI BAD] Bremsleitungen - Bremsschlauch - hinten - nicht mehr verfügbar
Moin! Hat der TüV bei der Lösung mit dem A4 Schlauch auf der Fahrerseite (Bild von janihani vom 01.08.2022) da nichts dagegen ? Es fehlen doch irgendwie Befestigungen (dauerhaft sichere) oder wie argumentiert man das weg ? Auf dem Bild ist auch nur eine Überwurfmutter dran und dann gehts direkt an den A4-Schlauch von der CuniFer Leitung. Sehe ich das richtig ? Reicht das so ? Warum kein Verbindungsstück noch zusätzlich dazwischen ? Merci u Gruss, P -
[1.4 AUA] Oil sump spare part 032103603AA ?
Sump.... pump.... I need a coffee
