[1.2 TDI ANY] - HELP: 6.9L/100km
Thanks Manni. Yes I aim towards lower consumption but since I suspect turbo for wear I need to choose between upgrading to a more efficient turbo or repairing the old one. Maybe you are familiar with: https://forums.tdiclub.com/index.php?threads/1-2-tdi-tuning-info.390974/ I looked at what he did with his 1.2 lupo. He till has insane fuel consumption but he also done 100 other things to the car. I will not be able to go that drastic but i can implement part of modifications. -
69
Jepp .... Thats the Game also in the same housing. More flow with high Rpm at high exhaust rate or quick high pressure by low flow. There is no magic which brake this problem. Therefore machines which needs high flow at high rate gets twin turbos. One small size for lower rpm and one bigger for high Rpm. What ist your Goal ??? Lower consumption ?? Then stay on "reparing" and get all parts in fine condition -
69
Are you sure? As far as I know Tuneko Ltd the one that tuned the 1.2 lupo a lot got 90hp from this engine with stock stuff therefore i believe the turbo is somewhat limited. The turbo on 1.4 tdi 90 is not the same with the one on 1.2 tdi. That's why I believe the 1.2 turbo is not as potent. I agree a bigger turbo has bigger lag but since only the pallets/wheels (going billet) are different I expect an improvement in efficiency for the same garret housing. I expect it to make better use of same flow since the billet wheels are lighter and have better airflow. In fact I expect lower lag because of better use of flow and decrease in spinning mass. Do you think I am looking at this wrong? -
VCDS / Diagnose für Anfänger beim A2
So fangen wir erstmal an: 1x Laptop: In meinem Fall ein alter IBM T60 , früherer Programmierlaptop. https://www.ebay.de/itm/226121377907 Dieser bekommt ein brisches Windows 7 64 bit. Dafür benötigt ihr das Windows 7 USB Tool: Original von Microsoft: https://www.microsoft.com/de-de/download/details.aspx?id=56485 Und dann noch die Windows 7 Datei : https://winfuture.de/downloadvorschalt,3291.html Und Weiter / USB Gerät / Ja löschen und schwups startet der Kopiervorgang. Da auf dem Stick noch Platz ist werden noch 2 Programme heruntergeladen: 1x Avast Free ( bitte nach Offline Installer googlen) Und den Firefox Browser Offline Installaer Am ende habt ihr dann folgende Dateien: So nun einmal den Laptop vom USB Stick booten und Windows installieren. Wer sich nciht sicher ist: Youtube -
6.086
Hat schon mal wer diesen Gummibalg unter dem Schaltsack ersetzt? Wenn ja, womit? Beim ATL ist der kaputt, und ich möchte das wieder luftdicht verschließen. Das Ding mein ich: Findet man auch nicht im Teilekatalog. -
69
The stock Turbo is capable of doing 120 HP so I question the necessity of an upgrade Turbo especially since a bigger turbo usually does not spool up that fast. -
69
Fixed all the leaks from intake and added some superglue to the vacuum pump (there was no smoke coming out of it anymore). The turbo o-ring for the intake was a little hard to find but got one in the end. It is a different car now. It does not rattle so much in eco mode. It is a pain to drive 50km/hr (it rattles a bit because it shifts in 5th gear in eco mode). The consumption seems to have gone 1L down compared to the previous test I done in this topic last year. In eco mode mixed - mostly external I get now 3.9L/100km. In normal mode when i arrived at home after the steep hill the consumption was 4.4L/100km. I will be back with some city consumption after at least a month. (i do not drive the car that much ). STILL one weird thing: When pressuring the vacuum hoses with the smoke machine I noticed smoke coming from the engine air intake. I suspect that the tandem pump/vacuum pump is not good inside - it does not seal well between oil and vacuum maybe. The vacuum side should not communicate with the engine side/oil side at least not by my logic and knowledge so this might be another big issue. I ordered a new pump from pierburg (it seems to have a better design than the luk version i have on the car) . The new tandem pump price is around 200 euros today in 2024-05 on autodoc24 (the mobile app). This might also explain oil consumption - i taught that the valve seals might be old but now the tandem pump is also on the list. It would be nice if the pump solves the oil consumption too. The smoke test will be done again with the new pump. If the result is different this might be a good way to determine if the tandem pump is broken inside. I expect a big difference with the new tandem pump if not than the injectors and turbo will be next. The new turbo i've been looking at is this one: https://muchboost.com/product/1-2-tdi-hybrid-turbo-upgrade-audi-a2-volkswagen-lupo-seat-arosa-any-ayz/ . But for now i hope that the tandem pump will solve a lot. -
34
Audi A2 1.2 tdi turbo doesn't work properly
Not sure if this topic has a conclusion or not. For me the bad consumption had several sources: 1)The T on the fuel filter (if you have the metal version -- the older ones) -It was cracked and air got into fuel system. 2)Air intake leaks -- on the oil stick pipe one o-ring was missing - after plugging this there was a big improvement. Also check the oil level sensor for missing or worn out orings. 3)air leak near turbo intake hose -- the o-ring was warn out and turbo was aspirating false air. 4)tandem pump might be defective inside - this is yet to be proven after I replace the current one with a new one. Find updates on my post. Usually the older version of tandem pumps had that issue with the hose plug getting loose BUT also with the seals between oil side and fuel side and vacuum side. You need to get a smoke machine for detecting leaks. You would not believe where the leaks are until you test for it. The car runs well with this leaks also and you cannot find anything specific on vag-com or computer diagnose. -
11
Programm für das Jahrestreffen vom 05.07. bis zum 07.07.2024 am Grohnder Fährhaus
Teilnehmerliste Programm: Abendessen für bis zu 20 Personen am Freitag 05.07.2024 im Grohnder Fährhaus: Nupi Tatzino Durnesss DerWeißeA2 Everconnect Abendessen für bis zu 40 Personen am Samstag 06.07.2024 im Grohnder Fährhaus: Nupi Tatzino Durnesss Audifanatiker + 3 Personen DerWeißeA2 alleswirdgut2 + 1/2P a2-701 Everconnect- 1
145
Anleitung: Trommelbremsen hinten auf Scheibenbremsen umbauen
Sind gleich.- 1
- anleitung
- hinterachse
(und 3 weitere)
